[petsc-users] PCBJACOBI behaves weirdly
Zhuo Chen chenzhuotj at gmail.com
Sat May 2 23:33:11 CDT 2020
Dear Petsc users,
My name is Zhuo Chen. I am very new to Petsc.
I have encountered a very weird problem. I try to use Petsc to solve a 2D
diffusion problem (https://en.wikipedia.org/wiki/Heat_equation). When I use
PCLU, the solution looks very good. Then, I change to PCJACOBI because I
plan to use MPI in the future. If I treat the whole matrix as a single
block and set the preconditioner of the "sub-matrix" with PCLU, the
solution is exactly the same as the PCLU setting. However, if I increase
the number of blocks, the result becomes worse. I attached the solution of
a 2D diffusion simulation I have done. The red dots are the analytic
solution and the blue circles are the solution from Petsc with 8 blocks.
The size of the computational domain is 300*8. The result with PCLU only is
very close to the analytic solution so I do not include it here.
Then I implemented the same problem with Matlab
with x=gmres(mat,rhs,10,tol,maxit,p), where mat is the same as the one in
my Petsc code, and p is the block Jacobi matrix (8 blocks). The result from
Matlab is very good, though it is slow. I attach the Matlab result to this
email as well.
I would like to paste a part of my Petsc code here as well.
179     call KSPSetOperators(ksp,A,A,ierr);CHKERRQ(ierr)
180     call KSPGetPC(ksp,pc,ierr);CHKERRQ(ierr)
181     tol=1d-6
182     call
KSPSetTolerances(ksp,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr);CHKERRQ(ierr)
183     call PCSetType(pc,PCBJACOBI,ierr);CHKERRQ(ierr)
184     nblks=8
185     allocate(blks(nblks))
186     blks=Ntot/nblks
187     call PCBJacobiSetTotalBlocks(pc,nblks,blks,ierr);CHKERRQ(ierr)
188     deallocate(blks)
189     call KSPsetup(ksp,ierr)
190     call PCBJacobiGetSubKSP(pc,nlocal,first,PETSC_NULL_KSP,ierr)
191     allocate(subksp(nlocal))
192     call PCBJacobiGetSubKSP(pc,nlocal,first,subksp,ierr)
193     do i=0,nlocal-1
194         call KSPGetPC(subksp(i+1),subpc,ierr)
195         call PCSetType(subpc,PCLU,ierr); CHKERRA(ierr)
196         call KSPSetType(subksp(i+1),KSPGMRES,ierr); CHKERRA(ierr)
197         tol=1d-6
198         call
KSPSetTolerances(subksp(i+1),tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr);CHKERRQ(ierr)
199     end do
200     deallocate(subksp)
It would be great if anyone can help me with this issue. Many thanks!
Zhuo Chen
Department of Physics
University of Alberta
Edmonton Alberta, Canada T6G 2E1
http://www.pas.rochester.edu/~zchen25/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200502/1439099d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200502/1439099d/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200502/1439099d/attachment-0003.png>
