[petsc-users] PETSC with OPENMP
    Mark Adams
    mfadams at lbl.gov
    Fri Nov  6 08:08:19 CST 2020
This just sounds like a bug. Valgrind would be great and a stack trace
would be great also. (compile with -g to get source lines). If you just get
a segv then a debugger should stop there. If you are getting a PETSc error
message then put a breakpoint in PetscError.
On Fri, Nov 6, 2020 at 4:45 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Enrico,
> some more information would be helpful, like a full petsc error message.
> Also, PETSc version and configuration would be great.
> Can you run valgrind to detect where and why the code is erroring? or run
> with -on_error_attach_debugger ?
> Thanks
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201106/49b73d5e/attachment.html>
