[petsc-users] Jacobian test by finite difference
Matthew Knepley
knepley at gmail.com
Tue May 19 04:55:51 CDT 2020
On Tue, May 19, 2020 at 1:57 AM zakaryah . <zakaryah at gmail.com> wrote:
> Hi all,
> I'm debugging some convergence issues and I came across something strange.
> I am using a nonlinear solver on a structured grid. The DMDA is 3
> dimensional, with 3 dof, and a box stencil of width 1. There are some small
> errors in the hand-coded Jacobian, which I am trying to sort out, but at
> least the fill pattern of the matrix is correct.
> However, when I run with -snes_test_jacobian -snes_test_jacobian_display
> -snes_compare_explicit, I see something very strange. The finite difference
> Jacobian has large terms outside the stencil. For example, for x,y,z,c =
> 0,0,0,0 (row 0), the columns 6, 7, 8, 12, 13, and 14 (column 6 =>
> x=2,y=0,z=0,c=0, etc.) have large values, while columns 9 through 20 are
> calculated but equal to zero. The "correct" values, i.e., in the stencil,
> are calculated as well, and nearly agree with my hand-coded Jacobian. This
> issue does NOT occur in serial, but occurs for any number of processors
> greater than 1.
> I have checked the indexing by hand, carefully, and the memory access with
> valgrind, and the results were clean. Does anyone have an idea why the
> finite difference calculation of the Jacobian would produce large values
> outside the stencil? I am using PETSc 3.12.2 and openMPI 3.1.0. Thanks for
> your help.
Since it only appears in parallel, I am guessing that your calculation of
global ordering does not take into account that we locally
reorder, rather than using lexicographic ordering, and you might have
periodic boundary conditions.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200519/e7cb645e/attachment.html>
