[petsc-users] Resuming analysis by importing Trajectory Data from external source
Mohammed Ashour ashour.msc at gmail.com
Sat May 9 14:47:27 CDT 2020
Oh, thanks for the tip.
I can do that. Aside from the solution vector, step number, and time, are
there any hidden details in TS I need to dump that would be essential for
the next run?
Thanks in advance
Yours Sincerely
On Sat, May 9, 2020 at 9:40 PM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> You do not want to use TSTrajectory for that. The trajectory object is
> meant to be used for sensitivity analysis to store _all_ the intermediate
> time steps and the perform backward integration.
> You should code a TSMonitor that dumps every n time steps and then use the
> last one to restart the simulation.
> On May 9, 2020, at 10:30 PM, Mohammed Ashour <ashour.msc at gmail.com> wrote:
> Dear All,
> I'm using PETSc in conjunction wit PetIGA to solve a 3D phase-field
> problem on HPC cluster.
> Given the computational load of the code, I'm running it on 15 nodes with
> a multithreaded job. Now there is a wall time for the current partition set
> to 24 hours, afterward, the job will be killed.
> I have been searching for the possibility of using the Trajectory to
> resume the run after it being terminated by reloading the dumped binary
> files from TSSetSaveTrajectory once again into the TS, i.e., state vector
> and it's time derivative, timestep and time.
> I have tried using TSTrajectoryGet but I ended up with the following error:
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: TS solver did not save trajectory
> So, I would like to ask if in theory that would be possible? if so, how
> can I reload the trajectory from a previously terminated job into a new one?
> Yours Sincerely.
> *Mohammed Ashour, M.Sc.*PhD Scholar
> Bauhaus-Universität Weimar
> Institute of Structural Mechanics (ISM)
> Marienstraße 7
> 99423 Weimar, Germany
> Mobile: +(49) 176 58834667
Marienstraße 7
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200509/5d8f909c/attachment.html>
