[petsc-users] make error in stefanozampini/hypre-cuda-rebased-v2
    Mark Adams
    mfadams at lbl.gov
    Fri Mar 13 08:17:40 CDT 2020
This error goes away with 32 bit integers. These methods are part of CUDA
C++ (https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html) and
I see unsigned long long int versions, but not signed ones that are in
PETSc.
My cuda is not that new:
08:43 2 stefanozampini/hypre-cuda-rebased-v2= ~/petsc_install$ nvcc
--version
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Sun_Jul_28_19:07:52_PDT_2019
Cuda compilation tools, release 10.1, V10.1.243
Junchao, do you have any ideas?
I did try just removing these methods and then it complained that they were
not there.
On Thu, Mar 12, 2020 at 9:26 PM Satish Balay <balay at mcs.anl.gov> wrote:
> /autofs/nccs-svm1_home1/adams/petsc_install/src/vec/is/sf/impls/basic/cuda/
> sfpackcuda.cu(334): error: function "atomicMin(long long *, long long)"
> has already been defined
> sfpackcuda.cu(345): error: function "atomicMax(long long *, long long)"
> sfpackcuda.cu(413): error: function "atomicAnd(long long *, long long)"
> sfpackcuda.cu(414): error: function "atomicOr(long long *, long long)"
> sfpackcuda.cu(415): error: function "atomicXor(long long *, long long)"
> This is a strange error. For one the compiler is not showing where the
> prior definition is.
> And the prior definition I see is 'double atomicMin(double* address,
> double val)' which shouldn't conflict - as this is c++?
> Satish
> On Thu, 12 Mar 2020, Mark Adams wrote:
> > I get this make error in stefanozampini/hypre-cuda-rebased-v2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200313/8da11b3d/attachment-0001.html>
