[petsc-users] Construct Matrix based on row and column values
Elias Karabelas
karabelaselias at gmail.com
Mon Mar 23 09:56:50 CDT 2020
Yeah I'll let you know how it turns out, for the moment I'm aiming at
scaler convection-diffusion equations for simulating the evolution of a
tracer concentration in a fluid with a precalculated velocity field from
a NS-Simulation.
On 23/03/2020 15:53, Jed Brown wrote:
> Thanks; please don't drop the list.
> I'd be curious whether this operation is common enough that we should
> add it to PETSc. My hesitance has been that people may want many
> different variants when working with systems of equations, for example.
> Elias Karabelas <karabelaselias at gmail.com> writes:
>> Dear Jed,
>> Yes the Matrix A comes from assembling a FEM-convection-diffusion
>> operator over a tetrahedral mesh. So my matrix graph should be
>> symmetric. Thanks for the snippet
>>>> Dear Users,
>>>> I want to implement a FCT (flux corrected transport) scheme with PETSc.
>>>> To this end I have amongst other things create a Matrix whose entries
>>>> are given by
>>>> L_ij = -max(0, A_ij, A_ji) for i neq j
>>>> L_ii = Sum_{j=0,..n, j neq i} L_ij
>>>> where Mat A is an (non-symmetric) Input Matrix created beforehand.
>>>> I was wondering how to do this. My first search brought me to
>>>> https://www.mcs.anl.gov/petsc/petsc-current/src/mat/examples/tutorials/ex16.c.html
>>>> but this just goes over the rows of one matrix to set new values and now
>>>> I would need to run over the rows and columns of the matrix. My Idea was
>>>> to just create a transpose of A and do the same but then the row-layout
>>>> will be different and I can't use the same for loop for A and AT and
>>>> thus also won't be able to calculate the max's above.
>>> Does your matrix have symmetric nonzero structure? (It's typical for
>>> finite element methods.)
>>> If so, all the indices will match up so I think you can do something like:
>>> for (row=rowstart; row<rowend; row++) {
>>> PetscScalar Lvals[MAX_LEN];
>>> PetscInt diag;
>>> MatGetRow(A, row, &ncols, &cols, &vals);
>>> MatGetRow(At, row, &ncolst, &colst, &valst);
>>> assert(ncols == ncolst); // symmetric structure
>>> PetscScalar sum = 0;
>>> for (c=0; c<ncols; c++) {
>>> assert(cols[c] == colst[c]); // symmetric structure
>>> if (cols[c] == row) diag = c;
>>> else sum -= (Lvals[c] = -max(0, vals[c], valst[c]));
>>> Lvals[diag] = sum;
>>> MatSetValues(L, 1, &row, ncols, cols, Lvals, INSERT_VALUES);
>>> MatRestoreRow(A, row, &ncols, &cols, &vals);
>>> MatRestoreRow(At, row, &ncolst, &colst, &valst);
