[petsc-users] installing petsc via spack on ac922 (a summit like system)
Cameron Smith smithc11 at rpi.edu
Tue Mar 10 08:09:15 CDT 2020
Thank you.  I'll give that a shot.
Out of curiosity, how does passing the openmp flags relate to the
'--with-openmp' option described here:
https://www.mcs.anl.gov/petsc/documentation/installation.html
under 'Installing packages that utilize OpenMP'?  Is this just passing
the openmp flags into compile/link commands of the packages that petsc
builds (via, --download-<package> options) and not to the petsc
compile/link?
-Cameron
On 3/10/20 9:01 AM, Satish Balay wrote:
> BTW: You might be able to do the same via spack.
> spack install petsc at 3.7.7 ~hdf5 ~hypre ~superlu-dist cflags=-fopenmp fflags=-fopenmp cxxflags=-fopenmp
> Satish
> On Tue, 10 Mar 2020, Satish Balay via petsc-users wrote:
>> Cameron,
>> You can try changing following petsc configure options and see if that works.. [i.e build petsc manually]
>> CFLAGS=-fopenmp FFLAGS=-fopenmp CXXFLAGS=-fopenmp
>> Satish
>> On Tue, 10 Mar 2020, Cameron Smith wrote:
>>> Thank you Mark.
>>> The configure.log is attached.
>>> Please let me know if any other info is needed.
>>> -Cameron
>>> On 3/10/20 7:31 AM, Mark Adams wrote:
>>>> Hi Cameron,
>>>> This can go on the list and we always want the configure.log file.
>>>> I build on Summit, but have not used the XL compilers. I've built 3.7.7 with
>>>> GNU and PGI. (XGC usually wants PGI)
>>>> On Mon, Mar 9, 2020 at 11:27 PM Cameron Smith <smithc11 at rpi.edu
>>>> <mailto:smithc11 at rpi.edu>> wrote:
>>>>      Hello,
>>>>      I'm installing petsc 3.7.7 on a summit like system with the following
>>>>      spack spec:
>>>>      with the XL 16.1.1 compiler and Spectrum MPI 10.3 .  This install
>>>>      produces a `/path/to/petsc/install/lib/petsc/conf/petscvariables` file
>>>>      that contains '-lxlomp_ser' in the 'PETSC_EXTERNAL_LIB_BASIC' and
>>>>      'PETSC_WITH_EXTERNAL_LIB' variables.
>>>>      The application I'm building, XGC, has a makefile based build system
>>>>      that includes '/path/to/petsc/install/lib/petsc/conf/variables'
>>>>      which in
>>>>      turn includes '/lib/petsc/conf/petscvariables'.
>>>>       From what I can tell, xlomp_ser is a serial implementation of the
>>>>      openmp library.  When XGC links this library it satisfies the openmp
>>>>      symbols XGC wants and at run time results in openmp API calls like
>>>>      'omp_get_max_threads()' returning 1 regardless of the OMP_NUM_THREADS
>>>>      setting.
>>>>      Do you know how I can build petsc, with or without spack, and avoid
>>>>      this
>>>>      library being listed in 'lib/petsc/conf/petscvariables'?
>>>>      If this should go to a petsc mailing list or git repo issues page I can
>>>>      send it there.
>>>>      Thank-you,
>>>>      Cameron
