[petsc-users] petsc4py/Plex createSection
Nicolas Barral nicolas.barral at math.u-bordeaux.fr
Sat Mar 28 09:04:22 CDT 2020
All,
I hope you're all safe and fine.
My question may be due to me being rusty with dmplex, please forgive me
if I missed something obvious...
In my Firedrake code, I had the following line for a 2D mesh
> section = createSection([1], [2, 0, 0], perm=mesh._plex_renumbering)
where mesh._plex_renumbering was an IS containing the mesh renumbering.
This created a nice section mapping the plex to a P1 field.
However, with a recently installed Petsc/petsc4py, this does not work
anymore and results in a section pointing all points of the plex to 0.
I investigated a bit (although I don't understand the doc for this
function), and found a similar construction in petsc4py
test/test_dmplex.py in 1D:
> DIM = 1
> CELLS = [[0, 1], [1, 2]]
> COORDS = [[0.], [0.5], [1.]]
> COMP = 1
> DOFS = [1, 0]
> plex = PETSc.DMPlex().createFromCellList(DIM, CELLS, COORDS)
> section = plex.createSection([COMP], [DOFS])
> plex.view()
> section.view()
This also results in an empty section (which makes the test fail when I
run it manually):
> PetscSection Object: 1 MPI processes
>   type not yet set
> Process 0:
>   (   0) dim  0 offset   0
>   (   1) dim  0 offset   0
>   (   2) dim  0 offset   0
>   (   3) dim  0 offset   0
>   (   4) dim  0 offset   0
So, what did I miss ?
Nicolas
