[petsc-users] Jacobian test by finite difference
zakaryah . zakaryah at gmail.com
Wed May 20 13:48:42 CDT 2020
I think I figured it out. It seems that only the hand-coded Jacobian is
displayed in natural ordering, while the finite difference (and hand-coded
minus finite difference) are displayed in global ordering. I guess the
finite difference Jacobian doesn't inherit the natural ordering from the
DM. Thanks for your help!
On Tue, May 19, 2020 at 5:06 PM Zhang, Hong <hongzhang at anl.gov> wrote:
> On May 19, 2020, at 2:51 PM, zakaryah . <zakaryah at gmail.com> wrote:
> I'd like to have one more pass at debugging it myself first. I think Matt
> is probably right about the ordering. I need to make sure I understand the
> ordering used in VecView. If I use DMCreateGlobalVector to create the
> vector for the residual, calculate the residual, then call VecView on the
> residual vector, how do I ensure that the output is in natural ordering?
> The output is in natural ordering by default. You can use
> PETSC_VIEWER_NATIVE to make output printed in PETSc ordering and have a
> comparison.
> PetscViewerPushFormat(PETSC_VIEWER_STDOUT_WORLD,PETSC_VIEWER_NATIVE);
> VecView(your_global_vector,PETSC_VIEWER_STDOUT_WORLD);
> PetscViewerPopFormat(PETSC_VIEWER_STDOUT_WORLD);
> Hong (Mr.)
> On Tue, May 19, 2020 at 1:17 PM Zhang, Hong <hongzhang at anl.gov> wrote:
>> Can you post your code (at least some essential snippets) for the
>> residual evaluation and the Jacobian evaluation?
>> Hong (Mr.)
>> On May 19, 2020, at 11:08 AM, zakaryah . <zakaryah at gmail.com> wrote:
>> Thanks Matt. I should have said that the boundary is set to
>>> BOUNDARY_NONE. I am not sure what you mean about the ordering. I understand
>>> that the actual indexing, internal to PETSc, does not match the natural
>>> ordering, as explained in the manual. But, doesn't MatView always use the
>>> natural ordering? Also, my hand-coded Jacobian routine uses
>>> MatSetValuesStencil, and the corresponding output from
>>> snes_test_jacobian_display exactly matches what I expect to see - correct
>>> layout of nonzero terms according to natural ordering. It is only the
>>> finite difference Jacobian that contains the unexpected, off-stencil terms.
>> This is weird. I run the Jacobian test manually, by adding a small
>> perturbation to the configuration vector at each index and calculating the
>> function for the perturbed configuration, then the result looks like it
>> should. This makes me think there is not a problem with my routine for
>> calculating the function, but I can't explain why the Jacobian test by
>> finite difference that PETSc calculates would be different, and have
>> non-zero values outside the stencil.
>> On Tue, May 19, 2020 at 10:13 AM zakaryah . <zakaryah at gmail.com> wrote:
>>> On Tue, May 19, 2020, 5:56 AM Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Tue, May 19, 2020 at 1:57 AM zakaryah . <zakaryah at gmail.com> wrote:
>>>>> Hi all,
>>>>> I'm debugging some convergence issues and I came across something
>>>>> strange. I am using a nonlinear solver on a structured grid. The DMDA is 3
>>>>> dimensional, with 3 dof, and a box stencil of width 1. There are some small
>>>>> errors in the hand-coded Jacobian, which I am trying to sort out, but at
>>>>> least the fill pattern of the matrix is correct.
>>>>> However, when I run with -snes_test_jacobian
>>>>> -snes_test_jacobian_display -snes_compare_explicit, I see something very
>>>>> strange. The finite difference Jacobian has large terms outside the
>>>>> stencil. For example, for x,y,z,c = 0,0,0,0 (row 0), the columns 6, 7, 8,
>>>>> 12, 13, and 14 (column 6 => x=2,y=0,z=0,c=0, etc.) have large values, while
>>>>> columns 9 through 20 are calculated but equal to zero. The "correct"
>>>>> values, i.e., in the stencil, are calculated as well, and nearly agree with
>>>>> my hand-coded Jacobian. This issue does NOT occur in serial, but occurs for
>>>>> any number of processors greater than 1.
>>>>> I have checked the indexing by hand, carefully, and the memory access
>>>>> with valgrind, and the results were clean. Does anyone have an idea why the
>>>>> finite difference calculation of the Jacobian would produce large values
>>>>> outside the stencil? I am using PETSc 3.12.2 and openMPI 3.1.0. Thanks for
>>>>> your help.
>>>> Since it only appears in parallel, I am guessing that your calculation
>>>> of global ordering does not take into account that we locally
>>>> reorder, rather than using lexicographic ordering, and you might have
>>>> periodic boundary conditions.
>>>>   Thanks,
>>>>      Matt
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200520/e2d69ae3/attachment.html>
