[petsc-users] node DG with DMPlex
Matthew Knepley
knepley at gmail.com
Thu Mar 26 17:38:33 CDT 2020
On Thu, Mar 26, 2020 at 5:14 PM Yann Jobic <yann.jobic at univ-amu.fr> wrote:
> Hi matt
> Le 3/23/2020 à 2:24 PM, Matthew Knepley a écrit :
> > On Wed, Mar 18, 2020 at 12:58 PM Yann Jobic <yann.jobic at univ-amu.fr
> > <mailto:yann.jobic at univ-amu.fr>> wrote:
> > Hi matt,
> > Le 3/17/2020 à 4:00 PM, Matthew Knepley a écrit :
> > > On Mon, Mar 16, 2020 at 5:20 PM Yann Jobic
> > <yann.jobic at univ-amu.fr <mailto:yann.jobic at univ-amu.fr>
> > > <mailto:yann.jobic at univ-amu.fr <mailto:yann.jobic at univ-amu.fr>>>
> > wrote:
> > > Hi all,
> > > I would like to implement a nodal DG with the DMPlex
> interface.
> > > Therefore, i must add the internal nodes to the DM (GLL
> > nodes), with
> > > the
> > > constrains :
> > > 1) Add them as solution points, with correct coordinates (and
> > keep the
> > > good rotational ordering)
> > > 2) Find the shared nodes at faces in order to compute the
> fluxes
> > > 3) For parallel use, so synchronize the ghost node at each
> > time steps
> > > Let me get the fundamentals straight before advising, since I
> > have never
> > > implemented nodal DG.
> > > 1) What is shared?
> > I need to duplicate an edge in 2D, or a facet in 3D, and to sync it
> > after a time step, in order to compute the numerical fluxes
> > (Lax-Friedrichs at the beginning).
> > I should have been more specific, but I think I see what you want. You
> > do not "share" unknowns between cells,
> > so all unknowns should be associated with some cell in the Section.
> > You think of some cell unknowns as being "connected" to a face, so when
> > you want to calculate a flux, you need
> > the unknowns from the adjacent cell in order to do it. In order to do
> > this, I would partition with overlap=1, which
> > is what we do for finite volume, which has the same adjacency needs. You
> > might also set
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMSetAdjacency.html
> > to PETSC_TRUE, PETSC_FALSE, but you are probably doing everything
> > matrix-free if you are using DG.
> > The above is optimal for FV, but not for DG because you communicate more
> > than you absolutely have to.
> > A more complicated, but optimal, thing to do would be to assign interior
> > dofs to the cell, and two sets of dofs
> > to each face, one for each cell. Then you only communicate the face
> > dofs. Its just more bookkeeping for you,
> > but it will work in parallel just fine.
> I'm going this way.
> So i should use dm/impls/plex/examples/tutorials/ex1.c.html as reference.
> I should define the internal nodes on cells :
> I define the section with 3 fields (field 0 on cells, field 1 and 2 on
> faces), as :
> numComp[0] = Nr; /* Total number of dof per Cell */
> numDof[0*(dim+1)+0] = dim; /* defined over the Cell */
> And on the same section, the dofs at faces :
> numComp[1] = NumDofPerFace;
> numComp[2] = NumDofPerFace;
> numDof[1*(dim+1)+dim-1] = dim-1; /* internal dof of the cell */
> numDof[2*(dim+1)+dim-1] = dim-1; /* external dof of the cell */
> Is it a good way to create my section ?
I would put them all in one field. A "field" is supposed to be a physical
thing, like velocity or pressure.
> Thus, the data is duplicated for the faces, that means that i have to
> sync the internal Face dof at faces with their corresponding values from
> the internal one (at cells).
That is not how I was envisioning it. Perhaps a drawing. Suppose you had
DG2, then you have
17 18
7-----8-----9-----14----15
16,3 4 5,6 11 12,13
1-----2-----3-----9-----10
19 20
so each face gets 2 dofs, one for each cell.When doing a cell integral, you
only use the dof that is for that cell.
The local-to-global would update the face dofs, so you would get each side.
There is a reordering when you extract the closure. I have written one for
spectral elements. We would need
another here that ordered all the "other" face dofs to the end.
This seems a little complicated to me. Do you know how Andreas Klockner
does it in Hedge? Or Tim Warburton?
I just want to make sure I am not missing an elegant way to handle this.
> Here field 1 is synchronised with field 0, locally.
> But the external Face dof, field 2, have to be synchronised with the
> values of the adjacent cell.
> Is it possible to use something like DMPlexGetFaceFields ?
> Is there an example of such use of PetscSection and synchronisation
> process ?
> For the parallel part, should i use PetscSF object ?
In parallel, integrals would be summed into the global vector, so each side
has a 0 for the other face dof and the right contribution
for its face dof. Then both sides get both solution dofs. It seems to work
in my head.
> I read your article "Mesh Algorithms for PDE with Sieve I: Mesh
> Distribution". But it's refereeing to Matthew G. Knepley and Dmitry A.
> Karpeev. Sieve implementation.
> Technical Report ANL/MCS to appear, Argonne National Laboratory,
> January 2008.
> I couldn't find it. It is freely available ?
Don't bother reading that. There are later ones:
There are two pretty good sources:
https://arxiv.org/abs/1505.04633
https://arxiv.org/abs/1506.06194
The last one is a follow-on to this paper
https://arxiv.org/abs/0908.4427
Matt
> > I don't think you need extra vertices, > or coordinates, and for output I
> > recommend using DMPlexProject() to get
> > the solution in some space that can be plotted like P1, or anything else
> > supported by your visualization.
> I would like to use DMplex as much as i can, as i would in the future
> refine locally the mesh.
> I hope you're good in this difficult situation (covid19),
> Best regards,
> Yann
> > Thanks,
> > Matt
> > > We have an implementation of spectral element ordering
> https://gitlab.com/petsc/petsc/-/blob/master/src/dm/impls/plex/examples/tutorials/ex6.c
> > > Those share
> > > the whole element boundary.
> > > 2) What ghosts do you need?
> > In order to compute the numerical fluxes of one element, i need the
> > values of the surrounding nodes connected to the adjacent elements.
> > > 3) You want to store real space coordinates for a quadrature?
> > It should be basically the same as PetscFE of higher order.
> > I add some vertex needed to compute a polynomal solution of the
> desired
> > order. That means that if i have a N, order of the local
> approximation,
> > i need 0.5*(N+1)*(N+2) vertex to store in the DMPlex (in 2D), in
> > order to :
> > 1) have the correct number of dof
> > 2) use ghost nodes to sync the values of the vertex/edge/facet for
> > 1D/2D/3D problem
> > 2) save correctly the solution
> > Does it make sense to you ?
> > Maybe like
> https://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/tutorials/ex11.c.html
> > With the use of the function SplitFaces, which i didn't fully
> > understood
> > so far.
> > Thanks,
> > Yann
> > > We usually define a quadrature on the reference element
> once.
> > > Thanks,
> > > Matt
> > > I found elements of answers in those threads :
> https://lists.mcs.anl.gov/pipermail/petsc-users/2016-August/029985.html
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2019-October/039581.html
> > > However, it's not clear for me where to begin.
> > > Quoting Matt, i should :
> > > " DMGetCoordinateDM(dm, &cdm);
> > > <Set field information into cdm instead of dm>
> > > DMCreateLocalVector(cdm, &coordinatesLocal);
> > > <Fill in higher order coordinate values>
> > > DMSetCoordinatesLocal(dm, coordinatesLocal);"
> > > However, i will not create ghost nodes this way. And i'm not
> > sure to
> > > keep the good ordering.
> > > This part should be implemented in the PetscFE interface, for
> > high
> > > order
> > > discrete solutions.
> > > I did not succeed in finding the correct part of the source
> > doing it.
> > > Could you please give me some hint to begin correctly thoses
> > tasks ?
> > > Thanks,
> > > Yann
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to
> which
> > > their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> > <http://www.cse.buffalo.edu/~knepley/>
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200326/e6f1ea0d/attachment-0001.html>
