[petsc-users] Question about DMPLEX/P4EST with different Sections
Matthew Knepley
knepley at gmail.com
Fri Mar 13 08:50:36 CDT 2020
On Fri, Mar 13, 2020 at 9:45 AM Berend van Wachem <berend.vanwachem at ovgu.de>
wrote:
> Dear Matt,
> Thanks for your response. My understanding of the DM and DMClone is the
> same - and I have tested this with a DMPLEX DM without problems.
> However, for some reason, I cannot change/set the section of a P4EST dm.
> In the attached example code, I get an error in line 140, where I try to
> create a new section from the cloned P4EST DM. Is it not possible to
> create/set a section on a P4EST DM? Or maybe I am doing something else
> wrong? Do you suggest a workaround?
Ah, I see. Let me check your example.
Toby, is this the way p4est acts right now?
Matt
> Many thanks, Berend.
> On 2020-03-13 00:19, Matthew Knepley wrote:
> > On Thu, Mar 12, 2020 at 7:40 AM Berend van Wachem
> > <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
> > Dear All,
> > I have started to use DMPLEX with P4EST for a computational fluid
> > dynamics application. I am solving a coupled system of 4 discretised
> > equations (for 3 velocity components and one pressure) on a mesh.
> > However, next to these 4 variables, I also have a few single field
> > variables (such as density and viscosity) defined over the mesh,
> > which I
> > don't solve for (they should not be part of the matrix with
> unknowns).
> > Most of these variables are at the cell centers, but in a few cases,
> it
> > want to define them at cell faces.
> > With just DMPLEX, I solve this by:
> > DMPlexCreateMesh, so I get an initial DM
> > DMPlexCreateSection, indicating the need for 4 variables
> > DMSetLocalSection
> > DMCreateGlobalVector (and Matrix), so I get an Unknown vector, a RHS
> > vector, and a matrix for the 4 variables.
> > To get a vector for a single variable at the cell center or the cell
> > face, I clone the original DM, I define a new Section on it, and then
> > create the vector from that which I need (e.g. for density,
> > viscosity or
> > a velocity at the cell face).
> > Then I loop over the mesh, and with MatSetValuesLocal, I set the
> > coefficients. After that, I solve the system for multiple timesteps
> > (sequential solves) and get the solution vector with the 4 variables
> > after each solve.
> > So-far, this works fine with DMPLEX. However, now I want to use
> P4EST,
> > and I have difficulty defining a variable vector other than the
> > original 4.
> > I have changed the code structure:
> > DMSetLocalSection
> > DMForestSetBaseDM(DM, DMForest) to create a DMForest
> > DMCreateGlobalVector (and Matrix), so I get a Unknown vector, a RHS
> > then I perform multiple time-steps,
> > DMForestTemplate(DMForest -> DMForestPost)
> > Adapt DMForestPost
> > DMCreateGlovalVector(DMForestPost, RefinedUnknownVector)
> > DMForestTransferVec(UnknownVector , RefinedUnknownVector)
> > DMForestPost -> DMForest
> > and then DMConvert(DMForest,DMPLEX,DM)
> > and I can solve the system as usual. That also seems to work.
> > But my conceptual question: how can I convert the other variable
> > vectors
> > (obtained with a different section on the same DM) such as density
> and
> > viscosity and faceVelocity within this framework?
> > Here is my current thinking about DMs. A DM is a function space
> > overlaying a topology. Much to my dismay, we
> > do not have a topology object, so it hides inside DM. DMClone() creates
> > a shallow copy of the topology. We use
> > this to have any number of data layouts through PetscSection, laying
> > over the same underlying topology.
> > So for each layout you have, make a separate clone. Then things like
> > TransferVec() will respond to the layout in
> > that clone. Certainly it works this way in Plex. I admit to not having
> > tried this for TransferVec(), but let me know if
> > you have any problems.
> > BTW, I usually use a dm for the solution, which I give to the solver,
> > say SNESSetDM(snes, dm), and then clone
> > it as dmAux which has the layout for all the auxiliary fields that are
> > not involved in the solve. The Plex examples
> > all use this form.
> > Thanks,
> > Matt
> > The DMForest has the same Section as the original DM and will thus
> have
> > the space for exactly 4 variables per cell. I tried pushing another
> > section on the DMForest and DMForestPost, but that does not seem to
> > work. Please find attached a working example with code to do this,
> > but I
> > get the error:
> > PETSC ERROR: PetscSectionGetChart() line 513 in
> > /usr/local/petsc-3.12.4/src/vec/is/section/interface/section.c Wrong
> > type of object: Parameter # 1
> > So, I is there a way to DMForestTransferVec my other vectors from one
> > DMForest to DMForestPost. How can I do this?
> > Many thanks for your help!
> > Best wishes, Berend.
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200313/85db779f/attachment.html>
