[petsc-users] Construct Matrix based on row and column values
Elias Karabelas
karabelaselias at gmail.com
Mon Mar 23 07:37:58 CDT 2020
On 23/03/2020 13:36, Matthew Knepley wrote:
> On Mon, Mar 23, 2020 at 8:31 AM Elias Karabelas
> <karabelaselias at gmail.com <mailto:karabelaselias at gmail.com>> wrote:
> Dear Matt,
> I've just found this answer from 2014
> https://lists.mcs.anl.gov/pipermail/petsc-users/2014-August/022450.html
> wondering if this would theoretically work.
> In serial certainly, I just don't see how it works in parallel since
> you might not own the row you need from the transpose.
> And the thing with this FCT-Schemes is, that they're build on
> purely algebraic considerations (like AMG) so I don't want to
> break it back down to mesh information if possible at all.
> The FEM-FCT I am familiar with from Lohner was phrased on a mesh.
Can you give me a reference to that? I based my things on this work
https://www.sciencedirect.com/science/article/pii/S0045782508003150#!
Best regards
Elias
> Thanks,
> Matt
> Best regards
> Elias
> On 23/03/2020 13:02, Matthew Knepley wrote:
>> On Mon, Mar 23, 2020 at 7:46 AM Elias Karabelas
>> Dear Users,
>> I want to implement a FCT (flux corrected transport) scheme
>> with PETSc.
>> To this end I have amongst other things create a Matrix whose
>> entries
>> are given by
>> L_ij = -max(0, A_ij, A_ji) for i neq j
>> L_ii = Sum_{j=0,..n, j neq i} L_ij
>> where Mat A is an (non-symmetric) Input Matrix created
>> beforehand.
>> I was wondering how to do this. My first search brought me to
>> https://www.mcs.anl.gov/petsc/petsc-current/src/mat/examples/tutorials/ex16.c.html
>> but this just goes over the rows of one matrix to set new
>> values and now
>> I would need to run over the rows and columns of the matrix.
>> My Idea was
>> to just create a transpose of A and do the same but then the
>> row-layout
>> will be different and I can't use the same for loop for A and
>> AT and
>> thus also won't be able to calculate the max's above.
>> Any help would be appreciated
>> I think it would likely be much easier to write your algorithm
>> directly on the mesh, rather than using matrices, since the
>> locality information is explicit with the mesh, but has to be
>> reconstructed with the matrix.
>> The problem here is that in parallel there would be no easy way
>> to get the halo you need using a matrix. You
>> really want the ghosted space for assembly, and that is provided
>> by the DM objects. Does this make sense?
>> Unless anybody in PETSc has a better idea.
>> Thanks,
>> Matt
>> Best regards
>> Elias
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200323/d57e09a3/attachment.html>
