[petsc-users] Construct Matrix based on row and column values
Elias Karabelas
karabelaselias at gmail.com
Mon Mar 23 09:17:28 CDT 2020
Ok I'll try to decipher that. Thought that I would maybe find something
in the GAMG routines but I'll be happy to scroll through the ASM stuff :D
On 23/03/2020 13:56, Matthew Knepley wrote:
> On Mon, Mar 23, 2020 at 8:41 AM Elias Karabelas
> <karabelaselias at gmail.com <mailto:karabelaselias at gmail.com>> wrote:
> Thanks I'll have a look at it. So I understand correctly, that
> purely algebraic is not the way to go through PETSc here?
> You can make it work. You would have the same difficulty in any linear
> algebra package, namely that you need
> an overlapped decomposition of the matrix, which no package does by
> default. PETSc does it for ASM, so you could
> use those routines to get what you want.
> Thanks,
> Matt
> Cheers
> Elias
> On 23/03/2020 13:39, Matthew Knepley wrote:
>> On Mon, Mar 23, 2020 at 8:38 AM Elias Karabelas
>> On 23/03/2020 13:36, Matthew Knepley wrote:
>>> On Mon, Mar 23, 2020 at 8:31 AM Elias Karabelas
>>> wrote:
>>> Dear Matt,
>>> I've just found this answer from 2014
>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2014-August/022450.html
>>> wondering if this would theoretically work.
>>> In serial certainly, I just don't see how it works in
>>> parallel since you might not own the row you need from the
>>> transpose.
>>> And the thing with this FCT-Schemes is, that they're
>>> build on purely algebraic considerations (like AMG) so I
>>> don't want to break it back down to mesh information if
>>> possible at all.
>>> The FEM-FCT I am familiar with from Lohner was phrased on a
>>> mesh.
>> Can you give me a reference to that? I based my things on
>> this work
>> https://www.sciencedirect.com/science/article/pii/S0045782508003150#!
>> Volker is of course great. I believe I was thinking of
>> https://onlinelibrary.wiley.com/doi/abs/10.1002/fld.1650071007
>> Thanks,
>> Matt
>> Best regards
>> Elias
>>> Thanks,
>>> Matt
>>> Best regards
>>> Elias
>>> On 23/03/2020 13:02, Matthew Knepley wrote:
>>>> On Mon, Mar 23, 2020 at 7:46 AM Elias Karabelas
>>>> Dear Users,
>>>> I want to implement a FCT (flux corrected
>>>> transport) scheme with PETSc.
>>>> To this end I have amongst other things create a
>>>> Matrix whose entries
>>>> are given by
>>>> L_ij = -max(0, A_ij, A_ji) for i neq j
>>>> L_ii = Sum_{j=0,..n, j neq i} L_ij
>>>> where Mat A is an (non-symmetric) Input Matrix
>>>> created beforehand.
>>>> I was wondering how to do this. My first search
>>>> brought me to
>>>> https://www.mcs.anl.gov/petsc/petsc-current/src/mat/examples/tutorials/ex16.c.html
>>>> but this just goes over the rows of one matrix to
>>>> set new values and now
>>>> I would need to run over the rows and columns of
>>>> the matrix. My Idea was
>>>> to just create a transpose of A and do the same but
>>>> then the row-layout
>>>> will be different and I can't use the same for loop
>>>> for A and AT and
>>>> thus also won't be able to calculate the max's above.
>>>> Any help would be appreciated
>>>> I think it would likely be much easier to write your
>>>> algorithm directly on the mesh, rather than using
>>>> matrices, since the locality information is explicit
>>>> with the mesh, but has to be reconstructed with the matrix.
>>>> The problem here is that in parallel there would be no
>>>> easy way to get the halo you need using a matrix. You
>>>> really want the ghosted space for assembly, and that is
>>>> provided by the DM objects. Does this make sense?
>>>> Unless anybody in PETSc has a better idea.
>>>> Thanks,
>>>> Matt
>>>> Best regards
>>>> Elias
>>>> What most experimenters take for granted before they
>>>> begin their experiments is infinitely more interesting
>>>> than any results to which their experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> -- Norbert Wiener
>> experiments is infinitely more interesting than any results to
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200323/13729fcd/attachment-0001.html>
