[petsc-users] --download-fblaslapack libraries cannot be used
Thu Mar 12 14:38:19 CDT 2020
For some reason - the fortran compiler libraries check worked fine without -lgfortran.
But now - flbaslapack check is failing without it.
To work arround - you can use option LIBS=-lgfortran
Satish
On Thu, 12 Mar 2020, Fande Kong wrote:
> Hi All,
> I had an issue when configuring petsc on a linux machine. I have the
> following error message:
>      Compiling FBLASLAPACK; this may take several minutes
>    TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> The configuration log was attached.
> Thanks,
> Fande,
