[petsc-users] Memory leak at GPU when updating matrix of type mpiaijcusparse (CUDA)
jordic
jordic at cttc.upc.edu
Tue Mar 3 04:50:11 CST 2020
Hello Junchao,
Thank you very much for solving these problems so quickly!
Best regards,
Jorge
On 2020-03-03 00:35, Junchao Zhang wrote:
> Jorge,
> I found multiple problems in petsc with your example. I have a fix at https://gitlab.com/petsc/petsc/-/merge_requests/2575
> If everything goes well, it will be in maint and master in a few days.
> Thanks for reporting the problem.
> --Junchao Zhang
> On Fri, Feb 28, 2020 at 12:13 PM Junchao Zhang <jczhang at mcs.anl.gov> wrote:
> I will take a look at it and get back to you. Thanks.
> On Fri, Feb 28, 2020, 7:29 AM jordic <jordic at cttc.upc.edu> wrote:
> Dear all,
> the following simple program:
> #include <petscmat.h>
> PetscInt ierr=0;
> int main(int argc,char **argv)
> MPI_Comm comm;
> PetscMPIInt rank,size;
> PetscInitialize(&argc,&argv,NULL,help);if (ierr) return ierr;
> comm = PETSC_COMM_WORLD;
> MPI_Comm_rank(comm,&rank);
> MPI_Comm_size(comm,&size);
> Mat A;
> MatCreate(comm, &A);
> MatSetSizes(A, 1, 1, PETSC_DETERMINE, PETSC_DETERMINE);
> MatSetFromOptions(A);
> PetscInt dnz=1, onz=0;
> MatMPIAIJSetPreallocation(A, 0, &dnz, 0, &onz);
> MatSetOption(A, MAT_NO_OFF_PROC_ENTRIES, PETSC_TRUE);
> MatSetOption(A, MAT_IGNORE_ZERO_ENTRIES, PETSC_TRUE);
> PetscInt igid=rank, jgid=rank;
> PetscScalar value=rank+1.0;
> // for(int i=0; i<10; ++i)
> for(;;) //infinite loop
> MatSetValue(A, igid, jgid, value, INSERT_VALUES);
> MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
> MatDestroy(&A);
> PetscFinalize();
> return ierr;
> creates a simple diagonal matrix with one value per mpi-core. If the type of the matrix is "mpiaij" (-mat_type mpiaij) there is no problem but with "mpiaijcusparse" (-mat_type mpiaijcusparse) the memory usage at the GPU grows with every iteration of the infinite loop. The only solution that I found is to destroy and create the matrix every time that it needs to be updated. Is there a better way to avoid this problem?
> I am using Petsc Release Version 3.12.2 with this configure options:
> Configure options --package-prefix-hash=/home_nobck/user/petsc-hash-pkgs --with-debugging=0 --with-fc=0 CC=gcc CXX=g++ --COPTFLAGS="-g -O3" --CXXOPTFLAGS="-g -O3" --CUDAOPTFLAGS="-D_FORCE_INLINES -g -O3" --with-mpi-include=/usr/lib/openmpi/include --with-mpi-lib="-L/usr/lib/openmpi/lib -lmpi_cxx -lmpi" --with-cuda=1 --with-precision=double --with-cuda-include=/usr/include --with-cuda-lib="-L/usr/lib/x86_64-linux-gnu -lcuda -lcudart -lcublas -lcufft -lcusparse -lcusolver" PETSC_ARCH=arch-ci-linux-opt-cxx-cuda-double
> Thanks for your help,
> Jorge
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200303/b01b1ac9/attachment-0001.html>
