[petsc-users] node DG with DMPlex
Matthew Knepley
knepley at gmail.com
Tue Mar 17 10:00:07 CDT 2020
On Mon, Mar 16, 2020 at 5:20 PM Yann Jobic <yann.jobic at univ-amu.fr> wrote:
> Hi all,
> I would like to implement a nodal DG with the DMPlex interface.
> Therefore, i must add the internal nodes to the DM (GLL nodes), with the
> constrains :
> 1) Add them as solution points, with correct coordinates (and keep the
> good rotational ordering)
> 2) Find the shared nodes at faces in order to compute the fluxes
> 3) For parallel use, so synchronize the ghost node at each time steps
Let me get the fundamentals straight before advising, since I have never
implemented nodal DG.
1) What is shared?
We have an implementation of spectral element ordering (
https://gitlab.com/petsc/petsc/-/blob/master/src/dm/impls/plex/examples/tutorials/ex6.c).
Those share
the whole element boundary.
2) What ghosts do you need?
3) You want to store real space coordinates for a quadrature?
We usually define a quadrature on the reference element once.
Matt
> I found elements of answers in those threads :
> https://lists.mcs.anl.gov/pipermail/petsc-users/2016-August/029985.html
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2019-October/039581.html
> However, it's not clear for me where to begin.
> Quoting Matt, i should :
> " DMGetCoordinateDM(dm, &cdm);
> <Set field information into cdm instead of dm>
> DMCreateLocalVector(cdm, &coordinatesLocal);
> <Fill in higher order coordinate values>
> DMSetCoordinatesLocal(dm, coordinatesLocal);"
> However, i will not create ghost nodes this way. And i'm not sure to
> keep the good ordering.
> This part should be implemented in the PetscFE interface, for high order
> discrete solutions.
> I did not succeed in finding the correct part of the source doing it.
> Could you please give me some hint to begin correctly thoses tasks ?
> Thanks,
> Yann
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200317/86d988e7/attachment.html>
