[petsc-users] Performance of SLEPc's Krylov-Schur solver
Jed Brown
jed at jedbrown.org
Fri May 1 07:12:58 CDT 2020
"Jose E. Roman" <jroman at dsic.upv.es> writes:
> Comments related to PETSc:
> - If you look at the "Reduct" column you will see that MatMult() is doing a lot of global reductions, which is bad for scaling. This is due to MATNEST (other Mat types do not do that). I don't know the details of MATNEST, maybe Matt can comment on this.
It is not intrinsic to MatNest, though use of MatNest incurs extra
VecScatter costs. If you use MatNest without VecNest, then
VecGetSubVector incurs significant cost (including reductions). I
suspect it's likely that some SLEPc functionality is not available with
VecNest. A better option would be to optimize VecGetSubVector by
caching the IS and subvector, at least in the contiguous case.
How difficult would it be for you to run with a monolithic matrix
instead of MatNest? It would certainly be better at amortizing
communication costs.
> Comments related to SLEPc.
> - The last rows (DSSolve, DSVectors, DSOther) correspond to "sequential" computations. In your case they take a non-negligible time (around 30 seconds). You can try to reduce this time by reducing the size of the projected problem, e.g. running with -eps_nev 100 -eps_mpd 64 (see https://slepc.upv.es/documentation/current/docs/manualpages/EPS/EPSSetDimensions.html )
> - In my previous comment about multithreaded BLAS, I was refering to configuring PETSc with MKL, OpenBLAS or similar. But anyway, I don't think this is relevant here.
> - Regarding the number of iterations, yes the number of iterations should be the same for different runs if you keep the same number of processes, but when you change the number of processes there might be significant differences for some problems, that is the rationale of my suggestion. Anyway, in your case the fluctuation does not seem very important.
> Jose
>> El 1 may 2020, a las 10:07, Walker Andreas <awalker at student.ethz.ch> escribió:
>> Hi Matthew,
>> I just ran the same program on a single core. You can see the output of -log_view below. As I see it, most functions have speedups of around 50 for 128 cores, also functions like matmult etc.
>> Best regards,
>> Andreas
>> *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
>> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
>> ./Solver on a named eu-a6-011-09 with 1 processor, by awalker Fri May 1 04:03:07 2020
>> Using Petsc Release Version 3.10.5, Mar, 28, 2019
>> Max Max/Min Avg Total
>> Time (sec): 3.092e+04 1.000 3.092e+04
>> Objects: 6.099e+05 1.000 6.099e+05
>> Flop: 9.313e+13 1.000 9.313e+13 9.313e+13
>> Flop/sec: 3.012e+09 1.000 3.012e+09 3.012e+09
>> MPI Messages: 0.000e+00 0.000 0.000e+00 0.000e+00
>> MPI Message Lengths: 0.000e+00 0.000 0.000e+00 0.000e+00
>> MPI Reductions: 0.000e+00 0.000
>> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>> e.g., VecAXPY() for real vectors of length N --> 2N flop
>> and VecAXPY() for complex vectors of length N --> 8N flop
>> Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
>> Avg %Total Avg %Total Count %Total Avg %Total Count %Total
>> 0: Main Stage: 3.0925e+04 100.0% 9.3134e+13 100.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
>> See the 'Profiling' chapter of the users' manual for details on interpreting output.
>> Phase summary info:
>> Count: number of times phase was executed
>> Time and Flop: Max - maximum over all processors
>> Ratio - ratio of maximum to minimum over all processors
>> Mess: number of messages sent
>> AvgLen: average message length (bytes)
>> Reduct: number of global reductions
>> Global: entire computation
>> Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>> %T - percent time in this phase %F - percent flop in this phase
>> %M - percent messages in this phase %L - percent message lengths in this phase
>> %R - percent reductions in this phase
>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
>> Event Count Time (sec) Flop --- Global --- --- Stage ---- Total
>> Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> MatMult 152338 1.0 8.2799e+03 1.0 8.20e+12 1.0 0.0e+00 0.0e+00 0.0e+00 27 9 0 0 0 27 9 0 0 0 990
>> MatMultAdd 609352 1.0 8.1229e+03 1.0 8.20e+12 1.0 0.0e+00 0.0e+00 0.0e+00 26 9 0 0 0 26 9 0 0 0 1010
>> MatConvert 30 1.0 1.5797e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatScale 10 1.0 4.7172e-02 1.0 6.73e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1426
>> MatAssemblyBegin 516 1.0 2.0695e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatAssemblyEnd 516 1.0 2.8933e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatZeroEntries 2 1.0 3.6038e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatView 10 1.0 2.4422e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatAXPY 40 1.0 3.1595e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatMatMult 60 1.0 1.3723e+01 1.0 1.24e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 90
>> MatMatMultSym 100 1.0 1.3651e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatMatMultNum 100 1.0 7.5159e+00 1.0 2.06e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 274
>> MatMatMatMult 40 1.0 1.8674e+01 1.0 1.66e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 89
>> MatMatMatMultSym 40 1.0 1.1848e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatMatMatMultNum 40 1.0 6.8266e+00 1.0 1.66e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 243
>> MatPtAP 40 1.0 1.9042e+01 1.0 1.66e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 87
>> MatTrnMatMult 40 1.0 7.7990e+00 1.0 8.24e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 106
>> DMPlexStratify 1 1.0 5.1223e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DMPlexPrealloc 2 1.0 1.5242e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecSet 914053 1.0 1.4929e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecAssemblyBegin 1 1.0 1.3411e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecAssemblyEnd 1 1.0 8.0094e-08 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecScatterBegin 1 1.0 2.6399e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecSetRandom 10 1.0 8.6088e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> EPSSetUp 10 1.0 2.9988e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> EPSSolve 10 1.0 2.8695e+04 1.0 9.31e+13 1.0 0.0e+00 0.0e+00 0.0e+00 93100 0 0 0 93100 0 0 0 3246
>> STSetUp 10 1.0 9.7291e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> STApply 152338 1.0 8.2803e+03 1.0 8.20e+12 1.0 0.0e+00 0.0e+00 0.0e+00 27 9 0 0 0 27 9 0 0 0 990
>> BVCopy 1814 1.0 1.1076e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> BVMultVec 304639 1.0 9.8281e+03 1.0 3.34e+13 1.0 0.0e+00 0.0e+00 0.0e+00 32 36 0 0 0 32 36 0 0 0 3397
>> BVMultInPlace 1824 1.0 7.0999e+02 1.0 1.79e+13 1.0 0.0e+00 0.0e+00 0.0e+00 2 19 0 0 0 2 19 0 0 0 25213
>> BVDotVec 304639 1.0 9.8037e+03 1.0 3.36e+13 1.0 0.0e+00 0.0e+00 0.0e+00 32 36 0 0 0 32 36 0 0 0 3427
>> BVOrthogonalizeV 152348 1.0 1.9633e+04 1.0 6.70e+13 1.0 0.0e+00 0.0e+00 0.0e+00 63 72 0 0 0 63 72 0 0 0 3411
>> BVScale 152348 1.0 3.7888e+01 1.0 5.32e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1403
>> BVSetRandom 10 1.0 8.6364e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DSSolve 1824 1.0 1.7363e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DSVectors 2797 1.0 1.2353e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DSOther 1824 1.0 9.8627e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> Memory usage is given in bytes:
>> Object Type Creations Destructions Memory Descendants' Mem.
>> Reports information only for process 0.
>> Container 1 1 584 0.
>> Distributed Mesh 1 1 5184 0.
>> GraphPartitioner 1 1 624 0.
>> Matrix 320 320 3469402576 0.
>> Index Set 53 53 2777932 0.
>> IS L to G Mapping 1 1 249320 0.
>> Section 13 11 7920 0.
>> Star Forest Graph 6 6 4896 0.
>> Discrete System 1 1 936 0.
>> Vector 609405 609405 857220847896 0.
>> Vec Scatter 1 1 704 0.
>> Viewer 22 11 9328 0.
>> EPS Solver 10 10 86360 0.
>> Spectral Transform 10 10 8400 0.
>> Basis Vectors 10 10 530336 0.
>> PetscRandom 10 10 6540 0.
>> Region 10 10 6800 0.
>> Direct Solver 10 10 9838880 0.
>> Krylov Solver 10 10 13920 0.
>> Preconditioner 10 10 10080 0.
>> Average time to get PetscTime(): 2.50991e-08
>> #PETSc Option Table entries:
>> -config=benchmark3.json
>> -eps_converged_reason
>> -log_view
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> Configure options: --prefix=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit --with-ssl=0 --download-c2html=0 --download-sowing=0 --download-hwloc=0 CFLAGS="-ftree-vectorize -O2 -march=core-avx2 -fPIC -mavx2" FFLAGS= CXXFLAGS="-ftree-vectorize -O2 -march=core-avx2 -fPIC -mavx2" --with-cc=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpicc --with-cxx=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpic++ --with-fc=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpif90 --with-precision=double --with-scalar-type=real --with-shared-libraries=1 --with-debugging=0 --with-64-bit-indices=0 COPTFLAGS= FOPTFLAGS= CXXOPTFLAGS= --with-blaslapack-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openblas-0.2.20-cot3cawsqf4pkxjwzjexaykbwn2ch3ii/lib/libopenblas.so --with-x=0 --with-cxx-dialect=C++11 --with-boost=1 --with-clanguage=C --with-scalapack-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/netlib-scalapack-2.0.2-bq6sqixlc4zwxpfrtbu7jt7twhps5ldv/lib/libscalapack.so --with-scalapack=1 --with-metis=1 --with-metis-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk --with-hdf5=1 --with-hdf5-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5 --with-hypre=1 --with-hypre-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne --with-parmetis=1 --with-parmetis-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4 --with-mumps=1 --with-mumps-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b --with-trilinos=1 --with-trilinos-dir=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo --with-fftw=0 --with-cxx-dialect=C++11 --with-superlu_dist-include=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/include --with-superlu_dist-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/lib/libsuperlu_dist.a --with-superlu_dist=1 --with-suitesparse-include=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/include --with-suitesparse-lib="/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libumfpack.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libklu.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libcholmod.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libbtf.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libccolamd.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libcolamd.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libcamd.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libamd.so /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib/libsuitesparseconfig.so /lib64/librt.so" --with-suitesparse=1 --with-zlib-include=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/include --with-zlib-lib=/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/lib/libz.so --with-zlib=1
>> Libraries compiled on 2020-01-22 15:21:53 on eu-c7-051-02
>> Machine characteristics: Linux-3.10.0-862.14.4.el7.x86_64-x86_64-with-centos-7.5.1804-Core
>> Using PETSc directory: /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit
>> Using PETSc arch:
>> Using C compiler: /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpicc -ftree-vectorize -O2 -march=core-avx2 -fPIC -mavx2
>> Using Fortran compiler: /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpif90
>> Using include paths: -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk/include -I/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/include
>> Using C linker: /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpicc
>> Using Fortran linker: /cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/bin/mpif90
>> Using libraries: -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/petsc-3.10.5-3czpbqhprn65yalty4o46knmhytixlit/lib -lpetsc -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/trilinos-12.14.1-hcdtxkqirqt6wkui3vkie5qse64payqo/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/mumps-5.1.1-36fzslrywwsg7gxnoxbjbzwuz6o74n6b/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/netlib-scalapack-2.0.2-bq6sqixlc4zwxpfrtbu7jt7twhps5ldv/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/netlib-scalapack-2.0.2-bq6sqixlc4zwxpfrtbu7jt7twhps5ldv/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/suite-sparse-5.1.0-sk4v2rs7dfpese3zgsyigwtv2w66v2gz/lib /lib64/librt.so -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/superlu-dist-6.1.1-ejpmx43wk4vplnmry5n5njvgqvcvfe6x/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hypre-2.14.0-ly5dmcaty5wx4opqwspvoim6zss6sxne/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openblas-0.2.20-cot3cawsqf4pkxjwzjexaykbwn2ch3ii/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openblas-0.2.20-cot3cawsqf4pkxjwzjexaykbwn2ch3ii/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hdf5-1.10.1-sbxt5qlg2pojshva2b6kdflsy64i4rs5/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/parmetis-4.0.3-ik3r6faxeb6uzyywppuc2niuvivwiux4/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/metis-5.1.0-bqbfmcvyqigdaeetkg6fuhdh4eplu3fk/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/zlib-1.2.11-bu2rglshnlxrwc24334r76jr34jm2fxy/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hwloc-1.11.9-a436y6rdahnn57u6oe6snwemjhcfmrso/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/hwloc-1.11.9-a436y6rdahnn57u6oe6snwemjhcfmrso/lib -Wl,-rpath,/cluster/apps/lsf/10.1/linux2.6-glibc2.3-x86_64/lib -L/cluster/apps/lsf/10.1/linux2.6-glibc2.3-x86_64/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-6.3.0/openmpi-3.0.1-k6n5k3l3baqlkdw3w7il7dwb6wilr6r6/lib -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib:/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib64 -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib/gcc/x86_64-pc-linux-gnu/6.3.0 -L/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib/gcc/x86_64-pc-linux-gnu/6.3.0 -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib64 -L/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib64 -Wl,-rpath,/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib -L/cluster/spack/apps/linux-centos7-x86_64/gcc-4.8.5/gcc-6.3.0-sqhtfh32p5gerbkvi5hih7cfvcpmewvj/lib -lmuelu-adapters -lmuelu-interface -lmuelu -lstratimikos -lstratimikosbelos -lstratimikosaztecoo -lstratimikosamesos -lstratimikosml -lstratimikosifpack -lModeLaplace -lanasaziepetra -lanasazi -lmapvarlib -lsuplib_cpp -lsuplib_c -lsuplib -lsupes -laprepro_lib -lchaco -lio_info_lib -lIonit -lIotr -lIohb -lIogs -lIogn -lIovs -lIopg -lIoexo_fac -lIopx -lIofx -lIoex -lIoss -lnemesis -lexoIIv2for32 -lexodus_for -lexodus -lmapvarlib -lsuplib_cpp -lsuplib_c -lsuplib -lsupes -laprepro_lib -lchaco -lio_info_lib -lIonit -lIotr -lIohb -lIogs -lIogn -lIovs -lIopg -lIoexo_fac -lIopx -lIofx -lIoex -lIoss -lnemesis -lexoIIv2for32 -lexodus_for -lexodus -lbelosxpetra -lbelosepetra -lbelos -lml -lifpack -lpamgen_extras -lpamgen -lamesos -lgaleri-xpetra -lgaleri-epetra -laztecoo -lisorropia -lxpetra-sup -lxpetra -lthyraepetraext -lthyraepetra -lthyracore -lthyraepetraext -lthyraepetra -lthyracore -lepetraext -ltrilinosss -ltriutils -lzoltan -lepetra -lsacado -lrtop -lkokkoskernels -lteuchoskokkoscomm -lteuchoskokkoscompat -lteuchosremainder -lteuchosnumerics -lteuchoscomm -lteuchosparameterlist -lteuchosparser -lteuchoscore -lteuchoskokkoscomm -lteuchoskokkoscompat -lteuchosremainder -lteuchosnumerics -lteuchoscomm -lteuchosparameterlist -lteuchosparser -lteuchoscore -lkokkosalgorithms -lkokkoscontainers -lkokkoscore -lkokkosalgorithms -lkokkoscontainers -lkokkoscore -lgtest -lpthread -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lsuperlu_dist -lHYPRE -lopenblas -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lparmetis -lmetis -lm -lz -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
>>> Am 30.04.2020 um 17:14 schrieb Matthew Knepley <knepley at gmail.com>:
>>> On Thu, Apr 30, 2020 at 10:55 AM Walker Andreas <awalker at student.ethz.ch> wrote:
>>> Hello everyone,
>>> I have used SLEPc successfully on a FEM-related project. Even though it is very powerful overall, the speedup I measure is a bit below my expectations. Compared to using a single core, the speedup is for example around 1.8 for two cores but only maybe 50-60 for 128 cores and maybe 70 or 80 for 256 cores. Some details about my problem:
>>> - The problem is based on meshes with up to 400k degrees of freedom. DMPlex is used for organizing it.
>>> - ParMetis is used to partition the mesh. This yields a stiffness matrix where the vast majority of entries is in the diagonal blocks (i.e. looking at the rows owned by a core, there is a very dense square-shaped region around the diagonal and some loosely scattered nozeroes in the other columns).
>>> - The actual matrix from which I need eigenvalues is a 2x2 block matrix, saved as MATNEST - matrix. Each of these four matrices is computed based on the stiffness matrix and has a similar size and nonzero pattern. For a mesh of 200k dofs, one such matrix has a size of about 174kx174k and on average about 40 nonzeroes per row.
>>> - I use the default Krylov-Schur solver and look for the 100 smallest eigenvalues
>>> - The output of -log_view for the 200k-dof - mesh described above run on 128 cores is at the end of this mail.
>>> I noticed that the problem matrices are not perfectly balanced, i.e. the number of rows per core might vary between 2500 and 3000, for example. But I am not sure if this is the main reason for the poor speedup.
>>> I tried to reduce the subspace size but without effect. I also attempted to use the shift-and-invert spectral transformation but the MATNEST-type prevents this.
>>> Are there any suggestions to improve the speedup further or is this the maximum speedup that I can expect?
>>> Can you also give us the performance for this problem on one node using the same number of cores per node? Then we can calculate speedup
>>> and look at which functions are not speeding up.
>>> Thanks,
>>> Matt
>>> Thanks a lot in advance,
>>> Andreas Walker
>>> m&m group
>>> D-MAVT
>>> ETH Zurich
>>> ./Solver on a named eu-g1-050-2 with 128 processors, by awalker Thu Apr 30 15:50:22 2020
>>> Time (sec): 6.209e+02 1.000 6.209e+02
>>> Objects: 6.068e+05 1.001 6.063e+05
>>> Flop: 9.230e+11 1.816 7.212e+11 9.231e+13
>>> Flop/sec: 1.487e+09 1.816 1.161e+09 1.487e+11
>>> MPI Messages: 1.451e+07 2.999 8.265e+06 1.058e+09
>>> MPI Message Lengths: 6.062e+09 2.011 5.029e+02 5.321e+11
>>> MPI Reductions: 1.512e+06 1.000
>>> 0: Main Stage: 6.2090e+02 100.0% 9.2309e+13 100.0% 1.058e+09 100.0% 5.029e+02 100.0% 1.512e+06 100.0%
>>> Phase summary info:
>>> BuildTwoSided 20 1.0 2.3249e-01 2.2 0.00e+00 0.0 2.2e+04 4.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> BuildTwoSidedF 317 1.0 8.5016e-01 4.8 0.00e+00 0.0 2.1e+04 1.4e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatMult 150986 1.0 2.1963e+02 1.3 8.07e+10 1.8 1.1e+09 5.0e+02 1.2e+06 31 9100100 80 31 9100100 80 37007
>>> MatMultAdd 603944 1.0 1.6209e+02 1.4 8.07e+10 1.8 1.1e+09 5.0e+02 0.0e+00 23 9100100 0 23 9100100 0 50145
>>> MatConvert 30 1.0 1.6488e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatScale 10 1.0 1.0347e-03 3.9 6.68e+05 1.8 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 65036
>>> MatAssemblyBegin 916 1.0 8.6715e-01 1.4 0.00e+00 0.0 2.1e+04 1.4e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatAssemblyEnd 916 1.0 2.0682e-01 1.1 0.00e+00 0.0 4.7e+05 1.3e+02 1.5e+03 0 0 0 0 0 0 0 0 0 0 0
>>> MatZeroEntries 42 1.0 7.2787e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatView 10 1.0 1.4816e+00 1.0 0.00e+00 0.0 6.4e+03 1.3e+05 3.0e+01 0 0 0 0 0 0 0 0 0 0 0
>>> MatAXPY 40 1.0 1.0752e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatTranspose 80 1.0 3.0198e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatMatMult 60 1.0 3.0391e-01 1.0 7.82e+06 1.6 3.8e+05 2.8e+02 7.8e+02 0 0 0 0 0 0 0 0 0 0 2711
>>> MatMatMultSym 60 1.0 2.4238e-01 1.0 0.00e+00 0.0 3.3e+05 2.4e+02 7.2e+02 0 0 0 0 0 0 0 0 0 0 0
>>> MatMatMultNum 60 1.0 5.8508e-02 1.0 7.82e+06 1.6 4.7e+04 5.7e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 14084
>>> MatPtAP 40 1.0 4.5617e-01 1.0 1.59e+07 1.6 3.3e+05 1.0e+03 6.4e+02 0 0 0 0 0 0 0 0 0 0 3649
>>> MatPtAPSymbolic 40 1.0 2.6002e-01 1.0 0.00e+00 0.0 1.7e+05 6.5e+02 2.8e+02 0 0 0 0 0 0 0 0 0 0 0
>>> MatPtAPNumeric 40 1.0 1.9293e-01 1.0 1.59e+07 1.6 1.5e+05 1.5e+03 3.2e+02 0 0 0 0 0 0 0 0 0 0 8629
>>> MatTrnMatMult 40 1.0 2.3801e-01 1.0 6.09e+06 1.8 1.8e+05 1.0e+03 6.4e+02 0 0 0 0 0 0 0 0 0 0 2442
>>> MatTrnMatMultSym 40 1.0 1.6962e-01 1.0 0.00e+00 0.0 1.7e+05 4.4e+02 6.4e+02 0 0 0 0 0 0 0 0 0 0 0
>>> MatTrnMatMultNum 40 1.0 6.9000e-02 1.0 6.09e+06 1.8 9.7e+03 1.1e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 8425
>>> MatGetLocalMat 240 1.0 4.9149e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatGetBrAoCol 160 1.0 2.0470e-02 1.6 0.00e+00 0.0 3.3e+05 4.1e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatTranspose_SeqAIJ_FAST 80 1.0 2.9940e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> Mesh Partition 1 1.0 1.4825e+00 1.0 0.00e+00 0.0 9.8e+04 6.9e+01 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> Mesh Migration 1 1.0 3.6680e-02 1.0 0.00e+00 0.0 1.5e+03 1.4e+04 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DMPlexDistribute 1 1.0 1.5269e+00 1.0 0.00e+00 0.0 1.0e+05 3.5e+02 1.2e+01 0 0 0 0 0 0 0 0 0 0 0
>>> DMPlexDistCones 1 1.0 1.8845e-02 1.2 0.00e+00 0.0 1.0e+03 1.7e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DMPlexDistLabels 1 1.0 9.7280e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DMPlexDistData 1 1.0 3.1499e-01 1.4 0.00e+00 0.0 9.8e+04 4.3e+01 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DMPlexStratify 2 1.0 9.3421e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DMPlexPrealloc 2 1.0 3.5980e-02 1.0 0.00e+00 0.0 4.0e+04 1.8e+03 3.0e+01 0 0 0 0 0 0 0 0 0 0 0
>>> SFSetGraph 20 1.0 1.6069e-05 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFSetUp 20 1.0 2.8043e-01 1.9 0.00e+00 0.0 6.7e+04 5.0e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFBcastBegin 25 1.0 3.9653e-02 2.5 0.00e+00 0.0 6.1e+04 4.9e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFBcastEnd 25 1.0 9.0128e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFReduceBegin 10 1.0 4.3473e-04 5.5 0.00e+00 0.0 7.4e+03 4.0e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFReduceEnd 10 1.0 5.7962e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFFetchOpBegin 2 1.0 1.6069e-0434.7 0.00e+00 0.0 1.8e+03 4.4e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFFetchOpEnd 2 1.0 8.9251e-04 2.6 0.00e+00 0.0 1.8e+03 4.4e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> VecSet 302179 1.0 1.3128e+00 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> VecAssemblyBegin 1 1.0 1.3844e-03 7.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> VecAssemblyEnd 1 1.0 3.4710e-05 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> VecScatterBegin 603945 1.0 2.2874e+01 4.4 0.00e+00 0.0 1.1e+09 5.0e+02 1.0e+00 2 0100100 0 2 0100100 0 0
>>> VecScatterEnd 603944 1.0 8.2651e+01 4.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 7 0 0 0 0 7 0 0 0 0 0
>>> VecSetRandom 11 1.0 2.7061e-03 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> EPSSetUp 10 1.0 5.0371e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+01 0 0 0 0 0 0 0 0 0 0 0
>>> EPSSolve 10 1.0 6.1329e+02 1.0 9.23e+11 1.8 1.1e+09 5.0e+02 1.5e+06 99100100100100 99100100100100 150509
>>> STSetUp 10 1.0 2.5475e-04 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> STApply 150986 1.0 2.1997e+02 1.3 8.07e+10 1.8 1.1e+09 5.0e+02 1.2e+06 31 9100100 80 31 9100100 80 36950
>>> BVCopy 1791 1.0 5.1953e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> BVMultVec 301925 1.0 1.5007e+02 3.1 3.31e+11 1.8 0.0e+00 0.0e+00 0.0e+00 14 36 0 0 0 14 36 0 0 0 220292
>>> BVMultInPlace 1801 1.0 8.0080e+00 1.8 1.78e+11 1.8 0.0e+00 0.0e+00 0.0e+00 1 19 0 0 0 1 19 0 0 0 2222543
>>> BVDotVec 301925 1.0 3.2807e+02 1.4 3.33e+11 1.8 0.0e+00 0.0e+00 3.0e+05 47 36 0 0 20 47 36 0 0 20 101409
>>> BVOrthogonalizeV 150996 1.0 4.0292e+02 1.1 6.64e+11 1.8 0.0e+00 0.0e+00 3.0e+05 62 72 0 0 20 62 72 0 0 20 164619
>>> BVScale 150996 1.0 4.1660e-01 3.2 5.27e+08 1.8 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 126494
>>> BVSetRandom 10 1.0 2.5061e-03 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DSSolve 1801 1.0 2.0764e+01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
>>> DSVectors 2779 1.0 1.2691e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DSOther 1801 1.0 1.2944e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
>>> Distributed Mesh 6 6 29160 0.
>>> GraphPartitioner 2 2 1244 0.
>>> Matrix 1104 1104 136615232 0.
>>> Index Set 930 930 9125912 0.
>>> IS L to G Mapping 3 3 2235608 0.
>>> Section 28 26 18720 0.
>>> Star Forest Graph 30 30 25632 0.
>>> Discrete System 6 6 5616 0.
>>> PetscRandom 11 11 7194 0.
>>> Vector 604372 604372 8204816368 0.
>>> Vec Scatter 203 203 272192 0.
>>> Viewer 21 10 8480 0.
>>> Basis Vectors 10 10 530848 0.
>>> Average time to get PetscTime(): 3.49944e-08
>>> Average time for MPI_Barrier(): 5.842e-06
>>> Average time for zero size MPI_Send(): 8.72551e-06
>>> -log_view
>>> Using PETSc arch:
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
