[petsc-users] TS generating inconsistent data
    Stefano Zampini
    stefano.zampini at gmail.com
    Sat Mar 14 11:31:55 CDT 2020
Take a look at
src/tao/unconstrained/examples/tutorials/spectraladjointassimilation.c
You need to call TSResetTrajectory before calling TSSolve when reusing the same TS
> On Mar 14, 2020, at 6:54 PM, Zane Charles Jakobs <Zane.Jakobs at colorado.edu> wrote:
> Hi PETSc devs,
> I have some code that implements (essentially) 4D-VAR with PETSc, and the results of both my forward and adjoint integrations look correct to me (i.e. calling TSSolve() and then TSAdjointSolve() works correctly as far as I can tell). However, when I try to use a TaoSolve() to optimize my initial condition, I get this error message:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: History id should be unique
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.12.4-783-g88ddbcab12  GIT Date: 2020-02-21 16:53:25 -0600
> [0]PETSC ERROR: ./var_ic_test on a arch-linux2-c-debug named DiffeoInvariant by diffeoinvariant Sat Mar 14 09:39:05 2020
> [0]PETSC ERROR: Configure options CFLAGS="-O3 -march=native -mtune=native -fPIE" --with-shared-libraries=1 --with-openmp=1 --with-threads=1 --with-fortran=0 --with-avx2=1 CXXOPTFLAGS="-O3 -march=native -mtune=native -fPIE" --with-cc=clang --with-cxx=clang++ --download-mpich
> [0]PETSC ERROR: #1 TSHistoryUpdate() line 82 in /usr/local/petsc/src/ts/interface/tshistory.c
> [0]PETSC ERROR: #2 TSTrajectorySet() line 73 in /usr/local/petsc/src/ts/trajectory/interface/traj.c
> [0]PETSC ERROR: #3 TSSolve() line 4005 in /usr/local/petsc/src/ts/interface/ts.c
> [0]PETSC ERROR: #4 MixedModelFormVARICFunctionGradient() line 301 in mixed.c
> [0]PETSC ERROR: #5 TaoComputeObjectiveAndGradient() line 261 in /usr/local/petsc/src/tao/interface/taosolver_fg.c
> [0]PETSC ERROR: #6 TaoSolve_LMVM() line 23 in /usr/local/petsc/src/tao/unconstrained/impls/lmvm/lmvm.c
> [0]PETSC ERROR: #7 TaoSolve() line 219 in /usr/local/petsc/src/tao/interface/taosolver.c
> [0]PETSC ERROR: #8 MixedModelOptimize() line 639 in mixed.c
> [0]PETSC ERROR: #9 MixedModelOptimizeInitialCondition() line 648 in mixed.c
> [0]PETSC ERROR: #10 main() line 76 in var_ic_test.c
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> In the function MixedModelFormVARICFunctionGradient(), I do
> ierr = TSSetTime(model->ts, 0.0);CHKERRQ(ierr);
> ierr = TSSetStepNumber(model->ts, 0);CHKERRQ(ierr);
> ierr = TSSetFromOptions(model->ts);CHKERRQ(ierr);
> ierr = TSSetMaxTime(model->ts, model->obs->t);CHKERRQ(ierr);
> ierr = TSSolve(model->ts, model->X);CHKERRQ(ierr);
> ... [allocating and setting cost gradient vec]
> ierr = TSSetCostGradients(model->ts, 1, model->lambda, NULL);CHKERRQ(ierr);
> ierr = TSAdjointSolve(model->ts);CHKERRQ(ierr);
> ierr = VecCopy(model->lambda[0], G);CHKERRQ(ierr);
> What might be causing the above error? Am I using a deprecated version of the Tao interface? (I'm using TaoSetObjectiveAndGradientRoutine, as done in ex20_opt_ic.c)
> Thanks!
> -Zane Jakobs
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200314/4819b958/attachment.html>
