[petsc-users] Random initial states of EPSSolve
Yang Bo (Asst Prof)
yang.bo at ntu.edu.sg
Tue Mar 17 07:23:14 CDT 2020
Hi everyone,
I am diagonalising a large symmetric real matrix for its null space (highly degenerate eigenstates with zero eigenvalues). I am using krylovschur which is variational, which is supposed to start with a set of random initial vectors. They will eventually converge to random vectors in the null space.
The problem is that if I run the EPSSOLVE with the same set of parameters (e.g. -eps_ncv and -eps_mpd), I always get the same eigenstates in the null space. This implies that the solver always start the same set of initial “random” vectors.
How does petsc generate the initial random vectors for krylovschur? Is there a way for me to generate different random initial vectors every time I run the diagonalisation (of the same matrix)?
Thanks, and stay safe and healthy!
Cheers,
Yang Bo
CONFIDENTIALITY: This email is intended solely for the person(s) named and may be confidential and/or privileged. If you are not the intended recipient, please delete it, notify us and do not copy, use, or disclose its contents.
Towards a sustainable earth: Print only when necessary. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200317/0504929e/attachment.html>
