[petsc-users] Question about DMLocalToLocal for DM_BOUNDARY_GHOSTED conditions
Matthew Knepley
knepley at gmail.com
Fri May 22 20:03:49 CDT 2020
On Fri, May 22, 2020 at 4:34 PM Lucas Banting <bantingl at myumanitoba.ca>
wrote:
> Hello,
> I am converting a serial code to parallel in fortran with petsc. I am
> using the DMDA to manage communication of the information that used to be
> in old two-dimensional fortran arrays.
> I noticed when using DMLocalToLocalBegin/End, not all the ghost values in
> the array at the DM_BOUNDARY_GHOSTED area is updated. Is this expected
> behaviour?
I believe so. GHOSTED is user managed space. We do not touch it.
> I read through this thread:
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2016-May/029252.html
> and saw someone had a similar question, but the answer was not clear to me.
> If this is expected behaviour, how should I instead update these values in
> my arrays? I was using DM_BOUNDARY_GHOSTED as I needed the extra ghost
> cells for some subroutines, but I do not need them in my matrix from
> DMCreateMatrix.
You fill them in the local vector.
Matt
> I am using Petsc 3.12.4 and open MPI 3.1.4.
> Thanks,
> Lucas Banting
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200522/c00f5fa4/attachment.html>
