[petsc-users] --download-fblaslapack libraries cannot be used
Fande Kong fdkong.jd at gmail.com
Sat Mar 14 12:36:46 CDT 2020
The configuration crashed earlier than before with your changes.
Please see the attached log file when using your branch. The trouble lines
should be:
 "    asub=self.mangleFortranFunction("asub")
    cbody = "extern void "+asub+"(void);\nint main(int argc,char
**args)\n{\n  "+asub+"();\n  return 0;\n}\n";
Fande,
On Thu, Mar 12, 2020 at 7:06 PM Satish Balay <balay at mcs.anl.gov> wrote:
> I can't figure out what the stack in the attached configure.log. [likely
> some stuff isn't getting logged in it]
> Can you retry with branch 'balay/fix-checkFortranLibraries/maint'?
> Satish
> On Thu, 12 Mar 2020, Fande Kong wrote:
> > Thanks, Satish,
> > But still have the problem. Please see the attached log file.
> > Thanks,
> > Fande.
> > On Thu, Mar 12, 2020 at 3:42 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > Can you retry with the attached patch?
> > > BTW: Its best to use the latest patched version - i.e
> petsc-3.12.4.tar.gz
> > > Satish
> > > > This fixed the fblaslapack issue. Now have another issue about mumps.
> > > > Please see the log file attached.
> > > > Thanks,
> > > > Fande,
> > > > On Thu, Mar 12, 2020 at 1:38 PM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > > For some reason - the fortran compiler libraries check worked fine
> > > without
> > > > > -lgfortran.
> > > > > But now - flbaslapack check is failing without it.
> > > > > To work arround - you can use option LIBS=-lgfortran
> > > > > Satish
> > > > > > Hi All,
> > > > > > I had an issue when configuring petsc on a linux machine. I have
> the
> > > > > > following error message:
> > > > > >      Compiling FBLASLAPACK; this may take several minutes
> > > > > >    TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
> > > > > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see
> > > configure.log for
> > > > > > details):
> > > > > > The configuration log was attached.
> > > > > > Thanks,
> > > > > > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200314/5024c49c/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200314/5024c49c/attachment-0001.obj>
