[petsc-users] Debug build fails
Zane Charles Jakobs Zane.Jakobs at colorado.edu
Sat Oct 3 10:11:21 CDT 2020
Hi PETSc devs,
I just pulled the latest version of PETSc on master, and while my optimized
build works fine, my debug build fails with the message
make[1]: *** No rule to make target 'src/sys/logging/examples/makefile'.
Stop.
make: *** [GNUmakefile:17: src/sys/logging/examples/makefile] Error 2
Doing
ls src/sys/logging/examples
shows a file named `index.html` and a directory named `tutorials`, but no
makefile. My configure line is
./configure PETSC_ARCH=arch-linux-c-debug --with-cc=clang
--with-cxx=clang++ COPTFLAGS="-O3 -march=native -mtune=native -fPIC"
CXXOPTFLAGS="-O3 -march=native -mtune=native -fPIC" FOPTFLAGS="-O3
-march=native -mtune=native -fPIC" --with-avx2=1 --download-mpich
--download-hypre --download-scalapack --download-mumps --with-debugging=yes
--with-blaslapack-dir=/opt/intel/mkl --download-zlib --download-libpng
--download-giflib --download-libjpeg --download-slepc --download-eigen
To reiterate, doing the exact same configure, but changing
'-with-debugging=yes' to '-with-debugging=no' (and changing the PETSC_ARCH
name to 'arch-linux-c-debug') and then building the non-debugging version
of PETSc works as normal. Any ideas what could be going on?
Thanks!
-Zane Jakobs
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201003/3357c3fe/attachment.html>
