[petsc-users] matsetvaluesblocked4_
Wed May 27 18:36:50 CDT 2020
On Wed, May 27, 2020 at 7:34 PM Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > Nvidias's NSight with 2D Q3 and bs=10. (attached).
> Thanks; this is basically the same as a CPU -- the cost is searching the
> sorted rows for the next entry.  I've long thought we should optimize
> the implementations to fast-path when the next column index in the
> sparse matrix equals the next index in the provided block.  It'd just
> take a good CPU test to demonstrate that payoff.
So you first check whether the next index is the one in the set passed in,
and otherwise
fall back on the search? Good idea.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200527/2b5d7b29/attachment.html>
