[petsc-users] [petsc4py] Assembly fails
Alejandro Aragon - 3ME A.M.Aragon at tudelft.nl
Wed Mar 25 11:13:35 CDT 2020
Dear everyone,
I’m new to petsc4py and I’m trying to run a simple finite element code that uses DMPLEX to load a .msh file (created by Gmsh). In version 3.10 the code was working but I recently upgraded to 3.12 and I get the following error:
(.pydev) ➜  testmodule git:(e0bc9ae) ✗ mpirun -np 2 python testmodule/__main__.py
{3: <testmodule.constitutive.elastic.Elastic object at 0x10feea520>}
{3: <testmodule.constitutive.elastic.Elastic object at 0x10d96d520>}
Traceback (most recent call last):
  File "testmodule/__main__.py", line 32, in <module>
    sys.exit(main(sys.argv))
  File "testmodule/__main__.py", line 29, in main
    step.solve(m)
  File "/Users/aaragon/Local/testmodule/testmodule/fem/analysis/static.py", line 33, in solve
    self.Amat.assemblyBegin(assembly=0)  # FINAL_ASSEMBLY = 0
  File "PETSc/Mat.pyx", line 1039, in petsc4py.PETSc.Mat.assemblyBegin
petsc4py.PETSc.Error: error code 63
[1] MatAssemblyBegin() line 5182 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/interface/matrix.c
[1] MatAssemblyBegin_MPIAIJ() line 810 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/impls/aij/mpi/mpiaij.c
[1] MatStashScatterBegin_Private() line 462 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[1] MatStashScatterBegin_BTS() line 931 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[1] PetscCommBuildTwoSidedFReq() line 555 in /private/tmp/pip-install-zurcx_6k/petsc/src/sys/utils/mpits.c
[1] Argument out of range
[1] toranks[0] 2 not in comm size 2
    step.solve(m)
[0] MatAssemblyBegin() line 5182 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/interface/matrix.c
[0] MatAssemblyBegin_MPIAIJ() line 810 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/impls/aij/mpi/mpiaij.c
[0] MatStashScatterBegin_Private() line 462 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[0] MatStashScatterBegin_BTS() line 931 in /private/tmp/pip-install-zurcx_6k/petsc/src/mat/utils/matstash.c
[0] PetscCommBuildTwoSidedFReq() line 555 in /private/tmp/pip-install-zurcx_6k/petsc/src/sys/utils/mpits.c
[0] Argument out of range
[0] toranks[0] 2 not in comm size 2
Primary job  terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[46994,1],0]
  Exit code:    1
This is in the call to assembly, which looks like this:
# Begins assembling the matrix. This routine should be called after completing all calls to MatSetValues().
# Completes assembling the matrix. This routine should be called after MatAssemblyBegin().
self.Amat.assemblyEnd(assembly=0)
I would appreciate if someone can give me some insight on what has changed in the new version of petsc4py (or petsc for that matter) to make this code work again.
Best regards,
— Alejandro
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200325/02400384/attachment-0001.html>
