[petsc-users] error when configuring petsc with Intel Compilers 2019 update 3
Tue May 26 11:02:30 CDT 2020
On Tue, May 26, 2020 at 11:23 AM Alfredo Jaramillo <
ajaramillopalma at gmail.com> wrote:
> hello dear PETSc team,
> I'm trying to install PETSc with the 2019 update 3 Intel Parallel Studio.
> When starting the configuration process there appears the next message:
> *TESTING: checkFortran90Array from
> config.compilersFortran(/opt/petsc-3.13.0/config/BuildSystem/config/compilersFortran.py:211)*******************************************************************************
>        UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):-------------------------------------------------------------------------------Could
> not check Fortran pointer
> arguments********************************************************************************
> the configuration log is attached to this message
> I would be very thankful of any kind help on this matter
It seems like headers in /usr/include are conflicting with your new
compiler.
Executing: mpiicc -c -o
/tmp/petsc-n__j58ih/config.compilersFortran/conftest.o
-I/tmp/petsc-n__j58ih/config.libraries
-I/tmp/petsc-n__j58ih/config.setCompilers
-I/tmp/petsc-n__j58ih/config.compilers
-I/tmp/petsc-n__j58ih/config.utilities.closure
-I/tmp/petsc-n__j58ih/config.compilersFortran  -fPIC -O3 -march=native
-mtune=native  /tmp/petsc-n__j58ih/config.compilersFortran/conftest.c
Possible ERROR while running compiler: exit code 2
stderr:
In file included from /usr/include/bits/floatn.h(119),
                 from /usr/include/stdlib.h(55),
                 from
/tmp/petsc-n__j58ih/config.compilersFortran/conftest.c(4):
/usr/include/bits/floatn-common.h(214): error: invalid combination of type
specifiers
  typedef float _Float32;
                 from
/usr/include/bits/floatn-common.h(251): error: invalid combination of type
specifiers
  typedef double _Float64;
                 from
/usr/include/bits/floatn-common.h(268): error: invalid combination of type
specifiers
  typedef double _Float32x;
                 from
/usr/include/bits/floatn-common.h(285): error: invalid combination of type
specifiers
  typedef long double _Float64x;
compilation aborted for
/tmp/petsc-n__j58ih/config.compilersFortran/conftest.c (code 2)
Source:
#include "confdefs.h"
#include "conffix.h"
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
  printf("arrays [%p %p %p]\n",a1,a2,a3);
  fflush(stdout);
  return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2,
void* p3)
  if ((p1 == p3) && (p1 != p2)) {
    printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
  } else {
    printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
    exit(111);
  return;
     Matt
Alfredo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200526/0266ab2a/attachment.html>
