[petsc-users] Question about DMLocalToLocal when using DM_BOUNDARY_GHOSTED
Lucas Banting
bantingl at myumanitoba.ca
Fri May 22 16:11:00 CDT 2020
Hello,
I am converting a serial code to parallel in fortran with petsc. I am using the DMDA to manage communication of the information that used to be in old two-dimensional fortran arrays.
I noticed when using DMLocalToLocalBegin/End, not all the ghost values in the array at the DM_BOUNDARY_GHOSTED area is updated. Is this expected behaviour?
I read through this thread: https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2016-May/029252.html and saw someone had a similar question, but the answer was not clear to me.
If this is expected behaviour, how should I instead update these values in my arrays? I was using DM_BOUNDARY_GHOSTED as I needed the extra ghost cells for some subroutines, but I do not need them in my matrix from DMCreateMatrix.
I am using Petsc 3.12.4 and open MPI 3.1.4.
Lucas Banting
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200522/07343032/attachment.html>
