[petsc-users] --download-fblaslapack libraries cannot be used
Satish Balay
balay at mcs.anl.gov
Sat Mar 14 12:57:43 CDT 2020
to work around - you can try:
LIBS="-lmpifort -lgfortran"
Satish
On Sat, 14 Mar 2020, Satish Balay via petsc-users wrote:
> Its the same location as before. For some reason configure is not saving the relevant logs.
> I don't understand saveLog() restoreLog() stuff. Matt, can you check on this?
> Satish
> On Sat, 14 Mar 2020, Fande Kong wrote:
> > The configuration crashed earlier than before with your changes.
> > Please see the attached log file when using your branch. The trouble lines
> > should be:
> > " asub=self.mangleFortranFunction("asub")
> > cbody = "extern void "+asub+"(void);\nint main(int argc,char
> > **args)\n{\n "+asub+"();\n return 0;\n}\n";
> > Thanks,
> > Fande,
> > On Thu, Mar 12, 2020 at 7:06 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > I can't figure out what the stack in the attached configure.log. [likely
> > > some stuff isn't getting logged in it]
> > > Can you retry with branch 'balay/fix-checkFortranLibraries/maint'?
> > > Satish
> > > On Thu, 12 Mar 2020, Fande Kong wrote:
> > > > Thanks, Satish,
> > > > But still have the problem. Please see the attached log file.
> > > > Thanks,
> > > > Fande.
> > > > On Thu, Mar 12, 2020 at 3:42 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > > Can you retry with the attached patch?
> > > > > BTW: Its best to use the latest patched version - i.e
> > > petsc-3.12.4.tar.gz
> > > > > Satish
> > > > > > This fixed the fblaslapack issue. Now have another issue about mumps.
> > > > > > Please see the log file attached.
> > > > > > Thanks,
> > > > > > Fande,
> > > > > > On Thu, Mar 12, 2020 at 1:38 PM Satish Balay <balay at mcs.anl.gov>
> > > wrote:
> > > > > > > For some reason - the fortran compiler libraries check worked fine
> > > > > without
> > > > > > > -lgfortran.
> > > > > > > But now - flbaslapack check is failing without it.
> > > > > > > To work arround - you can use option LIBS=-lgfortran
> > > > > > > Satish
> > > > > > > > Hi All,
> > > > > > > > I had an issue when configuring petsc on a linux machine. I have
> > > the
> > > > > > > > following error message:
> > > > > > > > Compiling FBLASLAPACK; this may take several minutes
> > > > > > > > TESTING: checkLib from
> > > config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
> > > > > > > > UNABLE to CONFIGURE with GIVEN OPTIONS (see
> > > > > configure.log for
> > > > > > > > details):
> > > > > > > > The configuration log was attached.
> > > > > > > > Thanks,
> > > > > > > > Fande,
