[petsc-users] [EXTERNAL] Re: Example code of linear solve of a block matrix system in Fortran
Matthew Knepley
knepley at gmail.com
Thu May 7 13:04:02 CDT 2020
On Thu, May 7, 2020 at 1:38 PM Satish Balay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Its best to keep the discussion on the list [or petsc-maint] - as others
> would have answers to some of these qestions.
> Wrt -info - yeah this is the correct option [my mistake in suggesting
> -log_info]
> Wrt understanding performance -log_view should help
Block preconditioners tend to come down to having a good preconditioner for
the Schur complement. There is a voluminous
literature here. For example,
https://www.sciencedirect.com/science/article/pii/S0021999107004330
Matt
> Satish
> On Thu, 7 May 2020, Thomas S. Chyczewski wrote:
> > Satish,
> > Thanks for your help. Sorry for not being able to figure it out on my
> own. I had a little trouble following the discussion in the manual. I got
> the block version working now and the linear solver time is cut in half
> compared to the monolithic version for a given set of parameters. I have
> experimented with a number of solver and preconditioner options as well as
> solver convergence criteria. But I'm wondering if there are any other
> parameters I should be playing with. I ask because I also had some trouble
> following the PCFIELDSPLIT discussion in the manual and I'm wondering if
> the default is the best option for me.
> > The -log_info option isn't available in the Fortran version, so I
> couldn't check the inode information as you suggested. However, below is
> the output when I run with the -info option. I know that having no mallocs
> during MatSetValues is good, but that's about it.
> > Thanks,
> > Tom
> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS
> arl19814.(none)
> > [0] petscinitialize_internal(): (Fortran):PETSc successfully started:
> procs 1
> arl19814.(none)
> > [0] petscinitialize_internal(): Running on machine: arl19814
> > [0] PetscCommDuplicate(): Duplicating a communicator 2 2 max tags =
> 100000000
> > [0] MatAssemblyEnd_SeqBAIJ(): Matrix size: 374400 X 374400, block size
> 3; storage space: 11199240 unneeded, 5606640 used
> > [0] MatAssemblyEnd_SeqBAIJ(): Number of mallocs during MatSetValues is 0
> > [0] MatAssemblyEnd_SeqBAIJ(): Most nonzeros blocks in any row is 5
> > [0] MatCheckCompressedRow(): Found the ratio (num_zerorows
> 0)/(num_localrows 124800) < 0.6. Do not use CompressedRow routines.
> > [0] PCSetUp(): Setting up PC for first time
> > [0] PetscCommDuplicate(): Duplicating a communicator 1 3 max tags =
> 100000000
> > [0] PetscCommDuplicate(): Using internal PETSc communicator 1 3
> > [0] PCSetUp(): Leaving PC with identical preconditioner since operator
> is unchanged
> is unchanged
> is unchanged
> is unchanged
> is unchanged
> is unchanged
> is unchanged
> is unchanged
> is unchanged
> > -----Original Message-----
> > From: Satish Balay <balay at mcs.anl.gov>
> > Sent: Wednesday, May 6, 2020 4:05 PM
> > To: Thomas S. Chyczewski <tsc109 at arl.psu.edu>
> > Cc: petsc-users <petsc-users at mcs.anl.gov>
> > Subject: Re: [petsc-users] [EXTERNAL] Re: Example code of linear solve
> > You can use
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValuesBlocked.html
> > MatSetValues() will also work - but MatSetValuesBlocked() is more
> efficient wrt BAIJ
> > Satish
> > On Wed, 6 May 2020, Thomas S. Chyczewski wrote:
> > > Thanks Satish. I have seen that page and can create a block matrix.
> It's not clear to me how to fill it and use it in a Fortran code.
> > > Sent: Wednesday, May 6, 2020 3:43 PM
> > > Cc: petsc-users at mcs.anl.gov
> > > Subject: [EXTERNAL] Re: [petsc-users] Example code of linear solve of
> > > What you are looking for is:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateBAIJ.html
> > > indoe is optimization for AIJ type - where you might not have a simple
> block size like 3 that you have.
> > > BAIJ will perform better than AIJ/with-inode
> > > To verify indoe usage - you can run the code with '-log_info' option -
> and do a 'grep inode'
> > > Satish
> > > > All,
> > > > I'm relatively new to PETSc and have relied pretty heavily on the
> example codes included in the distribution to figure out the finer points
> of using the PETSc library that I couldn't deduce from the manual. One
> thing I can't figure out is how to solve block matrix systems and I
> couldn't find an example in Fortran. I'm writing a 2D incompressible CFD
> solver so I have a 3x3 block Imax*Jmax system. The closest I've come to
> finding an example is ex19.c in the snes directory, but that is in c and
> for the nonlinear solver.
> > > > I have been able to run PETSc but unwrapping the block matrix into a
> monolithic system. But the manual says "Block matrices represent an
> important class of problems in numerical linear algebra and offer the
> possibility of far more efficient iterative solvers than just treating the
> entire matrix as black box." However, in the FAQs I saw a comment that
> PETSc scans the AIJ matrices for rows that have the same column layout and
> can deduce if it's a block system and use the more efficient solvers. I
> also saw in the archives for this email list a thread where it seems
> workaround for building fields in a Fortran code is discussed ("Back to
> struct in Fortran to represent field with dof > 1"), so I'm beginning to
> suspect building a block system in Fortran might not be straight forward.
> > > > All that being said, my questions:
> > > > Is there a significant advantage to building the block system as
> opposed to the analogous monolithic system if PETSc can figure out that
> it's a block system? Can you confirm that PETSc does figure this out?
> > > > If there is an advantage to loading the matrix as a block matrix, is
> there an example Fortran code that builds and solves a linear block system?
> > > > Thanks,
> > > > Tom C
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200507/e1301ec0/attachment-0001.html>
