[petsc-users] Question about DMPLEX/P4EST with different Sections
Berend van Wachem berend.vanwachem at ovgu.de
Mon Mar 30 06:15:59 CDT 2020
Dear Matt,
I am still not having success with the different sections on the DMForest.
The example you sent works only if the two sections are the same. But,
if the first section stores the data at the cell centers and the second
section stores the data at the cell faces, the code crashes.
I've attached the example again with 1 change compared to the example
you sent - line 134 indicates the second section should store the data
at the cell face. This crashes for me, see below.
Do you have any idea?
Many thanks,
Berend.
$ workingexample -on_error_attach_debugger
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] DMPlexTransferVecTree_Interpolate line 4000
/usr/local/petsc-3.12.4/src/dm/impls/plex/plextree.c
[0]PETSC ERROR: [0] DMPlexTransferVecTree line 4505
[0]PETSC ERROR: [0] DMForestTransferVec_p8est line 4829
/usr/local/petsc-3.12.4/src/dm/impls/forest/p4est/pforest.c
[0]PETSC ERROR: [0] DMForestTransferVec line 997
/usr/local/petsc-3.12.4/src/dm/impls/forest/forest.c
[0]PETSC ERROR: User provided function() line 0 in  unknown file
On 2020-03-19 23:39, Matthew Knepley wrote:
> Okay this runs for me.
>    Thanks,
>      Matt
> On Thu, Mar 19, 2020 at 6:07 PM Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
>     On Fri, Mar 13, 2020 at 9:45 AM Berend van Wachem
>     <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
>         Dear Matt,
>         Thanks for your response. My understanding of the DM and DMClone
>         is the
>         same - and I have tested this with a DMPLEX DM without problems.
>         However, for some reason, I cannot change/set the section of a
>         P4EST dm.
>         In the attached example code, I get an error in line 140, where
>         I try to
>         create a new section from the cloned P4EST DM. Is it not
>         possible to
>         create/set a section on a P4EST DM? Or maybe I am doing
>         something else
>         wrong? Do you suggest a workaround?
>     Hi Berend,
>     Sorry I am behind. The problem on line 140 is that you call a DMPlex
>     function (DMPlexCreateSection)
>     with a DMForest object. That is illegal. You can, however, call that
>     function using the Plex you get from
>     a Forest using DMConvert(DMForestClone, DMPLEX, &plexClone). I will
>     get your code running as soon
>     as I can, but after you create the Section, attaching it should be fine.
>        Thanks,
>           Matt
>         Many thanks, Berend.
>         On 2020-03-13 00:19, Matthew Knepley wrote:
>          > On Thu, Mar 12, 2020 at 7:40 AM Berend van Wachem
>         <mailto:berend.vanwachem at ovgu.de>>> wrote:
>          >     Dear All,
>          >     I have started to use DMPLEX with P4EST for a
>         computational fluid
>          >     dynamics application. I am solving a coupled system of 4
>         discretised
>          >     equations (for 3 velocity components and one pressure) on
>         a mesh.
>          >     However, next to these 4 variables, I also have a few
>         single field
>          >     variables (such as density and viscosity) defined over
>         the mesh,
>          >     which I
>          >     don't solve for (they should not be part of the matrix
>         with unknowns).
>          >     Most of these variables are at the cell centers, but in a
>         few cases, it
>          >     want to define them at cell faces.
>          >     With just DMPLEX, I solve this by:
>          >     DMPlexCreateMesh, so I get an initial DM
>          >     DMPlexCreateSection, indicating the need for 4 variables
>          >     DMSetLocalSection
>          >     DMCreateGlobalVector (and Matrix), so I get an Unknown
>         vector, a RHS
>          >     vector, and a matrix for the 4 variables.
>          >     To get a vector for a single variable at the cell center
>         or the cell
>          >     face, I clone the original DM, I define a new Section on
>         it, and then
>          >     create the vector from that which I need (e.g. for density,
>          >     viscosity or
>          >     a velocity at the cell face).
>          >     Then I loop over the mesh, and with MatSetValuesLocal, I
>         set the
>          >     coefficients. After that, I solve the system for multiple
>         timesteps
>          >     (sequential solves) and get the solution vector with the
>         4 variables
>          >     after each solve.
>          >     So-far, this works fine with DMPLEX. However, now I want
>         to use P4EST,
>          >     and I have difficulty defining a variable vector other
>         than the
>          >     original 4.
>          >     I have changed the code structure:
>          >     DMSetLocalSection
>          >     DMForestSetBaseDM(DM, DMForest) to create a DMForest
>          >     DMCreateGlobalVector (and Matrix), so I get a Unknown
>         vector, a RHS
>          >     then I perform multiple time-steps,
>          >         DMForestTemplate(DMForest ->  DMForestPost)
>          >         Adapt DMForestPost
>          >         DMCreateGlovalVector(DMForestPost, RefinedUnknownVector)
>          >         DMForestTransferVec(UnknownVector , RefinedUnknownVector)
>          >         DMForestPost -> DMForest
>          >     and then DMConvert(DMForest,DMPLEX,DM)
>          >     and I can solve the system as usual. That also seems to work.
>          >     But my conceptual question: how can I convert the other
>         variable
>          >     vectors
>          >     (obtained with a different section on the same DM) such
>         as density and
>          >     viscosity and faceVelocity within this framework?
>          > Here is my current thinking about DMs. A DM is a function space
>          > overlaying a topology. Much to my dismay, we
>          > do not have a topology object, so it hides inside DM.
>         DMClone() creates
>          > a shallow copy of the topology. We use
>          > this to have any number of data layouts through PetscSection,
>         laying
>          > over the same underlying topology.
>          > So for each layout you have, make a separate clone. Then
>         things like
>          > TransferVec() will respond to the layout in
>          > that clone. Certainly it works this way in Plex. I admit to
>         not having
>          > tried this for TransferVec(), but let me know if
>          > you have any problems.
>          > BTW, I usually use a dm for the solution, which I give to the
>         solver,
>          > say SNESSetDM(snes, dm), and then clone
>          > it as dmAux which has the layout for all the auxiliary fields
>         that are
>          > not involved in the solve. The Plex examples
>          > all use this form.
>          >    Thanks,
>          >       Matt
>          >     The DMForest has the same Section as the original DM and
>         will thus have
>          >     the space for exactly 4 variables per cell. I tried
>         pushing another
>          >     section on the DMForest and DMForestPost, but that does
>         not seem to
>          >     work. Please find attached a working example with code to
>         do this,
>          >     but I
>          >     get the error:
>          >     PETSC ERROR: PetscSectionGetChart() line 513 in
>           /usr/local/petsc-3.12.4/src/vec/is/section/interface/section.c
>         Wrong
>          >     type of object: Parameter # 1
>          >     So, I is there a way to DMForestTransferVec my other
>         vectors from one
>          >     DMForest to DMForestPost. How can I do this?
>          >     Many thanks for your help!
>          >     Best wishes, Berend.
>          > What most experimenters take for granted before they begin their
>          > experiments is infinitely more interesting than any results
>         to which
>          > their experiments lead.
>          > -- Norbert Wiener
>          > https://www.cse.buffalo.edu/~knepley/
>         <http://www.cse.buffalo.edu/~knepley/>
>     experiments is infinitely more interesting than any results to which
>     -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200330/fb0e1bc5/attachment.bin>
