[petsc-users] [petsc4py] Assembly fails
Alejandro Aragon - 3ME A.M.Aragon at tudelft.nl
Fri Mar 27 02:31:19 CDT 2020
Dear Matthew,
Thanks for your email. I have attached the python code that reproduces the following error in my computer:
(.pydev) ➜  dmplex_fem mpirun -np 2  python Cpp2Python.py
Traceback (most recent call last):
  File "Cpp2Python.py", line 383, in <module>
    sys.exit(Cpp2Python())
  File "Cpp2Python.py", line 357, in Cpp2Python
    dm = createfields(dm)
  File "Cpp2Python.py", line 62, in createfields
    section.setFieldName(0, "u")
  File "PETSc/Section.pyx", line 59, in petsc4py.PETSc.Section.setFieldName
petsc4py.PETSc.Error: error code 63
[1] PetscSectionSetFieldName() line 427 in /private/tmp/pip-install-laf1l3br/petsc/src/vec/is/section/interface/section.c
[1] Argument out of range
[1] Section field 0 should be in [0, 0)
[0] PetscSectionSetFieldName() line 427 in /private/tmp/pip-install-laf1l3br/petsc/src/vec/is/section/interface/section.c
[0] Argument out of range
[0] Section field 0 should be in [0, 0)
Primary job  terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[23972,1],0]
  Exit code:    1
I’m using Python 3.8 and this is the output of ‘pip freeze'
(.pydev) ➜  dmplex_fem pip freeze
cachetools==4.0.0
cycler==0.10.0
kiwisolver==1.1.0
llvmlite==0.31.0
matplotlib==3.2.1
mpi4py==3.0.3
numba==0.48.0
numpy==1.18.2
petsc==3.12.4
petsc4py==3.12.0
plexus==0.1.0
pyparsing==2.4.6
python-dateutil==2.8.1
scipy==1.4.1
six==1.14.0
I’m looking forward to getting your insight on the issue.
Best regards,
— Alejandro
On 25 Mar 2020, at 17:37, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Mar 25, 2020 at 12:29 PM Alejandro Aragon - 3ME <A.M.Aragon at tudelft.nl<mailto:A.M.Aragon at tudelft.nl>> wrote:
Dear everyone,
I’m new to petsc4py and I’m trying to run a simple finite element code that uses DMPLEX to load a .msh file (created by Gmsh). In version 3.10 the code was working but I recently upgraded to 3.12 and I get the following error:
(.pydev) ➜  testmodule git:(e0bc9ae) ✗ mpirun -np 2 python testmodule/__main__.py
{3: <testmodule.constitutive.elastic.Elastic object at 0x10feea520>}
{3: <testmodule.constitutive.elastic.Elastic object at 0x10d96d520>}
  File "testmodule/__main__.py", line 32, in <module>
    sys.exit(main(sys.argv))
  File "testmodule/__main__.py", line 29, in main
    step.solve(m)
  File "/Users/aaragon/Local/testmodule/testmodule/fem/analysis/static.py", line 33, in solve
    self.Amat.assemblyBegin(assembly=0)  # FINAL_ASSEMBLY = 0
  File "PETSc/Mat.pyx", line 1039, in petsc4py.PETSc.Mat.assemblyBegin
[1] MatAssemblyBegin() line 5182 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/interface/matrix.c
[1] MatAssemblyBegin_MPIAIJ() line 810 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/impls/aij/mpi/mpiaij.c
[1] MatStashScatterBegin_Private() line 462 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[1] MatStashScatterBegin_BTS() line 931 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[1] PetscCommBuildTwoSidedFReq() line 555 in /private/tmp/pip-install-zurcx_6k/petsc/src/sys/utils/mpits.c
[1] toranks[0] 2 not in comm size 2
    step.solve(m)
[0] MatAssemblyBegin() line 5182 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/interface/matrix.c
[0] MatAssemblyBegin_MPIAIJ() line 810 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/impls/aij/mpi/mpiaij.c
[0] MatStashScatterBegin_Private() line 462 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[0] MatStashScatterBegin_BTS() line 931 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[0] PetscCommBuildTwoSidedFReq() line 555 in /private/tmp/pip-install-zurcx_6k/petsc/src/sys/utils/mpits.c
[0] toranks[0] 2 not in comm size 2
  Process name: [[46994,1],0]
  Exit code:    1
This is in the call to assembly, which looks like this:
# Begins assembling the matrix. This routine should be called after completing all calls to MatSetValues().
# Completes assembling the matrix. This routine should be called after MatAssemblyBegin().
self.Amat.assemblyEnd(assembly=0)
I would appreciate if someone can give me some insight on what has changed in the new version of petsc4py (or petsc for that matter) to make this code work again.
It looks like you have an inconsistent build, or a memory overwrite. Since you are in Python, I suspect the former. Can you build
PETSc from scratch and try this? Does it work in serial? Can you send a small code that reproduces this?
     Matt
Best regards,
— Alejandro
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.cse.buffalo.edu_-7Eknepley_&d=DwMFaQ&c=XYzUhXBD2cD-CornpT4QE19xOJBbRy-TBPLK0X9U2o8&r=U1Pry6bTDByPujjSnTcPY6KNXqrym6APfmtom-lIPFA&m=WPJk3cZzX4wkA5n5wceeOf2wjrRxHYug5Gs78b9WHlc&s=vuuUnGL1h2Bfv_uY7e5cMSfiF1btYPrvwf5vKy1JoN0&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200327/748fc91c/attachment-0001.html>
Desc: d1_0.msh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200327/748fc91c/attachment-0001.obj>
Type: text/x-python-script
Desc: Cpp2Python.py
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200327/748fc91c/attachment-0001.bin>
