[petsc-users] PETSC with OPENMP
Enrico
degregori at dkrz.de
Fri Nov 6 03:41:02 CST 2020
Hello,
I need to call PETSC functions within an OPENMP parallel region. The
reason is not related to PETSC itself but to parallel IO. To finalize
the parallel IO I need to launch an OPENMP task. Thus, all the PETSC
calls are in a OPENMP single region and executed by one thread while
another thread finalizes the IO.
This seems to be pretty standard even if I'm using OPENMP with PETSC but
when I try to run, the code crashes the first time I call a PETSC
function while the other thread is working on the IO.
I've installed PETSC with threadsave and openmp mode and with log and
debugging set to 0 so this should be fine.
Do you know about a branch that support this kind of issue or a way to
solve it?
Enrico
