[petsc-users] Poor speed up for KSP example 45
Matthew Knepley
knepley at gmail.com
Wed Mar 25 16:55:57 CDT 2020
On Wed, Mar 25, 2020 at 5:41 PM Amin Sadeghi <aminthefresh at gmail.com> wrote:
> Junchao, thank you for doing the experiment, I guess TACC Frontera nodes
> have higher memory bandwidth (maybe more modern CPU architecture, although
> I'm not familiar as to which hardware affect memory bandwidth) than Compute
> Canada's Graham.
> Mark, I did as you suggested. As you suspected, running make streams
> yielded the same results, indicating that the memory bandwidth saturated at
> around 8 MPI processes. I ran the experiment on multiple nodes but only
> requested 8 cores per node, and here is the result:
> 1 node (8 cores total): 17.5s, 6X speedup
> 2 nodes (16 cores total): 13.5s, 7X speedup
> 3 nodes (24 cores total): 9.4s, 10X speedup
> 4 nodes (32 cores total): 8.3s, 12X speedup
> 5 nodes (40 cores total): 7.0s, 14X speedup
> 6 nodes (48 cores total): 61.4s, 2X speedup [!!!]
> 7 nodes (56 cores total): 4.3s, 23X speedup
> 8 nodes (64 cores total): 3.7s, 27X speedup
> *Note:* as you can see, the experiment with 6 nodes showed extremely poor
> scaling, which I guess was an outlier, maybe due to some connection problem?
> I also ran another experiment, requesting 2 full nodes, i.e. 64 cores, and
> here's the result:
> 2 nodes (64 cores total): 6.0s, 16X speedup [32 cores each node]
> So, it turns out that given a fixed number of cores, i.e. 64 in our case,
> much better speedups (27X vs. 16X in our case) can be achieved if they are
> distributed among separate nodes.
> Anyways, I really appreciate all your inputs.
> *One final question:* From what I understand from Mark's comment, PETSc
> at the moment is blind to memory hierarchy, is it feasible to make PETSc
> aware of the inter and intra node communication so that partitioning is
> done to maximize performance? Or, to put it differently, is this something
> that PETSc devs have their eyes on for the future?
There is already stuff in VecScatter that knows about the memory hierarchy,
which Junchao put in. We are actively working on some other node-aware
algorithms.
Matt
> Sincerely,
> Amin
> On Wed, Mar 25, 2020 at 3:51 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> I repeated your experiment on one node of TACC Frontera,
>> 1 rank: 85.0s
>> 16 ranks: 8.2s, 10x speedup
>> 32 ranks: 5.7s, 15x speedup
>> --Junchao Zhang
>> On Wed, Mar 25, 2020 at 1:18 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> Also, a better test is see where streams pretty much saturates, then run
>>> that many processors per node and do the same test by increasing the nodes.
>>> This will tell you how well your network communication is doing.
>>> But this result has a lot of stuff in "network communication" that can
>>> be further evaluated. The worst thing about this, I would think, is that
>>> the partitioning is blind to the memory hierarchy of inter and intra node
>>> communication. The next thing to do is run with an initial grid that puts
>>> one cell per node and the do uniform refinement, until you have one cell
>>> per process (eg, one refinement step using 8 processes per node), partition
>>> to get one cell per process, then do uniform refinement to get a
>>> reasonable sized local problem. Alas, this is not easy to do, but it is
>>> doable.
>>> On Wed, Mar 25, 2020 at 2:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> I would guess that you are saturating the memory bandwidth. After
>>>> you make PETSc (make all) it will suggest that you test it (make test) and
>>>> suggest that you run streams (make streams).
>>>> I see Matt answered but let me add that when you make streams you will
>>>> seed the memory rate for 1,2,3, ... NP processes. If your machine is decent
>>>> you should see very good speed up at the beginning and then it will start
>>>> to saturate. You are seeing about 50% of perfect speedup at 16 process. I
>>>> would expect that you will see something similar with streams. Without
>>>> knowing your machine, your results look typical.
>>>> On Wed, Mar 25, 2020 at 1:05 PM Amin Sadeghi <aminthefresh at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> I ran KSP example 45 on a single node with 32 cores and 125GB memory
>>>>> using 1, 16 and 32 MPI processes. Here's a comparison of the time spent
>>>>> during KSP.solve:
>>>>> - 1 MPI process: ~98 sec, speedup: 1X
>>>>> - 16 MPI processes: ~12 sec, speedup: ~8X
>>>>> - 32 MPI processes: ~11 sec, speedup: ~9X
>>>>> Since the problem size is large enough (8M unknowns), I expected a
>>>>> speedup much closer to 32X, rather than 9X. Is this expected? If yes, how
>>>>> can it be improved?
>>>>> I've attached three log files for more details.
>>>>> Sincerely,
>>>>> Amin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200325/f1a20b4a/attachment.html>
