[petsc-users] make check failed with intel 2019 compilers
Alexander Lindsay
alexlindsay239 at gmail.com
Tue May 12 15:44:22 CDT 2020
Ok, this is good to know. Yea we'll probably just roll back then. Thanks!
On Tue, May 12, 2020 at 12:45 PM Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 12 May 2020, Matthew Knepley wrote:
> > On Tue, May 12, 2020 at 3:13 PM Alexander Lindsay <
> alexlindsay239 at gmail.com>
> > wrote:
> > > The parallel make check target (ex19) fails with the error below after
> > > configuring/building with intel 2019 mpi compilers
> > > (mpiicc,mpiicpc,mpiifort). Any attempt to run valgrind or to attach to
> a
> > > debugger fails with `mpiexec: Error: unknown option "-pmi_args"`. I've
> > > attached configure.log. Does anyone have any ideas off the top of their
> > > head? We're trying to link MOOSE with a project that refuses to use a
> > > toolchain other than intel's. I'm currently trying to figure out
> whether
> > > the MPI implementation matters (e.g. can I use mpich/openmpi), but for
> now
> > > I'm operating under the assumption that I need to use the intel MPI
> > > implementation.
> > There have been a _lot_ of bugs in the 2019 MPI for some reason. Is it at
> > all possible to rollback?
> > If not, is this somewhere we can run?
> We have this compiler/mpi [19u3] on our KNL box. I've had weird issues
> with it - so we still use 18u2 on it.
> Satish
> > Thanks,
> > Matt
> > > lindad at lemhi2
> :/scratch/lindad/moose/petsc/src/snes/examples/tutorials((detached
> > > from 7c25e2d))$ mpiexec -np 2 ./ex19
> > > lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
> > > [0]PETSC ERROR:
> > > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > > probably memory access out of range
> > > [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > > [0]PETSC ERROR: or see
> > > https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > > [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS
> > > X to find memory corruption errors
> > > [0]PETSC ERROR: likely location of problem given in stack below
> > > [0]PETSC ERROR: --------------------- Stack Frames
> > > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> > > available,
> > > [0]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > > [0]PETSC ERROR: is given.
> > > [0]PETSC ERROR: [0] MPIPetsc_Type_unwrap line 38
> > > /scratch/lindad/moose/petsc/src/vec/is/sf/interface/sftype.c
> > > [0]PETSC ERROR: [1]PETSC ERROR:
> > > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > > [1]PETSC ERROR: Try option -start_in_debugger or
> > > [1]PETSC ERROR: or see
> > > [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS
> > > [1]PETSC ERROR: likely location of problem given in stack below
> > > [1]PETSC ERROR: --------------------- Stack Frames
> > > [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> > > available,
> > > [1]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > > [1]PETSC ERROR: is given.
> > > [1]PETSC ERROR: [1] MPIPetsc_Type_unwrap line 38
> > > [1]PETSC ERROR: [0] MPIPetsc_Type_compare line 71
> > > [0]PETSC ERROR: [0] PetscSFPackGetInUse line 514
> > > /scratch/lindad/moose/petsc/src/vec/is/sf/impls/basic/sfpack.c
> > > [0]PETSC ERROR: [0] PetscSFBcastAndOpEnd_Basic line 305
> > > /scratch/lindad/moose/petsc/src/vec/is/sf/impls/basic/sfbasic.c
> > > [0]PETSC ERROR: [0] PetscSFBcastAndOpEnd line 1335
> > > /scratch/lindad/moose/petsc/src/vec/is/sf/interface/sf.c
> > > [0]PETSC ERROR: [0] VecScatterEnd_SF line 83
> > > /scratch/lindad/moose/petsc/src/vec/vscat/impls/sf/vscatsf.c
> > > [0]PETSC ERROR: [1] MPIPetsc_Type_compare line 71
> > > [1]PETSC ERROR: [1] PetscSFPackGetInUse line 514
> > > [0] VecScatterEnd line 145
> > > /scratch/lindad/moose/petsc/src/vec/vscat/interface/vscatfce.c
> > > [0]PETSC ERROR: [0] DMGlobalToLocalEnd_DA line 25
> > > /scratch/lindad/moose/petsc/src/dm/impls/da/dagtol.c
> > > [0]PETSC ERROR: [1]PETSC ERROR: [1] PetscSFBcastAndOpEnd_Basic line 305
> > > [1]PETSC ERROR: [1] PetscSFBcastAndOpEnd line 1335
> > > [0] DMGlobalToLocalEnd line 2368
> > > /scratch/lindad/moose/petsc/src/dm/interface/dm.c
> > > [0]PETSC ERROR: [0] SNESComputeFunction_DMDA line 67
> > > /scratch/lindad/moose/petsc/src/snes/utils/dmdasnes.c
> > > [0]PETSC ERROR: [1]PETSC ERROR: [1] VecScatterEnd_SF line 83
> > > [0] MatFDColoringApply_AIJ line 180
> > > /scratch/lindad/moose/petsc/src/mat/impls/aij/mpi/fdmpiaij.c
> > > [0]PETSC ERROR: [0] MatFDColoringApply line 610
> > > /scratch/lindad/moose/petsc/src/mat/matfd/fdmatrix.c
> > > [0]PETSC ERROR: [1]PETSC ERROR: [1] VecScatterEnd line 145
> > > [1]PETSC ERROR: [1] DMGlobalToLocalEnd_DA line 25
> > > [0] SNESComputeJacobian_DMDA line 153
> > > [0]PETSC ERROR: [0] SNES user Jacobian function line 2678
> > > /scratch/lindad/moose/petsc/src/snes/interface/snes.c
> > > [0]PETSC ERROR: [1]PETSC ERROR: [1] DMGlobalToLocalEnd line 2368
> > > [1]PETSC ERROR: [1] SNESComputeFunction_DMDA line 67
> > > [0] SNESComputeJacobian line 2637
> > > [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
> > > /scratch/lindad/moose/petsc/src/snes/impls/ls/ls.c
> > > [0]PETSC ERROR: [1]PETSC ERROR: [1] MatFDColoringApply_AIJ line 180
> > > [1]PETSC ERROR: [1] MatFDColoringApply line 610
> > > [1]PETSC ERROR: [1] SNESComputeJacobian_DMDA line 153
> > > [1]PETSC ERROR: [0] SNESSolve line 4366
> > > [0]PETSC ERROR: [0] main line 108 ex19.c
> > > [1] SNES user Jacobian function line 2678
> > > [1]PETSC ERROR: [0]PETSC ERROR: --------------------- Error Message
> > > [1] SNESComputeJacobian line 2637
> > > [1]PETSC ERROR: [1] SNESSolve_NEWTONLS line 144
> > > [1]PETSC ERROR: [0]PETSC ERROR: Signal received
> > > [0]PETSC ERROR: See
> > > for trouble shooting.
> > > [0]PETSC ERROR: [1] SNESSolve line 4366
> > > [1]PETSC ERROR: [1] main line 108 ex19.c
> > > Petsc Release Version 3.12.4, unknown
> > > [0]PETSC ERROR: ./ex19 on a arch-moose named lemhi2 by lindad Tue May
> 12
> > > 12:54:11 2020
> > > [0]PETSC ERROR: [1]PETSC ERROR: Configure options --download-hypre=1
> > > --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=1
> > > --download-metis=1 --download-ptscotch=1 --download-parmetis=1
> > > --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1
> > > --download-slepc=git://https://gitlab.com/slepc/slepc.git
> > > --download-slepc-commit= 59ff81b --with-mpi=1 --with-cxx-dialect=C++11
> > > --with-fortran-bindings=0 --with-sowing=0 --with-cc=mpiicc
> > > --with-cxx=mpiicpc --with-fc=mpiifort --with-debugging=yes
> > > [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> > > [1]PETSC ERROR: Signal received
> > > [1]PETSC ERROR: See
> > > [1]PETSC ERROR: Petsc Release Version 3.12.4, unknown
> > > [1]PETSC ERROR: Abort(59) on node 0 (rank 0 in comm 0): application
> called
> > > MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> > > ./ex19 on a arch-moose named lemhi2 by lindad Tue May 12 12:54:11 2020
> --with-debugging=no
> > > --with-shared-libraries=1 --download-fblaslapack=1 --download-metis=1
> > > --download-ptscotch=1 --download-parmetis=1 --download-superlu_dist=1
> > > --download-mumps=1 --download-scalapack=1 --download-slepc=git://
> > > https://gitlab.com/slepc/slepc.git --download-slepc-commit= 59ff81b
> > > --with-mpi=1 --with-cxx-dialect=C++11 --with-fortran-bindings=0
> > > --with-sowing=0 --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort
> > > [1]PETSC ERROR: #1 User provided function() line 0 in unknown file
> > > [0]PETSC ERROR:
> > > [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> > > batch system) has told this process to end
> > > [0]PETSC ERROR: Abort(59) on node 1 (rank 1 in comm 0): application
> called
> > > MPI_Abort(MPI_COMM_WORLD, 59) - process 1
> > > [1]PETSC ERROR:
> > > [1]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> OS
> OS
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200512/eedb54c1/attachment-0001.html>
