[petsc-users] Inquiry about the interpolation and restriction matrix for PCMG
Xiaodong Liu
xliu29 at ncsu.edu
Sat Mar 21 11:46:28 CDT 2020
The issue is that, I tested non-Galerkin type without setting up coarse
operators explicitly using PCMGSetOperators, but it worked pretty well.
Xiaodong Liu, PhD
X: Computational Physics Division
Los Alamos National Laboratory
P.O. Box 1663,
Los Alamos, NM 87544
505-709-0534
On Fri, Mar 20, 2020 at 8:28 PM Xiaodong Liu <xliu29 at ncsu.edu> wrote:
> Thanks a lot, Matthew and Mark !
> Take care.
> Xiaodong Liu, PhD
> P.O. Box 1663,
> 505-709-0534
> On Fri, Mar 20, 2020 at 6:50 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Mar 20, 2020 at 6:26 PM Xiaodong Liu <xliu29 at ncsu.edu> wrote:
>>> Hi, Petsc team,
>>> I am practising PCMG using the following case (3DQ1)
>>> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex45.c.html
>>> I have several questions.
>>> *1) About the interpolation and restriction matrix*
>>> For both Galerkin and non-Galerkin type, the interpolation matrix P is
>>> based on the trilinear interpolation (*I found the source code*) and
>>> the restriction one R is 1/8*P^T?
>>> *Could you please tell me where the source code to define the
>>> restriction matrix is? *
>>> *2) About the operator on the coarse level*
>>> It is straightforward to calculate the operator on the coarse level
>>> for Galerkin type by R*A*P. But how did you define the operator for
>>> non-Galerkin type?
>> non-Galerkin usually means rediscretization, where the user explicitly
>> supplies the coarser operations, using
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCMGSetOperators.html
>> Thanks,
>> Matt
>>> Did you use DMRestrict ? Could you please tell me where is the source
>>> code to define
>>> (*link->restricthook)(fine,restrct,rscale,inject,coarse,link->ctx);
>>> in
>>> 2933: PetscErrorCode DMRestrict(DM fine,Mat restrct,Vec rscale,Mat
>>> inject,DM coarse)
>>> 2934: {
>>> 2935: PetscErrorCode ierr;
>>> 2936: DMCoarsenHookLink link;
>>> 2939: for (link=fine->coarsenhook; link; link=link->next) {
>>> 2940: if (link->restricthook) {
>>> 2941:
>>> 2942: }
>>> 2943: }
>>> 2944: return(0);
>>> 2945: }
>>> on
>>> https://www.mcs.anl.gov/petsc/petsc-current/src/dm/interface/dm.c.html#DMRestrict
>>> Thanks a lot !
>>> Take care!
>>> Xiaodong
>>> Xiaodong Liu, PhD
>>> P.O. Box 1663,
>>> 505-709-0534
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200321/6e674736/attachment.html>
