[petsc-users] installing petsc via spack on ac922 (a summit like system)
Cameron Smith
smithc11 at rpi.edu
Tue Mar 10 08:27:02 CDT 2020
That makes sense. Thank you.
-Cameron
On 3/10/20 9:25 AM, Satish Balay wrote:
> PETSc configure attempts to check for compiler libraries [so that one
> can mix and use c,c++,fortran codes with a c linker] by running
> compilers in verbose mode - and parsing the output. [i.e checkCLibraries(), checkFortranLibraries() ..]
> Here IBM compiler is using different library internally based on 'xlc -V' vs 'xlc -fopenmp -V'. For most other compilers - its just an additional library [with corresponding include file]
> So -fopenmp needs to be set before this step [checkCLibraries()] in configure.
> PETSc configure treats -with-openmp as an additional package - and process this option after the above checkCLibraries() check.
> However CFLAGS etc get processed and set before the call to checkCLibraries().
> My suggestion is a workaround to get -fopenmp option set before checkCLibraries() are called.
> Satish
> On Tue, 10 Mar 2020, Cameron Smith wrote:
>> Thank you. I'll give that a shot.
>> Out of curiosity, how does passing the openmp flags relate to the
>> '--with-openmp' option described here:
>> https://www.mcs.anl.gov/petsc/documentation/installation.html
>> under 'Installing packages that utilize OpenMP'? Is this just passing the
>> openmp flags into compile/link commands of the packages that petsc builds
>> (via, --download-<package> options) and not to the petsc compile/link?
>> -Cameron
>> On 3/10/20 9:01 AM, Satish Balay wrote:
>>> BTW: You might be able to do the same via spack.
>>> spack install petsc at 3.7.7 ~hdf5 ~hypre ~superlu-dist cflags=-fopenmp
>>> fflags=-fopenmp cxxflags=-fopenmp
>>> Satish
>>> On Tue, 10 Mar 2020, Satish Balay via petsc-users wrote:
>>>> Cameron,
>>>> You can try changing following petsc configure options and see if that
>>>> works.. [i.e build petsc manually]
>>>> CFLAGS=-fopenmp FFLAGS=-fopenmp CXXFLAGS=-fopenmp
>>>> Satish
>>>>> Thank you Mark.
>>>>> The configure.log is attached.
>>>>> Please let me know if any other info is needed.
>>>>> -Cameron
>>>>> On 3/10/20 7:31 AM, Mark Adams wrote:
>>>>>> Hi Cameron,
>>>>>> This can go on the list and we always want the configure.log file.
>>>>>> I build on Summit, but have not used the XL compilers. I've built 3.7.7
>>>>>> with
>>>>>> GNU and PGI. (XGC usually wants PGI)
>>>>>> On Mon, Mar 9, 2020 at 11:27 PM Cameron Smith <smithc11 at rpi.edu
>>>>>> <mailto:smithc11 at rpi.edu>> wrote:
>>>>>> Hello,
>>>>>> I'm installing petsc 3.7.7 on a summit like system with the
>>>>>> following
>>>>>> spack spec:
>>>>>> with the XL 16.1.1 compiler and Spectrum MPI 10.3 . This install
>>>>>> produces a `/path/to/petsc/install/lib/petsc/conf/petscvariables`
>>>>>> file
>>>>>> that contains '-lxlomp_ser' in the 'PETSC_EXTERNAL_LIB_BASIC' and
>>>>>> 'PETSC_WITH_EXTERNAL_LIB' variables.
>>>>>> The application I'm building, XGC, has a makefile based build system
>>>>>> that includes '/path/to/petsc/install/lib/petsc/conf/variables'
>>>>>> which in
>>>>>> turn includes '/lib/petsc/conf/petscvariables'.
>>>>>> From what I can tell, xlomp_ser is a serial implementation of the
>>>>>> openmp library. When XGC links this library it satisfies the openmp
>>>>>> symbols XGC wants and at run time results in openmp API calls like
>>>>>> 'omp_get_max_threads()' returning 1 regardless of the
>>>>>> OMP_NUM_THREADS
>>>>>> setting.
>>>>>> Do you know how I can build petsc, with or without spack, and avoid
>>>>>> this
>>>>>> library being listed in 'lib/petsc/conf/petscvariables'?
>>>>>> If this should go to a petsc mailing list or git repo issues page I
>>>>>> can
>>>>>> send it there.
>>>>>> Thank-you,
>>>>>> Cameron
