[petsc-users] Ainsworth formula to solve saddle point problems / preconditioner for shell matrices
Barry Smith bsmith at petsc.dev
Fri Oct 2 17:23:57 CDT 2020
> On Oct 2, 2020, at 6:50 AM, Olivier Jamond <olivier.jamond at cea.fr> wrote:
> Dear Jed,
> The code I am working on is quite generic and at the solve step, the matrix C can be 'whatever' (but is supposed to be full rank). But in practice, in 99% of the cases, C contain MPCs that refers to boundary conditions applied to subsets of the mesh boundary. These MPCs can couple several dofs, and a given dofs can be involved in several MPCs. For example, one could impose that the average of the solution in the x-direction is null on a part of the boundary, and that this part of the boundary is in contact with another part of the boundary.
> So yes, CCt is block diagonal, where each block is a set of MPCs that share dofs, and CtC is also block diagonal, where each block is a set of dofs that share MPCs. For the vast majority of cases, these blocks involve dofs/MPCs attached to a subset of the boundary, so they are small with respect to the total number of dofs (and their size grows slower than the total number of dofs when the mesh is refined).
> I am not sure to understand what you mean by compute the MPCs explicitly: do you mean eliminating them? For very simple dirichlet conditions I see how to do that, but in a more generic case I don't see (but there may be some techniques I don't know about!).
> I don't understand also what you mean by cleaning them in a small number of krylov iterations?
   I think what Jed is saying is that you should just actually build your preconditioner for your Ct*C + Qt*S*Q operator with S. Because Ct is tall and skinny the eigenstructure of Ct*C + Qt*S*Q is just the eigenstructure of S with a low rank "modification" and Krylov methods (GMRES) are good at solving problems where the eigenstructure of the preconditioner is only a small rank modification of the eigenstructure of the operator you are supply to GMRES. In the best situation each new iteration of GMRES corrects one more of the "rogue" eigen directions. I would first use a direct solver with S just to test how well it works as a preconditioner and then switch to GAMG or whatever should work efficiently for solving your particular S matrix.
  I'd be interested in hearing how well the Ainsworth Formula works, it is something that might be worth adding to PCFIELDSPLIT.
  Barry
> Many thanks,
> Olivier
> On 01/10/2020 20:47, Jed Brown wrote:
>> Olivier Jamond <olivier.jamond at cea.fr> writes:
>>> Dear all,
>>> I am working on a finite-elements/finite-volumes code, whose distributed
>>> solver is based on petsc. For FE, it relies on Lagrange multipliers for
>>> the imposition of various boundary conditions or interactions (simple
>>> dirichlet, contact, ...). This results in saddle point problems:
>>> [S Ct][x]=[f]
>>> [C 0 ][y] [g]
>>> As discussed in this mailing list ("Saddle point problem with nested
>>> matrix and a relatively small number of Lagrange multipliers"), the
>>> fieldsplit/PC_COMPOSITE_SCHUR approach involves (2 + 'number of
>>> iterations of the KSP for the Schur complement') KSPSolve(S, Sp). I
>>> would like to try the formula given by Ainsworth in [1] to solve this
>>> problem:
>>> x = (Sp)^(-1) * fp
>>> y = Rt * (f - S*x)
>>> where:
>>> Sp= Ct*C + Qt*S*Q
>> I just want to observe here that Ct*C lives in the big space and is low rank.  It's kinda like what you would get from an augmented Lagrangian approach.
>> The second term involves these commutators that destroy sparsity in general, but the context of the paper (as I interpreted it in a quick skim) is such that C*Ct consists of small decoupled blocks associated with each MPC.  The suggestion is that these can either be computed explicitly (possibly at the element level) or cleaned up in a small number of Krylov iterations.
>>> Q = I - P
>>> P = R * C
>>> R = Ct * (C*Ct)^(-1)
>>> My input matrices (S and C) are MPIAIJ matrices. I create a shell matrix
>>> for Sp (because it involves (C*Ct)^(-1) so I think it may be a bad idea
>>> to compute it explicitly...) with the MatMult operator to use it in a
>>> KSPSolve. The C matrix and g vector are scaled so that the condition
>>> number of Sp is similar to the one of S.
>>> It works, but my main problem is that because Sp is a shell matrix, as
>>> far as I understand, I deprive myself of all the petsc
>>> preconditioners... I tried to use S as a preconditioning matrix, but
>>> it's not good: With a GAMG preconditioner, my iteration number is about
>>> 4 times higher than in a "debug" version where I compute Sp explicitly
>>> as a MPIAIJ matrix and use it as preconditioning matrix.
>> Are your coupling constraints nonlocal, such that C*Ct is not block diagonal?
>>> Is there a way to use the petsc preconditioners for shell matrices or at
>>> least to define a shell preconditioner that internally calls the petsc
>>> preconditioners?
>>> In the end I would like to have something like GAMG(Ct*C + Qt*S*Q) as a
>>> preconditioner (here Q is a shell matrix), or something
>>> like Qt*GAMG(S)*Q (which from matlab experimentation could be a
>>> good preconditioner).
>>> Many thanks,
>>> Olivier
>>> [1]: Ainsworth, M. (2001). Essential boundary conditions and multi-point
>>> constraints in finite element analysis. Computer Methods in Applied
>>> Mechanics and Engineering, 190(48), 6323-6339.
