[petsc-users] Regarding Valgrind
MUKKUND SUNJII mukkundsunjii at gmail.com
Wed May 6 11:08:03 CDT 2020
Thank you so much for your suggestion.
I will try to install Valgrind through docker.
Mukkund
> On 5 May 2020, at 16:53, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
> Using Docker is certainly the easiest way to do this in my experience! You can install docker desktop here https://hub.docker.com/editions/community/docker-ce-desktop-mac/ <https://hub.docker.com/editions/community/docker-ce-desktop-mac/>
> Then make a docker context file (preferably in an empty directory somewhere) with the following contents:
> FROM jedbrown/mpich-ccache
> USER root
> # PACKAGE INSTALL
> RUN apt-get -y update
> RUN apt-get -y upgrade
> RUN apt-get -y install build-essential
> RUN apt-get -y install python3
> # OPTIONAL
> RUN apt-get -y install libc6-dbg
> # VALGRIND  BUILD FROM SOURCE
> WORKDIR /
> RUN git clone git://sourceware.org/git/valgrind.git <git://sourceware.org/git/valgrind.git>
> WORKDIR /valgrind
> RUN git pull
> RUN ./autogen.sh
> RUN ./configure --with-mpicc=/usr/local/bin/mpicc
> RUN make -j 5
> RUN make install
> # ENV VARIABLES
> ENV PETSC_DIR="/petsc"
> ENV PETSC_ARCH="arch-linux-c-debug”
> RUN echo 'export PATH="/usr/lib/ccache:$PATH"' >>  ~/.bashrc
> RUN "/usr/sbin/update-ccache-symlinks"
> WORKDIR /petsc
> Then simply run these commands from command line:
> docker build -t valgrinddocker:latest /PATH/TO/DOCKER/FILE
> docker run -it --rm --cpus 4 -v ${PETSC_DIR}:/petsc:delegated valgrinddocker:latest’
> This will build and launch docker image called “valgrinddocker” based on ubuntu with mpi and ccache preinstalled as well as optionally build valgrind from source. It also most importantly mounts your current ${PETSC_DIR} inside the container meaning you don’t have to reinstall PETSc inside docker. Anything you do inside the docker will also be mirrored on your “local” machine inside ${PETSC_DIR}. You will have to have a separate arch folder for running inside the image however so you will have to go through ./configure again.
> Alternatively If you don’t want to build valgrind from source and instead use apt-get to install it you may remove the commands regarding building valgrind and installing libc6-dbg.
> Hope this helps!
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
>> On May 5, 2020, at 7:46 AM, MUKKUND SUNJII <mukkundsunjii at gmail.com <mailto:mukkundsunjii at gmail.com>> wrote:
>> Greetings,
>> I have been working on modifying ex11.c by adding source terms to the existing model.
>> In the process, I had introduced some memory corruption errors. The modifications are fairly large, hence it is difficult to single out the problem.
>> In the FAQ page, I saw that we can use the flag -malloc_debug and/or CHKMEMQ statements. However, they don’t seem to help my case.
>> At this point of time, Valgrind is not supported by MAC OS X as I have the newer version of the OS. Any suggestions on how to figure out the source of the problem?
>> Regards,
>> Mukkund
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200506/a7a76c26/attachment.html>
