[petsc-users] Error on INTEGER SIZE using DMDACreate3d
Stefano Zampini stefano.zampini at gmail.com
Wed May 27 04:26:51 CDT 2020
You need a version of PETSc compiled with 64bit indices, since the message
indicates the number of dofs in this case is larger the INT_MAX
2501×3401×1601 = 13617947501
I also suggest you upgrade to a newer version, 3.8.3 is quite old as the
error message reports
Il giorno mer 27 mag 2020 alle ore 11:50 Pierpaolo Minelli <
pierpaolo.minelli at cnr.it> ha scritto:
> Hi,
> I am trying to solve a Poisson equation on this grid:
> Nx = 2501
> Ny = 3401
> Nz = 1601
> I received this error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Overflow in integer operation:
> http://www.mcs.anl.gov/petsc/documentation/faq.html#64-bit-indices
> [0]PETSC ERROR: Mesh of 2501 by 3401 by 1 (dof) is too large for 32 bit
> indices
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
> [0]PETSC ERROR:
> /marconi_scratch/userexternal/pminelli/PIC3D/2500_3400_1600/./PIC_3D on a
> arch-linux2-c-opt named r129c09s02 by pminelli Tu
> e May 26 20:16:34 2020
> [0]PETSC ERROR: Configure options
> --prefix=/cineca/prod/opt/libraries/petsc/3.8.3/intelmpi--2018--binary
> CC=mpiicc FC=mpiifort CXX=mpiicpc
> F77=mpiifort F90=mpiifort --with-debugging=0
> --with-blaslapack-dir=/cineca/prod/opt/compilers/intel/pe-xe-2018/binary/mkl
> --with-fortran=1
> --with-fortran-interfaces=1
> --with-cmake-dir=/cineca/prod/opt/tools/cmake/3.5.2/none
> --with-mpi-dir=/cineca/prod/opt/compilers/intel/pe-xe-
> 2018/binary/impi/2018.4.274 --download-scalapack --download-mumps=yes
> --download-hypre --download-superlu_dist --download-parmetis --downlo
> ad-metis
> [0]PETSC ERROR: #1 DMSetUp_DA_3D() line 218 in
> /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/
> impls/da/da3.c
> [0]PETSC ERROR: #2 DMSetUp_DA() line 25 in
> /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/impl
> s/da/dareg.c
> [0]PETSC ERROR: #3 DMSetUp() line 720 in
> /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/interf
> ace/dm.c
> forrtl: error (76): Abort trap signal
> I am on an HPC facility and after I loaded PETSC module, I have seen that
> it is configured with INTEGER size = 32
> I solve my problem with these options and it works perfectly with smaller
> grids:
> -dm_mat_type hypre -pc_type hypre -pc_hypre_type boomeramg
> -pc_hypre_boomeramg_relax_type_all SOR/Jacobi
> -pc_hypre_boomeramg_coarsen_type PMIS -pc_hypre_boomeramg_interp_type FF1
> -ksp_type richardson
> Is it possible to overcome this if I ask them to install a version with
> INTEGER SIZE = 64?
> Alternatively, is it possible to overcome this using intel compiler
> options?
> Thanks in advance
> Pierpaolo Minelli
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200527/651c9d59/attachment-0001.html>
