[petsc-users] HDF5 viewer + groups
Hapla Vaclav vaclav.hapla at erdw.ethz.ch
Mon May 11 15:55:52 CDT 2020
On 11 May 2020, at 19:35, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Mon, May 11, 2020 at 1:29 PM Daniel R. Shapero <shapero at uw.edu<mailto:shapero at uw.edu>> wrote:
Gotcha, that all makes sense and thanks for the reply!
Is adding a namespace mechanism to HDF5 viewers worthwhile from your end? I totally understand if not and we can probably design around that from the Firedrake side, e.g. restricting to only one mesh per checkpoint file.
I don't think it's such a huge deal. We are redoing things anyway, so its just another requirement.
Yes, this is a totally reasonable requirement. We are going to change the default naming and custom naming will be definitely possible as well.
It's in my backlog but should get to that soon!
See also https://gitlab.com/petsc/petsc/-/issues/553
Vaclav
     Matt
On Mon, May 11, 2020 at 3:24 AM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Sun, May 10, 2020 at 10:03 PM Daniel R. Shapero <shapero at uw.edu<mailto:shapero at uw.edu>> wrote:
I'm trying to improve the checkpointing functionality in the Firedrake library, which currently uses the HDF5 viewer to store PetscVec objects. The problem with this approach is that a lot of context about the stored vector (e.g. the mesh and finite element space that it came from) is lost and we'd like to save that too.
In order to make a sensible hierarchy inside the file, I'd like to be able to write a DMPlex to a group, say `/meshes/<mesh_name>`, within the file rather than at the root `/`. I tried using the `PETScViewerHDF5PushGroup` function; I thought that this will change the current group of the file to whatever name you give and all subsequent dataset writes will go under that group until you call the matching pop. This doesn't seem to be the case and all of the mesh data gets written under `/`. From reading the source code, it looks like the HDF5 writer pushes the group `/topology` to write out the DMPlex cells (and likewise for coordinates etc) which then clobbers whatever I pushed before it instead of concatenating.
I've attached a minimal example using petsc4py to demonstrate. I get the same results when I use some extra functionality in Firedrake to ensure that the `/meshes` group is created in the first place, which I can then verify with h5ls.
Is there a way to do what I want and if so how? If there isn't, is that because no one has needed this before or is there a fundamental reason why you shouldn't be doing this in the first place?
The reason is the impedence mismatch with visualization formats. VTK/ExodusII/etc are all based on a single mesh and multiple vectors in a file, so I
copied that design. It would be possible to namespace everything, and fix the XDMF generator to understand that.
Vaclav, should we roll this into the HDF5 parallel reading/writing update?
     Matt
Thanks!
Daniel
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200511/5d436251/attachment-0001.html>
