[petsc-users] Memory violation in PetscFVLeastSquaresPseudoInverseSVD_Static
Pierre Seize
Pierre.Seize at onera.fr
Thu Oct 1 03:18:22 CDT 2020
Sure I'll try,
I was thinking of using ls->B as the A matrix for dgelss, ls->work as
work and ls->Binv as B. The result is then stored in ls->Binv, but in
column-major format.
Right now, the column-major result is transposed in
PetscFVLeastSquaresPseudoInverseSVD_Static, and the row-major result is
copied in the output in PetscFVComputeGradient_LeastSquares. I think
it's because PetscFVLeastSquaresPseudoInverse_Static gives the result in
row-major format.
Would it be alright if I changed
PetscFVLeastSquaresPseudoInverseSVD_Static so that the result would
still be in column-major format ? I could include the result recopy in
the if statement for example.
Moreover, this would be to keep the compatibility with
PetscFVLeastSquaresPseudoInverse_Static, but right now it is manually
disabled (with useSVD = PETSC_TRUE), so I am worrying for nothing ?
Pierre
On 30/09/20 20:38, Jed Brown wrote:
> Pierre Seize <Pierre.Seize at onera.fr> writes:
>> Hi,
>> In PetscFVLeastSquaresPseudoInverseSVD_Static, there is
>> Brhs = work;
>> maxmn = PetscMax(m,n);
>> for (j=0; j<maxmn; j++) {
>> for (i=0; i<maxmn; i++) Brhs[i + j*maxmn] = 1.0*(i == j);
>> where on the calling function, PetscFVComputeGradient_LeastSquares, we
>> set the arguments m <= numFaces, n <= dim and work <= ls->work. The size
>> of the work array is computed in PetscFVLeastSquaresSetMaxFaces_LS as:
>> ls->maxFaces = maxFaces;
>> m = ls->maxFaces;
>> n = dim;
>> nrhs = ls->maxFaces;
>> minwork = 3*PetscMin(m,n) + PetscMax(2*PetscMin(m,n),
>> PetscMax(PetscMax(m,n), nrhs)); /* required by LAPACK */
> It's totally buggy because this formula is for the argument to dgelss, but the array is being used for a different purpose (to place Brhs).
> WORK
> WORK is DOUBLE PRECISION array, dimension (MAX(1,LWORK))
> On exit, if INFO = 0, WORK(1) returns the optimal LWORK.
> LWORK
> LWORK is INTEGER
> The dimension of the array WORK. LWORK >= 1, and also:
> LWORK >= 3*min(M,N) + max( 2*min(M,N), max(M,N), NRHS )
> For good performance, LWORK should generally be larger.
> If LWORK = -1, then a workspace query is assumed; the routine
> only calculates the optimal size of the WORK array, returns
> this value as the first entry of the WORK array, and no error
> message related to LWORK is issued by XERBLA.
> There should be a separate allocation for Brhs and the work argument should be passed through to dgelss.
> The current code passes
> tmpwork = Ainv;
> along to dgelss, but we don't know that it's the right size either.
> Would you be willing to submit a merge request with your best attempt at fixing this. I can help review and we'll get it into the 3.14.1 release?
>> ls->workSize = 5*minwork; /* We can afford to be extra generous */
>> In my example, the used size (maxmn * maxmn) is 81, and the actual size
>> (ls->workSize) is 75, and therefore valgrind complains.
>> Is it because I am missing something, or is it a bug ?
>> Thanks
>> Pierre Seize
