[petsc-users] Construct Matrix based on row and column values
Elias Karabelas
karabelaselias at gmail.com
Mon Mar 23 07:41:06 CDT 2020
Thanks I'll have a look at it. So I understand correctly, that purely
algebraic is not the way to go through PETSc here?
Cheers
Elias
On 23/03/2020 13:39, Matthew Knepley wrote:
> On Mon, Mar 23, 2020 at 8:38 AM Elias Karabelas
> <karabelaselias at gmail.com <mailto:karabelaselias at gmail.com>> wrote:
> On 23/03/2020 13:36, Matthew Knepley wrote:
>> On Mon, Mar 23, 2020 at 8:31 AM Elias Karabelas
>> Dear Matt,
>> I've just found this answer from 2014
>> https://lists.mcs.anl.gov/pipermail/petsc-users/2014-August/022450.html
>> wondering if this would theoretically work.
>> In serial certainly, I just don't see how it works in parallel
>> since you might not own the row you need from the transpose.
>> And the thing with this FCT-Schemes is, that they're build on
>> purely algebraic considerations (like AMG) so I don't want to
>> break it back down to mesh information if possible at all.
>> The FEM-FCT I am familiar with from Lohner was phrased on a mesh.
> Can you give me a reference to that? I based my things on this
> work
> https://www.sciencedirect.com/science/article/pii/S0045782508003150#!
> Volker is of course great. I believe I was thinking of
> https://onlinelibrary.wiley.com/doi/abs/10.1002/fld.1650071007
> Thanks,
> Matt
> Best regards
> Elias
>> Thanks,
>> Matt
>> Best regards
>> Elias
>> On 23/03/2020 13:02, Matthew Knepley wrote:
>>> On Mon, Mar 23, 2020 at 7:46 AM Elias Karabelas
>>> wrote:
>>> Dear Users,
>>> I want to implement a FCT (flux corrected transport)
>>> scheme with PETSc.
>>> To this end I have amongst other things create a Matrix
>>> whose entries
>>> are given by
>>> L_ij = -max(0, A_ij, A_ji) for i neq j
>>> L_ii = Sum_{j=0,..n, j neq i} L_ij
>>> where Mat A is an (non-symmetric) Input Matrix created
>>> beforehand.
>>> I was wondering how to do this. My first search brought
>>> me to
>>> https://www.mcs.anl.gov/petsc/petsc-current/src/mat/examples/tutorials/ex16.c.html
>>> but this just goes over the rows of one matrix to set
>>> new values and now
>>> I would need to run over the rows and columns of the
>>> matrix. My Idea was
>>> to just create a transpose of A and do the same but then
>>> the row-layout
>>> will be different and I can't use the same for loop for
>>> A and AT and
>>> thus also won't be able to calculate the max's above.
>>> Any help would be appreciated
>>> I think it would likely be much easier to write your
>>> algorithm directly on the mesh, rather than using matrices,
>>> since the locality information is explicit with the mesh,
>>> but has to be reconstructed with the matrix.
>>> The problem here is that in parallel there would be no easy
>>> way to get the halo you need using a matrix. You
>>> really want the ghosted space for assembly, and that is
>>> provided by the DM objects. Does this make sense?
>>> Unless anybody in PETSc has a better idea.
>>> Thanks,
>>> Matt
>>> Best regards
>>> Elias
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments is infinitely more interesting than any results to
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200323/77aa694d/attachment-0001.html>
