[petsc-users] --download-fblaslapack libraries cannot be used
Fande Kong
fdkong.jd at gmail.com
Thu Mar 12 18:41:05 CDT 2020
Thanks, Satish,
But still have the problem. Please see the attached log file.
Fande.
On Thu, Mar 12, 2020 at 3:42 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Can you retry with the attached patch?
> BTW: Its best to use the latest patched version - i.e petsc-3.12.4.tar.gz
> Satish
> On Thu, 12 Mar 2020, Fande Kong wrote:
> > This fixed the fblaslapack issue. Now have another issue about mumps.
> > Please see the log file attached.
> > Thanks,
> > Fande,
> > On Thu, Mar 12, 2020 at 1:38 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > For some reason - the fortran compiler libraries check worked fine
> without
> > > -lgfortran.
> > > But now - flbaslapack check is failing without it.
> > > To work arround - you can use option LIBS=-lgfortran
> > > Satish
> > > > Hi All,
> > > > I had an issue when configuring petsc on a linux machine. I have the
> > > > following error message:
> > > > Compiling FBLASLAPACK; this may take several minutes
> > > > TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
> > > > UNABLE to CONFIGURE with GIVEN OPTIONS (see
> configure.log for
> > > > details):
> > > > The configuration log was attached.
> > > > Thanks,
> > > > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200312/51edd90a/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200312/51edd90a/attachment-0001.obj>
