[petsc-users] CVODE N_Vector PETSc interface gives a memory corruption error
Praharsh Suryadevara surya031 at umn.edu
Thu Nov 19 09:04:52 CST 2020
Thanks!
 The main reason is I want to be able to use SNES within CVODE as they
state in the sundials manual; however, the notes in the documentation
here https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSUNDIALS.html
states that it uses the sundials, internal solver. Is there a way
around that?
Praharsh
On Thu, Nov 19, 2020 at 7:36 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 18, 2020 at 11:11 PM Praharsh Suryadevara via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hi All,
>> I asked this on StackOverflow but I realized it's better off asked here,
>> I'm trying to use the CVODE_PETSc interface, and I've been getting
>> memory corruption errors I couldn't understand, so I tried to make a
>> minimal reproducible example for one below. Running this,
> There is a bug in CVODE's PETSc interface:
> ==16192== Invalid write of size 8
> ==16192==    at 0x4E4553C: N_VNewEmpty_Petsc (in /home/praharsh/.local/lib/libsundials_nvecpetsc.so.5.5.0)
> ==16192==    by 0x4E45630: N_VMake_Petsc (in /home/praharsh/.local/lib/libsundials_nvecpetsc.so.5.5.0)
> ==16192==    by 0x108AF8: main (in /home/praharsh/.local/examples/cvode/petsc/cv_petsc_ex7)
> ==16192==  Address 0xfaf8708 is 0 bytes after a block of size 392 alloc'd
> ==16192==    at 0x4C2FB0F: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==16192==    by 0x4044922: ??? (in /var/empty/local/lib/libsundials_cvode.so.5.3.0)
> ==16192==    by 0x84000001: ???
> ==16192==    by 0x4E4532E: N_VNewEmpty_Petsc (in /home/praharsh/.local/lib/libsundials_nvecpetsc.so.5.5.0)
> An alternative is to use CVODE through PETSc, meaning you would configure using --download-sundials, and
> then use the CVODE solvers from Sundials.
>   Thanks,
>     Matt
>> int main(int argc,char **argv)
>>     N_Vector           nvecx;
>>     PetscErrorCode       ierr;
>>     Vec                  x;
>>     int nr_dof = 3;
>>     PetscInitializeNoArguments();
>>     VecCreateSeq(PETSC_COMM_SELF, nr_dof, &x);
>>     VecZeroEntries(x);
>>     VecAssemblyBegin(x);
>>     VecAssemblyEnd(x);
>>     nvecx = N_VMake_Petsc(x);
>>     if (check_retval((void *)nvecx, "N_VMake_Petsc", 0)) return 1;
>>     N_VDestroy(nvecx);
>>     ierr = VecDestroy(&x);CHKERRQ(ierr);
>>     printf("Corruption is happening below\n");
>>     ierr = PetscFinalize();
>>     printf("PETSC FINALIZE\n");
>>     return ierr;
>> gives me
>> double free or corruption (out)
>> [1]    14133 abort (core dumped)  ./cv_petsc_ex7
>> I've also attached the output of valgrind --leak-check=full
>> ./my_program_executable &> valgrind_output.log
>> I'm not particularly sure why PetscFinalize is causing memory
>> corruption here. I'm using Sundials 5.5.0 and Petsc 3.14.0. I don't
>> really understand CVODE or PETSc internals or manual memory management
>> well since I'm new to all of them. Any help pinpointing the issue
>> would be appreciated.
>> Thank you!
>> Praharsh
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
