[petsc-users] installing petsc via spack on ac922 (a summit like system)
Satish Balay
balay at mcs.anl.gov
Tue Mar 10 07:55:16 CDT 2020
Cameron,
You can try changing following petsc configure options and see if that works.. [i.e build petsc manually]
CFLAGS=-fopenmp FFLAGS=-fopenmp CXXFLAGS=-fopenmp
Satish
On Tue, 10 Mar 2020, Cameron Smith wrote:
> Thank you Mark.
> The configure.log is attached.
> Please let me know if any other info is needed.
> -Cameron
> On 3/10/20 7:31 AM, Mark Adams wrote:
> > Hi Cameron,
> > This can go on the list and we always want the configure.log file.
> > I build on Summit, but have not used the XL compilers. I've built 3.7.7 with
> > GNU and PGI. (XGC usually wants PGI)
> > On Mon, Mar 9, 2020 at 11:27 PM Cameron Smith <smithc11 at rpi.edu
> > <mailto:smithc11 at rpi.edu>> wrote:
> > Hello,
> > I'm installing petsc 3.7.7 on a summit like system with the following
> > spack spec:
> > petsc at 3.7.7 ~hdf5 ~hypre ~superlu-dist
> > with the XL 16.1.1 compiler and Spectrum MPI 10.3 . This install
> > produces a `/path/to/petsc/install/lib/petsc/conf/petscvariables` file
> > that contains '-lxlomp_ser' in the 'PETSC_EXTERNAL_LIB_BASIC' and
> > 'PETSC_WITH_EXTERNAL_LIB' variables.
> > The application I'm building, XGC, has a makefile based build system
> > that includes '/path/to/petsc/install/lib/petsc/conf/variables'
> > which in
> > turn includes '/lib/petsc/conf/petscvariables'.
> > From what I can tell, xlomp_ser is a serial implementation of the
> > openmp library. When XGC links this library it satisfies the openmp
> > symbols XGC wants and at run time results in openmp API calls like
> > 'omp_get_max_threads()' returning 1 regardless of the OMP_NUM_THREADS
> > setting.
> > Do you know how I can build petsc, with or without spack, and avoid
> > this
> > library being listed in 'lib/petsc/conf/petscvariables'?
> > If this should go to a petsc mailing list or git repo issues page I can
> > send it there.
> > Thank-you,
> > Cameron
