[petsc-users] Gather and Broadcast Parallel Vectors in k-means algorithm
Eda Oktay
eda.oktay at metu.edu.tr
Fri May 22 12:31:36 CDT 2020
Dear Richard,
Thank you for your email. From MATLAB's kmeans() function I believe I got
the final clustering index set, not centroids. What I am trying to do is to
cluster vectors created by MatDuplicateVecs() according to the index set
(whose type is not IS since I took it from MATLAB) that I obtained from
MATLAB. I am trying to cluster these vectors however since they are
parallel, I couldn't understand how to cluster them.
Normally, I have to be independent from MATLAB so I will try your
suggestion, grateful for that. However, because of my limited
knowledge about PETSc and parallel computing, I am not able to figure out
how to cluster parallel vectors according to an index set.
Eda
Mills, Richard Tran <rtmills at anl.gov>, 30 Nis 2020 Per, 02:07 tarihinde
şunu yazdı:
> Hi Eda,
> Thanks for your reply. I'm still trying to understand why you say you need
> to duplicate the row vectors across all processes. When I have implemented
> parallel k-means, I don't duplicate the row vectors. (This would be very
> unscalable and largely defeat the point of doing this with MPI parallelism
> in the first place.)
> Earlier in this email thread, you said that you have used Matlab to get
> cluster IDs for each row vector. Are you trying to then use this
> information to calculate the cluster centroids from inside your PETSc
> program? If so, you can do this by having each MPI rank do the following:
> For cluster i in 0 to (k-1), calculate the element-wise sum of all of the
> local rows that belong to cluster i, then use MPI_Allreduce() to calculate
> the global elementwise sum of all the local sums (this array will be
> replicated across all MPI ranks), and finally divide by the number of
> members of that cluster to get the centroid. Note that MPI_Allreduce()
> doesn't work on PETSc objects, but simple arrays, so you'll want to use
> something like MatGetValues() or MatGetRow() to access the elements of your
> row vectors.
> Let me know if I am misunderstanding what you are aiming to do, or if I am
> misunderstanding something.
> It sounds like you would benefit from having some routines in PETSc to do
> k-means (or other) clustering, by the way?
> Best regards,
> Richard
> On 4/29/20 3:47 AM, Eda Oktay wrote:
> Dear Richard,
> I am trying to use spectral clustering algorithm by using k-means
> clustering algorithm at some point. I am doing this by producing a matrix
> consisting of eigenvectors (of the adjacency matrix of the graph that I
> want to partition), then forming row vectors of this matrix. This is the
> part that I am using parallel vector. By using the output from k-means, I
> am trying to cluster these row vectors. To cluster these vectors, I think I
> need all row vectors in all processes. I wanted to use sequential vectors,
> however, I couldn't find a different way that I form row vectors of a
> matrix.
> I am trying to use VecScatterCreateToAll, however, since my vector is
> parallel crated by VecDuplicateVecs, my input is not in correct type, so I
> get error. I still can't get how can I use this function in parallel vector
> created by VecDuplicateVecs.
> Thank you all for your help.
> Eda
> Mills, Richard Tran <rtmills at anl.gov>, 7 Nis 2020 Sal, 01:51 tarihinde
> şunu yazdı:
>> Hi Eda,
>> I think that you probably want to use VecScatter routines, as Junchao
>> has suggested, instead of the lower level star forest for this. I
>> believe that VecScatterCreateToZero() is what you want for the broadcast
>> problem you describe, in the second part of your question. I'm not sure
>> what you are trying to do in the first part. Taking a parallel vector
>> and then copying its entire contents to a sequential vector residing on
>> each process is not scalable, and a lot of the design that has gone into
>> PETSc is to prevent the user from ever needing to do things like that.
>> Can you please tell us what you intend to do with these sequential
>> vectors?
>> I'm also wondering why, later in your message, you say that you get
>> cluster assignments from Matlab, and then "to cluster row vectors
>> according to this information, all processors need to have all of the
>> row vectors". Do you mean you want to get all of the row vectors copied
>> onto all of the processors so that you can compute the cluster
>> centroids? If so, computing the cluster centroids can be done without
>> copying the row vectors onto all processors if you use a communication
>> operation like MPI_Allreduce().
>> Lastly, let me add that I've done a fair amount of work implementing
>> clustering algorithms on distributed memory parallel machines, but
>> outside of PETSc. I was thinking that I should implement some of these
>> routines using PETSc. I can't get to this immediately, but I'm wondering
>> if you might care to tell me a bit more about the clustering problems
>> you need to solve and how having some support for this in PETSc might
>> (or might not) help.
>> Best regards,
>> Richard
>> On 4/4/20 1:39 AM, Eda Oktay wrote:
>> > Hi all,
>> > I created a parallel vector UV, by using VecDuplicateVecs since I need
>> > row vectors of a matrix. However, I need the whole vector be in all
>> > processors, which means I need to gather all and broadcast them to all
>> > processors. To gather, I tried to use VecStrideGatherAll:
>> > Vec UVG;
>> > VecStrideGatherAll(UV,UVG,INSERT_VALUES);
>> > VecView(UVG,PETSC_VIEWER_STDOUT_WORLD);
>> > however when I try to view the vector, I get the following error.
>> > [3]PETSC ERROR: Invalid argument
>> > [3]PETSC ERROR: Wrong type of object: Parameter # 1
>> > [3]PETSC ERROR: See
>> > http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> > [3]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
>> > [3]PETSC ERROR: ./clustering_son_final_edgecut_without_parmetis on a
>> > arch-linux2-c-debug named localhost.localdomain by edaoktay Sat Apr 4
>> > 11:22:54 2020
>> > [0]PETSC ERROR: See
>> shooting.
>> > [0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
>> > [0]PETSC ERROR: ./clustering_son_final_edgecut_without_parmetis on a
>> > 11:22:54 2020
>> > [0]PETSC ERROR: Configure options --download-mpich --download-openblas
>> > --download-slepc --download-metis --download-parmetis --download-chaco
>> > --with-X=1
>> > [0]PETSC ERROR: #1 VecStrideGatherAll() line 646 in
>> > /home/edaoktay/petsc-3.11.1/src/vec/vec/utils/vinv.c
>> > 11:22:54 2020
>> > [1]PETSC ERROR: Configure options --download-mpich --download-openblas
>> > --with-X=1
>> > [1]PETSC ERROR: #1 VecStrideGatherAll() line 646 in
>> > --with-X=1
>> > [3]PETSC ERROR: #1 VecStrideGatherAll() line 646 in
>> > I couldn't understand why I am getting this error. Is this because of
>> > UV being created by VecDuplicateVecs? How can I solve this problem?
>> > The other question is broadcasting. After gathering all elements of
>> > the vector UV, I need to broadcast them to all processors. I found
>> > PetscSFBcastBegin. However, I couldn't understand the PetscSF concept
>> > properly. I couldn't adjust my question to the star forest concept.
>> > My problem is: If I have 4 processors, I create a matrix whose columns
>> > are 4 smallest eigenvectors, say of size 72. Then by defining each row
>> > of this matrix as a vector, I cluster them by using k-means
>> > clustering algorithm. For now, I cluster them by using MATLAB and I
>> > obtain a vector showing which row vector is in which cluster. After
>> > getting this vector, to cluster row vectors according to this
>> > information, all processors need to have all of the row vectors.
>> > According to this problem, how can I use the star forest concept?
>> > I will be glad if you can help me about this problem since I don't
>> > have enough knowledge about graph theory. An if you have any idea
>> > about how can I use k-means algorithm in a more practical way, please
>> > let me know.
>> > Thanks!
>> > Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200522/6075991d/attachment.html>
