[petsc-users] Using Petsc-Matlab engine on a cluster
Barry Smith
bsmith at petsc.dev
Sat Nov 28 20:30:08 CST 2020
PetscMatlabEngineEvaluate(mpc->mengine,"clc; clear all; close all; addpath([cd,'/MPC_matlab_code'])");
Undefined function or variable 'load_mpc_parameters'.
My guess is that the 'cd' may be different on the different machines, hence it does not do the addpath() you expect and hence cannot find the script load_mpc_parameters ?
In the branch I provided I have just now added more output messages if you run with the PETSc option -info that might indicate what is happening. So you can git pull; make libs and run again.
Barry
> On Nov 12, 2020, at 1:48 AM, Kaustubh Khedkar <kkhedkar9879 at sdsu.edu> wrote:
> Hi Barry,
> I used the branch barry/2020-11-10/add-matlab-engine-host. Now it appears that the matlab engine starts can start on any node but it is not able to execute any matlab script. If I revert back to PETSc 3.13.5 the head compute node is able to execute the MATLAB script. See the following error (load_mpc_parameters.m is a MATLAB script that the code is trying to execute):
> Starting Matlab engine...
> Matlab engine started
> Storing variables in Matlab workspace...
> Error using save
> Variable 'a' not found.
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Error in external library
> [0]PETSC ERROR: Unable to get array a from matlab
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: unknown GIT Date: unknown
> [0]PETSC ERROR: ./main3d on a linux-opt named node35 by kkhedkar Thu Nov 12 02:39:47 2020
> [0]PETSC ERROR: Configure options --CC=/home/kkhedkar/sfw/mpich3.3_mellanox/3.3/bin/mpicc --CXX=/home/kkhedkar/sfw/mpich3.3_mellanox/3.3/bin/mpicxx --FC=/home/kkhedkar/sfw/mpich3.3_mellanox/3.3/bin/mpif90 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --PETSC_ARCH=linux-opt --with-debugging=0 --download-hypre=1 --with-x=0 --download-fblaslapack=1 --with-matlab-dir=/nas/app/MATLAB/matlab2019a/ --with-matlab-engine=1 --with-matlab-engine-dir=/nas/app/MATLAB/matlab2019a/extern/engines/
> [0]PETSC ERROR: #1 PetscMatlabEngineGetArray() line 407 in /home/kkhedkar/sfw/petsc_matlab_host_fix/petsc/src/sys/classes/matlabengine/matlab.c
> Error using save
> Variable 'h' not found.
> [0]PETSC ERROR: #2 PetscMatlabEngineGetArray() line 407 in /home/kkhedkar/sfw/petsc_matlab_host_fix/petsc/src/sys/classes/matlabengine/matlab.c
> Error using save
> Variable 'mpc_start_time' not found.
> [0]PETSC ERROR: #3 PetscMatlabEngineGetArray() line 407 in /home/kkhedkar/sfw/petsc_matlab_host_fix/petsc/src/sys/classes/matlabengine/matlab.c
> Error using save
> Variable 'sample_size' not found.
> sample_size = 0
> [0]PETSC ERROR: #4 PetscMatlabEngineGetArray() line 407 in /home/kkhedkar/sfw/petsc_matlab_host_fix/petsc/src/sys/classes/matlabengine/matlab.c
> Error using save
> Variable 'dt_sampling' not found.
> Storing up past excitation force samples every 0 time-steps.
> [0]PETSC ERROR: #5 PetscMatlabEngineGetArray() line 407 in /home/kkhedkar/sfw/petsc_matlab_host_fix/petsc/src/sys/classes/matlabengine/matlab.c
> IBRedundantInitializer: Deallocating initialization data.
> My code is using Petsc matlab engine in this way (“master” is the hostname of the head node where MATLAB is licensed):
> if(SAMRAI_MPI::getRank() == 0)
> std::cout << "\nStarting Matlab engine...\n" << std::endl;
> PetscMatlabEngineCreate(PETSC_COMM_SELF, "master", &(mpc->mengine));
> std::cout << "Matlab engine started" << std::endl;
> std::cout << "Storing variables in Matlab workspace...\n" << std::endl;
> PetscMatlabEngineEvaluate(mpc->mengine,"global hydro wave; wave.H_wave = %f ; wave.Tp = %f; m = %f;", input_db->getDouble("HEIGHT"), input_db->getDouble("TIME_PERIOD"), input_db->getDouble("MASS"));
> PetscMatlabEngineEvaluate(mpc->mengine,"load_mpc_parameters; calculate_mpc_matrices");
> PetscMatlabEngineGetArray(mpc->mengine, 1, 1, &(mpc->m_plus_Ainf), "a");
> PetscMatlabEngineGetArray(mpc->mengine, 1, 1, &(mpc->dt_controller), "h");
> PetscMatlabEngineGetArray(mpc->mengine, 1, 1, &(mpc->mpc_start_time), "mpc_start_time");
> PetscScalar sample_size;
> PetscMatlabEngineGetArray(mpc->mengine, 1, 1, &sample_size, "sample_size");
> mpc->sample_size = int(sample_size);
> std::cout << "\nsample_size = " << mpc->sample_size << std::endl;
> mpc->F_past.resize(mpc->sample_size);
> mpc->t_past.resize(mpc->sample_size);
> double dt = input_db->getDouble("DT_MAX");
> mpc->initial_position = input_db->getDouble("ZCOM");
> mpc->current_position = mpc->initial_position;
> PetscScalar dt_sampling;
> PetscMatlabEngineGetArray(mpc->mengine, 1, 1, &dt_sampling, "dt_sampling");
> mpc->sampling_interval = int(dt_sampling / dt);
> std::cout << "Storing up past excitation force samples every " << mpc->sampling_interval << " time-steps.\n" << std::endl;
> From: Barry Smith <bsmith at petsc.dev>
> Date: Tuesday, November 10, 2020 at 5:22 PM
> To: Kaustubh Khedkar <kkhedkar9879 at sdsu.edu>
> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Using Petsc-Matlab engine on a cluster
> In the git branch barry/2020-11-10/add-matlab-engine-host I have added the option -matlab_engine_host hostname
> Note this does require you have ssh access to hostname from where your PETSc program is running which may require setting up some ssh files
> Good luck
> Barry
> On Nov 9, 2020, at 5:35 PM, Kaustubh Khedkar <kkhedkar9879 at sdsu.edu <mailto:kkhedkar9879 at sdsu.edu>> wrote:
> Hello,
> I am using PETSc with Matlab engine. I have built an application that uses Matlab engine through PETSc interface. I am trying to run this application on a cluster which has Matlab installed on a network drive (nas drive). I have made sure that I am able to access Matlab using my university details on the cluster (by activating Matlab license through Mathworks.com <http://mathworks.com/> account). I am also able to run this application using mpirun on the head node (master) which starts the Matlab engine but if I try to run this application using slurm on compute node then the Matlab engine does not start. I have also confirmed that if I login into one of the compute nodes and do a mpirun the Matlab engine does not start there. If I try to launch Matlab on a compute node it asks for Matlab license which the compute node is unable to activate possibly because it is not connected to the internet directly.
> Is there a way start matlab engine on the head node through Petsc interface even though the application is running on compute nodes or is there any other work around this issue?
> Thanks,
> Kaustubh Khedkar
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201128/1f5b31ce/attachment.html>
