[petsc-users] Poor speed up for KSP example 45
Fande Kong fdkong.jd at gmail.com
Wed Mar 25 20:18:06 CDT 2020
In case someone wants to learn more about the hierarchical partitioning algorithm. Here is a reference
https://arxiv.org/pdf/1809.02666.pdf
Thanks
Fande
> On Mar 25, 2020, at 5:18 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> On Wed, Mar 25, 2020 at 6:40 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> On Wed, Mar 25, 2020 at 12:18 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> Also, a better test is see where streams pretty much saturates, then run that many processors per node and do the same test by increasing the nodes. This will tell you how well your network communication is doing.
>>>> But this result has a lot of stuff in "network communication" that can be further evaluated. The worst thing about this, I would think, is that the partitioning is blind to the memory hierarchy of inter and intra node communication.
>>> Hierarchical partitioning was designed for this purpose. https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/MatOrderings/MATPARTITIONINGHIERARCH.html#MATPARTITIONINGHIERARCH
>> That's fantastic!
>> Fande,
>>> The next thing to do is run with an initial grid that puts one cell per node and the do uniform refinement, until you have one cell per process (eg, one refinement step using 8 processes per node), partition to get one cell per process, then do uniform refinement to get a reasonable sized local problem. Alas, this is not easy to do, but it is doable.
>>>> On Wed, Mar 25, 2020 at 2:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> I would guess that you are saturating the memory bandwidth. After you make PETSc (make all) it will suggest that you test it (make test) and suggest that you run streams (make streams).
>>>> I see Matt answered but let me add that when you make streams you will seed the memory rate for 1,2,3, ... NP processes. If your machine is decent you should see very good speed up at the beginning and then it will start to saturate. You are seeing about 50% of perfect speedup at 16 process. I would expect that you will see something similar with streams. Without knowing your machine, your results look typical.
>>>>> On Wed, Mar 25, 2020 at 1:05 PM Amin Sadeghi <aminthefresh at gmail.com> wrote:
>>>>> Hi,
>>>>> I ran KSP example 45 on a single node with 32 cores and 125GB memory using 1, 16 and 32 MPI processes. Here's a comparison of the time spent during KSP.solve:
>>>>> - 1 MPI process: ~98 sec, speedup: 1X
>>>>> - 16 MPI processes: ~12 sec, speedup: ~8X
>>>>> - 32 MPI processes: ~11 sec, speedup: ~9X
>>>>> Since the problem size is large enough (8M unknowns), I expected a speedup much closer to 32X, rather than 9X. Is this expected? If yes, how can it be improved?
>>>>> I've attached three log files for more details.
>>>>> Sincerely,
>>>>> Amin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200325/9552132b/attachment.html>
