[petsc-users] Performance of SLEPc's Krylov-Schur solver
Matthew Knepley
knepley at gmail.com
Mon May 4 05:24:27 CDT 2020
On Mon, May 4, 2020 at 6:12 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > El 4 may 2020, a las 12:06, Matthew Knepley <knepley at gmail.com>
> escribió:
> > On Mon, May 4, 2020 at 3:51 AM Walker Andreas <awalker at student.ethz.ch>
> wrote:
> > Hey everyone,
> > I wanted to give you a short update on this:
> > - As suggested by Matt, I played around with the distribution of my
> cores over nodes and changed to using one core per node only.
> > - After experimenting with a monolithic matrix instead of a MATNEST
> object, I observed that the monolithic showed better speedup and changed to
> building my problem matrix as monolithic matrix.
> > - I keep the subspace for the solver small which slightly improves the
> runtimes
> > After these changes, I get near-perfect scaling with speedups above 56
> for 64 cores (1 core/node) for example. Unfortunately I can’t really tell
> which of the above changes contributed how much to this improvement.
> > Anyway, thanks everyone for your help!
> > Great! I am glad its scaling well.
> > 1) You should be able to up the number of cores per node as large as you
> want, as long as you evaluate the scaling in terms of nodes., meaning use
> that as the baseline.
> > 2) You can see how many cores per node are used efficiently by running
> 'make streams'.
> > 3) We would be really interested in seeing the logs from runs where
> MATNEST scales worse than AIJ. Maybe we could fix that.
> Matt, this last issue is due to SLEPc, I am preparing a fix.
Thanks! I am interested to see it.
Matt
> > Thanks,
> > Matt
> > Best regards and stay healthy
> > Andreas
> >> Am 01.05.2020 um 14:45 schrieb Matthew Knepley <knepley at gmail.com>:
> >> On Fri, May 1, 2020 at 8:32 AM Walker Andreas <awalker at student.ethz.ch>
> wrote:
> >> Hi Jed, Hi Jose,
> >> Thank you very much for your suggestions.
> >> - I tried reducing the subspace to 64 which indeed reduced the runtime
> by around 20 percent (sometimes more) for 128 cores. I will check what the
> effect on the sequential runtime is.
> >> - Regarding MatNest, I can just look for the eigenvalues of a
> submatrix to see how the speedup is affected; I will check that. Replacing
> the full matnest with a contiguous matrix is definitely more work but, if
> it improves the performance, worth the work (we assume that the program
> will be reused a lot).
> >> - Petsc is configured with mumps, openblas, scalapack (among others).
> But I noticed no significant difference to when petsc is configured without
> them.
> >> - The number of iterations required by the solver does not depend on
> the number of cores.
> >> Best regards and many thanks,
> >> Let me just address something from a high level. These operations are
> not compute limited (for the most part), but limited by
> >> bandwidth. Bandwidth is allocated by node, not by core, on these
> machines. That is why it important to understand how many
> >> nodes you are using, not cores. A useful scaling test would be to fill
> up a single node (however many cores fit on one node), and
> >> then increase the # of nodes. We would expect close to linear scaling
> in that case.
> >> Thanks,
> >> Matt
> >> Andreas Walker
> >> > Am 01.05.2020 um 14:12 schrieb Jed Brown <jed at jedbrown.org>:
> >> > "Jose E. Roman" <jroman at dsic.upv.es> writes:
> >> >> Comments related to PETSc:
> >> >> - If you look at the "Reduct" column you will see that MatMult() is
> doing a lot of global reductions, which is bad for scaling. This is due to
> MATNEST (other Mat types do not do that). I don't know the details of
> MATNEST, maybe Matt can comment on this.
> >> > It is not intrinsic to MatNest, though use of MatNest incurs extra
> >> > VecScatter costs. If you use MatNest without VecNest, then
> >> > VecGetSubVector incurs significant cost (including reductions). I
> >> > suspect it's likely that some SLEPc functionality is not available
> with
> >> > VecNest. A better option would be to optimize VecGetSubVector by
> >> > caching the IS and subvector, at least in the contiguous case.
> >> > How difficult would it be for you to run with a monolithic matrix
> >> > instead of MatNest? It would certainly be better at amortizing
> >> > communication costs.
> >> >> Comments related to SLEPc.
> >> >> - The last rows (DSSolve, DSVectors, DSOther) correspond to
> "sequential" computations. In your case they take a non-negligible time
> (around 30 seconds). You can try to reduce this time by reducing the size
> of the projected problem, e.g. running with -eps_nev 100 -eps_mpd 64 (see
> https://slepc.upv.es/documentation/current/docs/manualpages/EPS/EPSSetDimensions.html
> >> >> - In my previous comment about multithreaded BLAS, I was refering to
> configuring PETSc with MKL, OpenBLAS or similar. But anyway, I don't think
> this is relevant here.
> >> >> - Regarding the number of iterations, yes the number of iterations
> should be the same for different runs if you keep the same number of
> processes, but when you change the number of processes there might be
> significant differences for some problems, that is the rationale of my
> suggestion. Anyway, in your case the fluctuation does not seem very
> important.
> >> >> Jose
> >> >>> El 1 may 2020, a las 10:07, Walker Andreas <awalker at student.ethz.ch>
> escribió:
> >> >>> Hi Matthew,
> >> >>> I just ran the same program on a single core. You can see the
> output of -log_view below. As I see it, most functions have speedups of
> around 50 for 128 cores, also functions like matmult etc.
> >> >>> Best regards,
> >> >>> Andreas
> >> >>> *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript
> -r -fCourier9' to print this document ***
> >> >>> ---------------------------------------------- PETSc Performance
> Summary: ----------------------------------------------
> >> >>> ./Solver on a named eu-a6-011-09 with 1 processor, by awalker Fri
> May 1 04:03:07 2020
> >> >>> Using Petsc Release Version 3.10.5, Mar, 28, 2019
> >> >>> Max Max/Min Avg Total
> >> >>> Time (sec): 3.092e+04 1.000 3.092e+04
> >> >>> Objects: 6.099e+05 1.000 6.099e+05
> >> >>> Flop: 9.313e+13 1.000 9.313e+13 9.313e+13
> >> >>> Flop/sec: 3.012e+09 1.000 3.012e+09 3.012e+09
> >> >>> MPI Messages: 0.000e+00 0.000 0.000e+00 0.000e+00
> >> >>> MPI Message Lengths: 0.000e+00 0.000 0.000e+00 0.000e+00
> >> >>> MPI Reductions: 0.000e+00 0.000
> >> >>> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> >> >>> e.g., VecAXPY() for real vectors of
> length N --> 2N flop
> >> >>> and VecAXPY() for complex vectors of
> length N --> 8N flop
> >> >>> Summary of Stages: ----- Time ------ ----- Flop ------ ---
> Messages --- -- Message Lengths -- -- Reductions --
> >> >>> Avg %Total Avg %Total Count
> %Total Avg %Total Count %Total
> >> >>> 0: Main Stage: 3.0925e+04 100.0% 9.3134e+13 100.0%
> 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
> >> >>> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> >> >>> Phase summary info:
> >> >>> Count: number of times phase was executed
> >> >>> Time and Flop: Max - maximum over all processors
> >> >>> Ratio - ratio of maximum to minimum over all
> processors
> >> >>> Mess: number of messages sent
> >> >>> AvgLen: average message length (bytes)
> >> >>> Reduct: number of global reductions
> >> >>> Global: entire computation
> >> >>> Stage: stages of a computation. Set stages with
> PetscLogStagePush() and PetscLogStagePop().
> >> >>> %T - percent time in this phase %F - percent flop in
> this phase
> >> >>> %M - percent messages in this phase %L - percent message
> lengths in this phase
> >> >>> %R - percent reductions in this phase
> >> >>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max
> time over all processors)
> >> >>> Event Count Time (sec) Flop
> --- Global --- --- Stage ---- Total
> >> >>> Max Ratio Max Ratio Max Ratio Mess
> AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> >> >>> --- Event Stage 0: Main Stage
> >> >>> MatMult 152338 1.0 8.2799e+03 1.0 8.20e+12 1.0 0.0e+00
> 0.0e+00 0.0e+00 27 9 0 0 0 27 9 0 0 0 990
> >> >>> MatMultAdd 609352 1.0 8.1229e+03 1.0 8.20e+12 1.0 0.0e+00
> 0.0e+00 0.0e+00 26 9 0 0 0 26 9 0 0 0 1010
> >> >>> MatConvert 30 1.0 1.5797e+00 1.0 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>> MatScale 10 1.0 4.7172e-02 1.0 6.73e+07 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1426
> >> >>> MatAssemblyBegin 516 1.0 2.0695e-04 1.0 0.00e+00 0.0 0.0e+00
> >> >>> MatAssemblyEnd 516 1.0 2.8933e+00 1.0 0.00e+00 0.0 0.0e+00
> >> >>> MatZeroEntries 2 1.0 3.6038e-02 1.0 0.00e+00 0.0 0.0e+00
> >> >>> MatView 10 1.0 2.4422e+00 1.0 0.00e+00 0.0 0.0e+00
> >> >>> MatAXPY 40 1.0 3.1595e-01 1.0 0.00e+00 0.0 0.0e+00
> >> >>> MatMatMult 60 1.0 1.3723e+01 1.0 1.24e+09 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 90
> >> >>> MatMatMultSym 100 1.0 1.3651e+01 1.0 0.00e+00 0.0 0.0e+00
> >> >>> MatMatMultNum 100 1.0 7.5159e+00 1.0 2.06e+09 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 274
> >> >>> MatMatMatMult 40 1.0 1.8674e+01 1.0 1.66e+09 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 89
> >> >>> MatMatMatMultSym 40 1.0 1.1848e+01 1.0 0.00e+00 0.0 0.0e+00
> >> >>> MatMatMatMultNum 40 1.0 6.8266e+00 1.0 1.66e+09 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 243
> >> >>> MatPtAP 40 1.0 1.9042e+01 1.0 1.66e+09 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 87
> >> >>> MatTrnMatMult 40 1.0 7.7990e+00 1.0 8.24e+08 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 106
> >> >>> DMPlexStratify 1 1.0 5.1223e-02 1.0 0.00e+00 0.0 0.0e+00
> >> >>> DMPlexPrealloc 2 1.0 1.5242e+00 1.0 0.00e+00 0.0 0.0e+00
> >> >>> VecSet 914053 1.0 1.4929e+02 1.0 0.00e+00 0.0 0.0e+00
> >> >>> VecAssemblyBegin 1 1.0 1.3411e-07 1.0 0.00e+00 0.0 0.0e+00
> >> >>> VecAssemblyEnd 1 1.0 8.0094e-08 1.0 0.00e+00 0.0 0.0e+00
> >> >>> VecScatterBegin 1 1.0 2.6399e-04 1.0 0.00e+00 0.0 0.0e+00
> >> >>> VecSetRandom 10 1.0 8.6088e-02 1.0 0.00e+00 0.0 0.0e+00
> >> >>> EPSSetUp 10 1.0 2.9988e+00 1.0 0.00e+00 0.0 0.0e+00
> >> >>> EPSSolve 10 1.0 2.8695e+04 1.0 9.31e+13 1.0 0.0e+00
> 0.0e+00 0.0e+00 93100 0 0 0 93100 0 0 0 3246
> >> >>> STSetUp 10 1.0 9.7291e-05 1.0 0.00e+00 0.0 0.0e+00
> >> >>> STApply 152338 1.0 8.2803e+03 1.0 8.20e+12 1.0 0.0e+00
> >> >>> BVCopy 1814 1.0 1.1076e+00 1.0 0.00e+00 0.0 0.0e+00
> >> >>> BVMultVec 304639 1.0 9.8281e+03 1.0 3.34e+13 1.0 0.0e+00
> 0.0e+00 0.0e+00 32 36 0 0 0 32 36 0 0 0 3397
> >> >>> BVMultInPlace 1824 1.0 7.0999e+02 1.0 1.79e+13 1.0 0.0e+00
> 0.0e+00 0.0e+00 2 19 0 0 0 2 19 0 0 0 25213
> >> >>> BVDotVec 304639 1.0 9.8037e+03 1.0 3.36e+13 1.0 0.0e+00
> 0.0e+00 0.0e+00 32 36 0 0 0 32 36 0 0 0 3427
> >> >>> BVOrthogonalizeV 152348 1.0 1.9633e+04 1.0 6.70e+13 1.0 0.0e+00
> 0.0e+00 0.0e+00 63 72 0 0 0 63 72 0 0 0 3411
> >> >>> BVScale 152348 1.0 3.7888e+01 1.0 5.32e+10 1.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1403
> >> >>> BVSetRandom 10 1.0 8.6364e-02 1.0 0.00e+00 0.0 0.0e+00
> >> >>> DSSolve 1824 1.0 1.7363e+01 1.0 0.00e+00 0.0 0.0e+00
> >> >>> DSVectors 2797 1.0 1.2353e-01 1.0 0.00e+00 0.0 0.0e+00
> >> >>> DSOther 1824 1.0 9.8627e+00 1.0 0.00e+00 0.0 0.0e+00
> >> >>> Memory usage is given in bytes:
> >> >>> Object Type Creations Destructions Memory
> Descendants' Mem.
> >> >>> Reports information only for process 0.
> >> >>> Container 1 1 584 0.
> >> >>> Distributed Mesh 1 1 5184 0.
> >> >>> GraphPartitioner 1 1 624 0.
> >> >>> Matrix 320 320 3469402576 0.
> >> >>> Index Set 53 53 2777932 0.
> >> >>> IS L to G Mapping 1 1 249320 0.
> >> >>> Section 13 11 7920 0.
> >> >>> Star Forest Graph 6 6 4896 0.
> >> >>> Discrete System 1 1 936 0.
> >> >>> Vector 609405 609405 857220847896 0.
> >> >>> Vec Scatter 1 1 704 0.
> >> >>> Viewer 22 11 9328 0.
> >> >>> EPS Solver 10 10 86360 0.
> >> >>> Spectral Transform 10 10 8400 0.
> >> >>> Basis Vectors 10 10 530336 0.
> >> >>> PetscRandom 10 10 6540 0.
> >> >>> Region 10 10 6800 0.
> >> >>> Direct Solver 10 10 9838880 0.
> >> >>> Krylov Solver 10 10 13920 0.
> >> >>> Preconditioner 10 10 10080 0.
> >> >>> Average time to get PetscTime(): 2.50991e-08
> >> >>> #PETSc Option Table entries:
> >> >>> -config=benchmark3.json
> >> >>> -eps_converged_reason
> >> >>> -log_view
> >> >>> #End of PETSc Option Table entries
> >> >>> Compiled without FORTRAN kernels
> >> >>> Compiled with full precision matrices (default)
> >> >>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> >> >>> Configure options:
> --prefix=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit
> --with-ssl=0 --download-c2html=0 --download-sowing=0 --download-hwloc=0
> CFLAGS="-ftree-vectorize -O2 -march=core-avx2 -fPIC -mavx2" FFLAGS=
> CXXFLAGS="-ftree-vectorize -O2 -march=core-avx2 -fPIC -mavx2"
> --with-cc=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpicc
> --with-cxx=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpic++
> --with-fc=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpif90
> --with-precision=double --with-scalar-type=real --with-shared-libraries=1
> --with-debugging=0 --with-64-bit-indices=0 COPTFLAGS= FOPTFLAGS=
> CXXOPTFLAGS=
> --with-blaslapack-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openblas-0.2.20-cot3cawsqf4pkxjwzjexaykbwn2ch3ii/lib/libopenblas.so
> --with-x=0 --with-cxx-dialect=C++11 --with-boost=1 --with-clanguage=C
> --with-scalapack-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/netlib-scalapack-2.0.2-bq6sqixlc4zwxpfrtbu7jt7twhps5ldv/lib/libscalapack.so
> --with-scalapack=1 --with-metis=1
> --with-metis-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk
> --with-hdf5=1
> --with-hdf5-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5
> --with-hypre=1
> --with-hypre-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne
> --with-parmetis=1
> --with-parmetis-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4
> --with-mumps=1
> --with-mumps-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b
> --with-trilinos=1
> --with-trilinos-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo
> --with-fftw=0 --with-cxx-dialect=C++11
> --with-superlu_dist-include=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/include
> --with-superlu_dist-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/lib/libsuperlu_dist.a
> --with-superlu_dist=1
> --with-suitesparse-include=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/include
> --with-suitesparse-lib="/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libumfpack.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libklu.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libcholmod.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libbtf.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libccolamd.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libcolamd.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libcamd.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libamd.so
> /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libsuitesparseconfig.so
> /lib64/librt.so" --with-suitesparse=1
> --with-zlib-include=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/include
> --with-zlib-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/lib/libz.so
> --with-zlib=1
> >> >>> Libraries compiled on 2020-01-22 15:21:53 on eu-c7-051-02
> >> >>> Machine characteristics:
> Linux-3.10.0-862.14.4.el7.x86_64-x86_64-with-centos-7.5.1804-Core
> >> >>> Using PETSc directory:
> >> >>> Using PETSc arch:
> >> >>> Using C compiler:
> >> >>> Using Fortran compiler:
> >> >>> Using include paths:
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk/include
> -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/include
> >> >>> Using C linker:
> >> >>> Using Fortran linker:
> >> >>> Using libraries:
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit/lib
> -lpetsc
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/netlib-scalapack-2.0.2-bq6sqixlc4zwxpfrtbu7jt7twhps5ldv/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/netlib-scalapack-2.0.2-bq6sqixlc4zwxpfrtbu7jt7twhps5ldv/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib
> /lib64/librt.so
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openblas-0.2.20-cot3cawsqf4pkxjwzjexaykbwn2ch3ii/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openblas-0.2.20-cot3cawsqf4pkxjwzjexaykbwn2ch3ii/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hwloc-1.11.9-a436y6rdahnn57u6oe6snwemjhcfmrso/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hwloc-1.11.9-a436y6rdahnn57u6oe6snwemjhcfmrso/lib
> -Wl,-rpath,/cluster/apps/lsf/10.1/linux2.6-glibc2.3-x86_64/lib
> -L/cluster/apps/lsf/10.1/linux2.6-glibc2.3-x86_64/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/lib
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/lib
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib:/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib64
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib/gcc/x86_64-pc-linux-gnu/6.3.0
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib/gcc/x86_64-pc-linux-gnu/6.3.0
> -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib64
> -L/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib64
> -lmuelu-adapters -lmuelu-interface -lmuelu -lstratimikos -lstratimikosbelos
> -lstratimikosaztecoo -lstratimikosamesos -lstratimikosml
> -lstratimikosifpack -lModeLaplace -lanasaziepetra -lanasazi -lmapvarlib
> -lsuplib_cpp -lsuplib_c -lsuplib -lsupes -laprepro_lib -lchaco
> -lio_info_lib -lIonit -lIotr -lIohb -lIogs -lIogn -lIovs -lIopg -lIoexo_fac
> -lIopx -lIofx -lIoex -lIoss -lnemesis -lexoIIv2for32 -lexodus_for -lexodus
> -lmapvarlib -lsuplib_cpp -lsuplib_c -lsuplib -lsupes -laprepro_lib -lchaco
> -lbelosxpetra -lbelosepetra -lbelos -lml -lifpack -lpamgen_extras -lpamgen
> -lamesos -lgaleri-xpetra -lgaleri-epetra -laztecoo -lisorropia -lxpetra-sup
> -lxpetra -lthyraepetraext -lthyraepetra -lthyracore -lthyraepetraext
> -lthyraepetra -lthyracore -lepetraext -ltrilinosss -ltriutils -lzoltan
> -lepetra -lsacado -lrtop -lkokkoskernels -lteuchoskokkoscomm
> -lteuchoskokkoscompat -lteuchosremainder -lteuchosnumerics -lteuchoscomm
> -lteuchosparameterlist -lteuchosparser -lteuchoscore -lteuchoskokkoscomm
> -lteuchosparameterlist -lteuchosparser -lteuchoscore -lkokkosalgorithms
> -lkokkoscontainers -lkokkoscore -lkokkosalgorithms -lkokkoscontainers
> -lkokkoscore -lgtest -lpthread -lcmumps -ldmumps -lsmumps -lzmumps
> -lmumps_common -lpord -lscalapack -lumfpack -lklu -lcholmod -lbtf -lccolamd
> -lcolamd -lcamd -lamd -lsuitesparseconfig -lsuperlu_dist -lHYPRE -lopenblas
> -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lparmetis -lmetis -lm -lz
> -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi
> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
> >> >>>> Am 30.04.2020 um 17:14 schrieb Matthew Knepley <knepley at gmail.com
> >> >>>> On Thu, Apr 30, 2020 at 10:55 AM Walker Andreas <
> awalker at student.ethz.ch> wrote:
> >> >>>> Hello everyone,
> >> >>>> I have used SLEPc successfully on a FEM-related project. Even
> though it is very powerful overall, the speedup I measure is a bit below my
> expectations. Compared to using a single core, the speedup is for example
> around 1.8 for two cores but only maybe 50-60 for 128 cores and maybe 70 or
> 80 for 256 cores. Some details about my problem:
> >> >>>> - The problem is based on meshes with up to 400k degrees of
> freedom. DMPlex is used for organizing it.
> >> >>>> - ParMetis is used to partition the mesh. This yields a stiffness
> matrix where the vast majority of entries is in the diagonal blocks (i.e.
> looking at the rows owned by a core, there is a very dense square-shaped
> region around the diagonal and some loosely scattered nozeroes in the other
> columns).
> >> >>>> - The actual matrix from which I need eigenvalues is a 2x2 block
> matrix, saved as MATNEST - matrix. Each of these four matrices is computed
> based on the stiffness matrix and has a similar size and nonzero pattern.
> For a mesh of 200k dofs, one such matrix has a size of about 174kx174k and
> on average about 40 nonzeroes per row.
> >> >>>> - I use the default Krylov-Schur solver and look for the 100
> smallest eigenvalues
> >> >>>> - The output of -log_view for the 200k-dof - mesh described above
> run on 128 cores is at the end of this mail.
> >> >>>> I noticed that the problem matrices are not perfectly balanced,
> i.e. the number of rows per core might vary between 2500 and 3000, for
> example. But I am not sure if this is the main reason for the poor speedup.
> >> >>>> I tried to reduce the subspace size but without effect. I also
> attempted to use the shift-and-invert spectral transformation but the
> MATNEST-type prevents this.
> >> >>>> Are there any suggestions to improve the speedup further or is
> this the maximum speedup that I can expect?
> >> >>>> Can you also give us the performance for this problem on one node
> using the same number of cores per node? Then we can calculate speedup
> >> >>>> and look at which functions are not speeding up.
> >> >>>> Thanks,
> >> >>>> Matt
> >> >>>> Thanks a lot in advance,
> >> >>>> Andreas Walker
> >> >>>> m&m group
> >> >>>> D-MAVT
> >> >>>> ETH Zurich
> 'enscript -r -fCourier9' to print this document ***
> >> >>>> ./Solver on a named eu-g1-050-2 with 128 processors, by awalker
> Thu Apr 30 15:50:22 2020
> >> >>>> Time (sec): 6.209e+02 1.000 6.209e+02
> >> >>>> Objects: 6.068e+05 1.001 6.063e+05
> >> >>>> Flop: 9.230e+11 1.816 7.212e+11 9.231e+13
> >> >>>> Flop/sec: 1.487e+09 1.816 1.161e+09 1.487e+11
> >> >>>> MPI Messages: 1.451e+07 2.999 8.265e+06 1.058e+09
> >> >>>> MPI Message Lengths: 6.062e+09 2.011 5.029e+02 5.321e+11
> >> >>>> MPI Reductions: 1.512e+06 1.000
> >> >>>> 0: Main Stage: 6.2090e+02 100.0% 9.2309e+13 100.0%
> 1.058e+09 100.0% 5.029e+02 100.0% 1.512e+06 100.0%
> >> >>>> Phase summary info:
> processors
> this phase
> >> >>>> BuildTwoSided 20 1.0 2.3249e-01 2.2 0.00e+00 0.0 2.2e+04
> 4.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> BuildTwoSidedF 317 1.0 8.5016e-01 4.8 0.00e+00 0.0 2.1e+04
> 1.4e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> MatMult 150986 1.0 2.1963e+02 1.3 8.07e+10 1.8 1.1e+09
> 5.0e+02 1.2e+06 31 9100100 80 31 9100100 80 37007
> >> >>>> MatMultAdd 603944 1.0 1.6209e+02 1.4 8.07e+10 1.8 1.1e+09
> 5.0e+02 0.0e+00 23 9100100 0 23 9100100 0 50145
> >> >>>> MatConvert 30 1.0 1.6488e-02 2.2 0.00e+00 0.0 0.0e+00
> >> >>>> MatScale 10 1.0 1.0347e-03 3.9 6.68e+05 1.8 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 65036
> >> >>>> MatAssemblyBegin 916 1.0 8.6715e-01 1.4 0.00e+00 0.0 2.1e+04
> >> >>>> MatAssemblyEnd 916 1.0 2.0682e-01 1.1 0.00e+00 0.0 4.7e+05
> 1.3e+02 1.5e+03 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> MatZeroEntries 42 1.0 7.2787e-03 2.0 0.00e+00 0.0 0.0e+00
> >> >>>> MatView 10 1.0 1.4816e+00 1.0 0.00e+00 0.0 6.4e+03
> 1.3e+05 3.0e+01 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> MatAXPY 40 1.0 1.0752e-02 1.9 0.00e+00 0.0 0.0e+00
> >> >>>> MatTranspose 80 1.0 3.0198e-03 1.4 0.00e+00 0.0 0.0e+00
> >> >>>> MatMatMult 60 1.0 3.0391e-01 1.0 7.82e+06 1.6 3.8e+05
> 2.8e+02 7.8e+02 0 0 0 0 0 0 0 0 0 0 2711
> >> >>>> MatMatMultSym 60 1.0 2.4238e-01 1.0 0.00e+00 0.0 3.3e+05
> 2.4e+02 7.2e+02 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> MatMatMultNum 60 1.0 5.8508e-02 1.0 7.82e+06 1.6 4.7e+04
> 5.7e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 14084
> >> >>>> MatPtAP 40 1.0 4.5617e-01 1.0 1.59e+07 1.6 3.3e+05
> 1.0e+03 6.4e+02 0 0 0 0 0 0 0 0 0 0 3649
> >> >>>> MatPtAPSymbolic 40 1.0 2.6002e-01 1.0 0.00e+00 0.0 1.7e+05
> 6.5e+02 2.8e+02 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> MatPtAPNumeric 40 1.0 1.9293e-01 1.0 1.59e+07 1.6 1.5e+05
> 1.5e+03 3.2e+02 0 0 0 0 0 0 0 0 0 0 8629
> >> >>>> MatTrnMatMult 40 1.0 2.3801e-01 1.0 6.09e+06 1.8 1.8e+05
> 1.0e+03 6.4e+02 0 0 0 0 0 0 0 0 0 0 2442
> >> >>>> MatTrnMatMultSym 40 1.0 1.6962e-01 1.0 0.00e+00 0.0 1.7e+05
> 4.4e+02 6.4e+02 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> MatTrnMatMultNum 40 1.0 6.9000e-02 1.0 6.09e+06 1.8 9.7e+03
> 1.1e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 8425
> >> >>>> MatGetLocalMat 240 1.0 4.9149e-02 1.6 0.00e+00 0.0 0.0e+00
> >> >>>> MatGetBrAoCol 160 1.0 2.0470e-02 1.6 0.00e+00 0.0 3.3e+05
> 4.1e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> MatTranspose_SeqAIJ_FAST 80 1.0 2.9940e-03 1.4 0.00e+00 0.0
> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> Mesh Partition 1 1.0 1.4825e+00 1.0 0.00e+00 0.0 9.8e+04
> 6.9e+01 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> Mesh Migration 1 1.0 3.6680e-02 1.0 0.00e+00 0.0 1.5e+03
> 1.4e+04 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> DMPlexDistribute 1 1.0 1.5269e+00 1.0 0.00e+00 0.0 1.0e+05
> 3.5e+02 1.2e+01 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> DMPlexDistCones 1 1.0 1.8845e-02 1.2 0.00e+00 0.0 1.0e+03
> 1.7e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> DMPlexDistLabels 1 1.0 9.7280e-04 1.2 0.00e+00 0.0 0.0e+00
> 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> DMPlexDistData 1 1.0 3.1499e-01 1.4 0.00e+00 0.0 9.8e+04
> 4.3e+01 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> DMPlexStratify 2 1.0 9.3421e-02 1.8 0.00e+00 0.0 0.0e+00
> 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> DMPlexPrealloc 2 1.0 3.5980e-02 1.0 0.00e+00 0.0 4.0e+04
> 1.8e+03 3.0e+01 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> SFSetGraph 20 1.0 1.6069e-05 2.0 0.00e+00 0.0 0.0e+00
> >> >>>> SFSetUp 20 1.0 2.8043e-01 1.9 0.00e+00 0.0 6.7e+04
> 5.0e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> SFBcastBegin 25 1.0 3.9653e-02 2.5 0.00e+00 0.0 6.1e+04
> 4.9e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> SFBcastEnd 25 1.0 9.0128e-02 1.6 0.00e+00 0.0 0.0e+00
> >> >>>> SFReduceBegin 10 1.0 4.3473e-04 5.5 0.00e+00 0.0 7.4e+03
> 4.0e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> SFReduceEnd 10 1.0 5.7962e-03 1.3 0.00e+00 0.0 0.0e+00
> >> >>>> SFFetchOpBegin 2 1.0 1.6069e-0434.7 0.00e+00 0.0 1.8e+03
> 4.4e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> SFFetchOpEnd 2 1.0 8.9251e-04 2.6 0.00e+00 0.0 1.8e+03
> >> >>>> VecSet 302179 1.0 1.3128e+00 2.3 0.00e+00 0.0 0.0e+00
> >> >>>> VecAssemblyBegin 1 1.0 1.3844e-03 7.3 0.00e+00 0.0 0.0e+00
> >> >>>> VecAssemblyEnd 1 1.0 3.4710e-05 4.1 0.00e+00 0.0 0.0e+00
> >> >>>> VecScatterBegin 603945 1.0 2.2874e+01 4.4 0.00e+00 0.0 1.1e+09
> 5.0e+02 1.0e+00 2 0100100 0 2 0100100 0 0
> >> >>>> VecScatterEnd 603944 1.0 8.2651e+01 4.5 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00 7 0 0 0 0 7 0 0 0 0 0
> >> >>>> VecSetRandom 11 1.0 2.7061e-03 3.1 0.00e+00 0.0 0.0e+00
> >> >>>> EPSSetUp 10 1.0 5.0371e-02 1.1 0.00e+00 0.0 0.0e+00
> 0.0e+00 4.0e+01 0 0 0 0 0 0 0 0 0 0 0
> >> >>>> EPSSolve 10 1.0 6.1329e+02 1.0 9.23e+11 1.8 1.1e+09
> 5.0e+02 1.5e+06 99100100100100 99100100100100 150509
> >> >>>> STSetUp 10 1.0 2.5475e-04 2.9 0.00e+00 0.0 0.0e+00
> >> >>>> STApply 150986 1.0 2.1997e+02 1.3 8.07e+10 1.8 1.1e+09
> 5.0e+02 1.2e+06 31 9100100 80 31 9100100 80 36950
> >> >>>> BVCopy 1791 1.0 5.1953e-03 1.5 0.00e+00 0.0 0.0e+00
> >> >>>> BVMultVec 301925 1.0 1.5007e+02 3.1 3.31e+11 1.8 0.0e+00
> 0.0e+00 0.0e+00 14 36 0 0 0 14 36 0 0 0 220292
> >> >>>> BVMultInPlace 1801 1.0 8.0080e+00 1.8 1.78e+11 1.8 0.0e+00
> 0.0e+00 0.0e+00 1 19 0 0 0 1 19 0 0 0 2222543
> >> >>>> BVDotVec 301925 1.0 3.2807e+02 1.4 3.33e+11 1.8 0.0e+00
> 0.0e+00 3.0e+05 47 36 0 0 20 47 36 0 0 20 101409
> >> >>>> BVOrthogonalizeV 150996 1.0 4.0292e+02 1.1 6.64e+11 1.8 0.0e+00
> 0.0e+00 3.0e+05 62 72 0 0 20 62 72 0 0 20 164619
> >> >>>> BVScale 150996 1.0 4.1660e-01 3.2 5.27e+08 1.8 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 126494
> >> >>>> BVSetRandom 10 1.0 2.5061e-03 2.9 0.00e+00 0.0 0.0e+00
> >> >>>> DSSolve 1801 1.0 2.0764e+01 1.1 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
> >> >>>> DSVectors 2779 1.0 1.2691e-01 1.1 0.00e+00 0.0 0.0e+00
> >> >>>> DSOther 1801 1.0 1.2944e+01 1.0 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
> Descendants' Mem.
> >> >>>> Distributed Mesh 6 6 29160 0.
> >> >>>> GraphPartitioner 2 2 1244 0.
> >> >>>> Matrix 1104 1104 136615232 0.
> >> >>>> Index Set 930 930 9125912 0.
> >> >>>> IS L to G Mapping 3 3 2235608 0.
> >> >>>> Section 28 26 18720 0.
> >> >>>> Star Forest Graph 30 30 25632 0.
> >> >>>> Discrete System 6 6 5616 0.
> >> >>>> PetscRandom 11 11 7194 0.
> >> >>>> Vector 604372 604372 8204816368 0.
> >> >>>> Vec Scatter 203 203 272192 0.
> >> >>>> Viewer 21 10 8480 0.
> >> >>>> Basis Vectors 10 10 530848 0.
> >> >>>> Average time to get PetscTime(): 3.49944e-08
> >> >>>> Average time for MPI_Barrier(): 5.842e-06
> >> >>>> Average time for zero size MPI_Send(): 8.72551e-06
> >> >>>> -log_view
> >> >>>> Configure options:
> CXXOPTFLAGS=
> --with-hdf5=1
> --with-hypre=1
> --with-parmetis=1
> --with-mumps=1
> --with-trilinos=1
> --with-zlib=1
> >> >>>> Using PETSc arch:
> >> >>>> Using C compiler:
> >> >>>> Using C linker:
> >> >>>> Using libraries:
> -lpetsc
> /lib64/librt.so
> >> >>>> What most experimenters take for granted before they begin their
> experiments lead.
> >> >>>> -- Norbert Wiener
> >> >>>> https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> >> -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200504/94cb8f9a/attachment-0001.html>
