[petsc-users] PETSc and Windows 10
Pierre Jolivet pierre.jolivet at enseeiht.fr
Tue Jun 30 08:22:46 CDT 2020
Please use the 3.13.2 tarball, this was fixed by Satish in the previous commit I already linked (https://gitlab.com/petsc/petsc/-/commit/2cd8068296b34e127f055bb32f556e3599f17523 <https://gitlab.com/petsc/petsc/-/commit/2cd8068296b34e127f055bb32f556e3599f17523>).
(If you want FreeFEM to do the dirty work for you, just switch to the develop branch, and redo “make petsc-slepc”)
But I think you’ve got everything you need now for a smooth compilation :)
Pierre
> On 30 Jun 2020, at 3:09 PM, Paolo Lampitella <paololampitella at hotmail.com> wrote:
> Dear Pierre,
> thanks for the fast response. Unfortunately it still fails, but now in the configure of ScaLAPACK
> (which means that it went ok for slepc, tetgen, metis, parmetis, ptscotch, superlu and suitesparse).
> The way I applied the modification is by manually editing the Makefile in the 3rdparty/ff-petsc folder, adding -fallow-invalid-boz to both CFLAGS and FFLAGS (this entry added by me). Then executed make petsc-slepc.
> As my project is much less ambitious, I have a good feeling that I will be able to use your Makefile successfully, but as I am kind of slow I tought that it would have been useful for you to know. The configure.log is attached. This time the error is:
> Rank mismatch between actual argument at (1) and actual argument at (2) (scalar and rank-1)
> in subroutine pclarf.f of ScaLAPACK.
> However, before attampting with my project, I have few questions about your Makefile, in particular this piece:
> --with-mpi-lib=/c/Windows/System32/msmpi.dll --with-mpi-include=/home/paolo/FreeFem-sources/3rdparty/include/msmpi --with-mpiexec="/C/Program\ Files/Microsoft\ MPI/Bin/mpiexec"
> I see from MPI.py that I should not use ‘--with-mpi-lib/include’ if I want to use my now working mpi wrappers. Is this correct?
> Paolo
> Inviato da Posta <https://go.microsoft.com/fwlink/?LinkId=550986> per Windows 10
> Da: Pierre Jolivet <mailto:pierre.jolivet at enseeiht.fr>
> Inviato: lunedì 29 giugno 2020 21:37
> A: Paolo Lampitella <mailto:paololampitella at hotmail.com>
> Cc: Matthew Knepley <mailto:knepley at gmail.com>; petsc-users <mailto:petsc-users at mcs.anl.gov>
> Oggetto: Re: [petsc-users] PETSc and Windows 10
> I do not give up easily on Windows problems:
> 1) that’s around 50% of our (FreeFEM) user-base (and I want them to use PETSc and SLEPc, ofc…)
> 2) most people I work with from corporations just have Windows laptops/desktops and I always recommend MSYS because it’s very lightweight and you can pass .exe around
> 3) I’ve bothered enough Satish, Jed, and Matt on GitLab to take (at least partially) the blame now when it doesn’t work on MSYS
> That being said, the magic keyword is the added flag FFLAGS="-fallow-invalid-boz" (see, I told you ./configure issues were easier to deal with than the others).
> Here you’ll see that everything goes through just fine (sorry, it took me a long time to post this because everything is slow on my VM):
> 1) http://jolivet.perso.enseeiht.fr/win10/configure.log <http://jolivet.perso.enseeiht.fr/win10/configure.log>
> 2) http://jolivet.perso.enseeiht.fr/win10/make.log <http://jolivet.perso.enseeiht.fr/win10/make.log> (both steps #1 and #2 in MSYS terminal, gcc/gfortran 10, MS-MPI see screenshot)
> 3) http://jolivet.perso.enseeiht.fr/win10/ex2.txt <http://jolivet.perso.enseeiht.fr/win10/ex2.txt> (Command Prompt, 4 processes + MUMPS, I can send you the .exe if you want to try on your machine)
> I just realize that I didn’t generate the Fortran bindings, but you can see I compiled MUMPS and ScaLAPACK, so that shouldn’t be a problem.
> Or if there is a problem, we will need to fix this in PETSc.
> I’ll push this added flag to the FreeFEM repo, thanks for reminding me of the brokenness of gcc/gfortran 10 + MS-MPI.
> Here is to hoping this won’t affect PETSc ./configure with previous gcc/gfortran version (unlikely, this option is apparently 13-year old https://gcc.gnu.org/bugzilla/show_bug.cgi?id=29471 <https://gcc.gnu.org/bugzilla/show_bug.cgi?id=29471>)
> Let me know of the next hiccup, if any.
> Thanks,
> Pierre
> On 29 Jun 2020, at 8:09 PM, Paolo Lampitella <paololampitella at hotmail.com <mailto:paololampitella at hotmail.com>> wrote:
> Dear Pierre,
> thanks again for your time
> I guess there is no way for me to use the toolchain you are using (I don’t remember having any choice on which version of MSYS or GCC I could install)
> Paolo
> Inviato: lunedì 29 giugno 2020 20:01
> A: Matthew Knepley <mailto:knepley at gmail.com>
> Cc: Paolo Lampitella <mailto:paololampitella at hotmail.com>; petsc-users <mailto:petsc-users at mcs.anl.gov>
> On 29 Jun 2020, at 7:47 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Mon, Jun 29, 2020 at 1:35 PM Paolo Lampitella <paololampitella at hotmail.com <mailto:paololampitella at hotmail.com>> wrote:
> Dear Pierre, sorry to bother you, but I already have some issues. What I did:
> pacman -R mingw-w64-x86_64-python mingw-w64-x86_64-gdb (is gdb also troublesome?)
> Followed points 6 and 7 at https://doc.freefem.org/introduction/installation.html#compilation-on-windows <https://doc.freefem.org/introduction/installation.html#compilation-on-windows>
> I first got a warning on the configure at point 6, as –disable-hips is not recognized. Then, on make ‘petsc-slepc’ of point 7 (no SUDO=sudo flag was necessary) I got to this point:
> tar xzf ../pkg/petsc-lite-3.13.0.tar.gz
> patch -p1 < petsc-suitesparse.patch
> patching file petsc-3.13.0/config/BuildSystem/config/packages/SuiteSparse.py
> touch petsc-3.13.0/tag-tar
> cd petsc-3.13.0 && ./configure MAKEFLAGS='' \
>         --prefix=/home/paolo/freefem/ff-petsc//r \
>         --with-debugging=0 COPTFLAGS='-O3 -mtune=generic' CXXOPTFLAGS='-O3 -mtune=generic' FOPTFLAGS='-O3 -mtune=generic' --with-cxx-dialect=C++11 --with-ssl=0 --with-x=0 --with-fortran-bindings=0 --with-shared-libraries=0 --with-cc='gcc' --with-cxx='g++' --with-fc='gfortran' CXXFLAGS='-fno-stack-protector' CFLAGS='-fno-stack-protector' --with-scalar-type=real --with-mpi-lib='/c/Windows/System32/msmpi.dll' --with-mpi-include='/home/paolo/FreeFem-sources/3rdparty/include/msmpi' --with-mpiexec='/C/Program\ Files/Microsoft\ MPI/Bin/mpiexec' --with-blaslapack-include='' --with-blaslapack-lib='/mingw64/bin/libopenblas.dll' --download-scalapack --download-metis --download-ptscotch --download-mumps --download-hypre --download-parmetis --download-superlu --download-suitesparse --download-tetgen --download-slepc '--download-metis-cmake-arguments=-G "MSYS Makefiles"' '--download-parmetis-cmake-arguments=-G "MSYS Makefiles"' '--download-superlu-cmake-arguments=-G "MSYS Makefiles"' '--download-hypre-configure-arguments=--build=x86_64-linux-gnu --host=x86_64-linux-gnu' PETSC_ARCH=fr
>              Configuring PETSc to compile on your system
> TESTING: FortranMPICheck from config.packages.MPI(config/BuildSystem/config/pack*******************************************************************************
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> Fortran error! mpi_init() could not be located!
> make: *** [Makefile:210: petsc-3.13.0/tag-conf-real] Errore 1
> Note that I didn’t add anything to any PATH variable, because this is not mentioned in your documentation.
> On a side note, this is the same error I got when trying to build PETSc in Cygwin with the default OpenMPI available in Cygwin.
> I am attaching the configure.log… it seems to me that the error comes from the configure trying to include the mpif.h in your folder and not using the -fallow-invalid-boz flag that I had to use, for example, to compile mpi.f90 into mpi.mod
> But I’m not sure why this is happening
> Pierre,
> Could this be due to gcc 10?
> Sorry, I’m slow. You are right. Our workers use gcc 9, everything is fine, but I see on my VM which I updated that I use gcc 10 and had to disable Fortran, I guess the MUMPS run I showcased was with a prior PETSc build.
> I’ll try to resolve this and will keep you posted.
> They really caught a lot of people off guard with gfortran 10…
> Thanks,
> Pierre
> Executing: gfortran -c -o /tmp/petsc-ur0cff6a/config.libraries/conftest.o -I/tmp/petsc-ur0cff6a/config.compilers -I/tmp/petsc-ur0cff6a/config.setCompilers -I/tmp/petsc-ur0cff6a/config.compilersFortran -I/tmp/petsc-ur0cff6a/config.libraries  -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 -mtune=generic   -I/home/paolo/FreeFem-sources/3rdparty/include/msmpi /tmp/petsc-ur0cff6a/config.libraries/conftest.F90
> Possible ERROR while running compiler: exit code 1
> stderr:
> C:/msys64/home/paolo/FreeFem-sources/3rdparty/include/msmpi/mpif.h:227:36:
>   227 |        PARAMETER (MPI_DATATYPE_NULL=z'0c000000')
>       |                                    1
> Error: BOZ literal constant at (1) is neither a data-stmt-constant nor an actual argument to INT, REAL, DBLE, or CMPLX intrinsic function [see '-fno-allow-invalid-boz']
> C:/msys64/home/paolo/FreeFem-sources/3rdparty/include/msmpi/mpif.h:303:27:
>   303 |        PARAMETER (MPI_CHAR=z'4c000101')
>       |                           1
> C:/msys64/home/paolo/FreeFem-sources/3rdparty/include/msmpi/mpif.h:305:36:
>   305 |        PARAMETER (MPI_UNSIGNED_CHAR=z'4c000102')
>       |                                    1
>   Thanks,
>      Matt
> Thanks
> Paolo
> Inviato: lunedì 29 giugno 2020 18:34
> Cc: Satish Balay <mailto:balay at mcs.anl.gov>; petsc-users <mailto:petsc-users at mcs.anl.gov>
> On 29 Jun 2020, at 6:27 PM, Paolo Lampitella <paololampitella at hotmail.com <mailto:paololampitella at hotmail.com>> wrote:
> I think I made the first step of having mingw64 from msys2 working with ms-mpi.
> I found that the issue I was having was related to:
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=91556 <https://gcc.gnu.org/bugzilla/show_bug.cgi?id=91556>
> and, probably (but impossible to check now), I was using an msys2 and/or mingw mpi package before this fix:
> https://github.com/msys2/MINGW-packages/commit/11b4cff3d2ec7411037b692b0ad5a9f3e9b9978d#diff-eac59989e3096be97d940c8f47b50fba <https://github.com/msys2/MINGW-packages/commit/11b4cff3d2ec7411037b692b0ad5a9f3e9b9978d#diff-eac59989e3096be97d940c8f47b50fba>
> Admittedly, I never used gcc 10 before on any machine. Still, I feel that reporting that sort of error in that way is,
> at least, misleading (I would have preferred the initial implementation as mentioned in the gcc bug track).
> A second thing that I was not used to, and made me more uncertain of the procedure I was following, is having to compile myself the mpi module. There are several version of this out there, but I decided to stick with this one:
> https://www.scivision.dev/windows-mpi-msys2/ <https://www.scivision.dev/windows-mpi-msys2/>
> even if there seems to be no need to include -fno-range-check and the current mpi.f90 version is different from the mpif.h as reported here:
> https://github.com/microsoft/Microsoft-MPI/issues/33 <https://github.com/microsoft/Microsoft-MPI/issues/33>
> which, to me, are both signs of lack of attention on the fortran side by those that maintain this thing.
> In summary, this is the procedure I followed so far (on a 64 bit machine with Windows 10):
> Install MSYS2 from https://www.msys2.org/ <https://www.msys2.org/> and just follow the install wizard
> Open the MSYS2 terminal and execute: pacman -Syuu
> Close the terminal when asked and reopen it
> Keep executing ‘pacman -Syuu’ until nothing else needs to be updated
> Close the MSYS2 terminal and reopen it (I guess because was in paranoid mode), then install packages with:
> pacman -S base-devel git gcc gcc-fortran bsdcpio lndir pax-git unzip
> pacman -S mingw-w64-x86_64-toolchain
> pacman -S mingw-w64-x86_64-msmpi
> pacman -S mingw-w64-x86_64-cmake
> pacman -S mingw-w64-x86_64-freeglut
> pacman -S mingw-w64-x86_64-gsl
> pacman -S mingw-w64-x86_64-libmicroutils
> pacman -S mingw-w64-x86_64-hdf5
> pacman -S mingw-w64-x86_64-openblas
> pacman -S mingw-w64-x86_64-arpack
> pacman -S mingw-w64-x86_64-jq
> This set should include all the libraries mentioned by Pierre and/or used by his Jenkins, as the final scope here is to have PETSc and dependencies working. But I think that for pure MPI one could stop to msmpi (even, maybe, just install msmpi and have the dependencies figured out by pacman). Honestly, I don’t remember the exact order I used to install the packages, but this should not affect things. Also, as I was still in paranoid mode, I kept executing ‘pacman -Syuu’ after each package was installed. After this, close the MSYS2 terminal.
> Open the MINGW64 terminal and create the .mod file out of the mpi.f90 file, as mentioned here https://www.scivision.dev/windows-mpi-msys2/ <https://www.scivision.dev/windows-mpi-msys2/>, with:
> cd /mingw64/include
> gfortran mpif90 -c -fno-range-check -fallow-invalid-boz
> Ah, yes, that’s new to gfortran 10 (we use gfortran 9 on our workers), which is now what’s ship with MSYS2 (we haven’t updated yet). Sorry that I forgot about that.
> This is needed to ‘USE mpi’ (as opposed to INCLUDE ‘mpif.h’)
> Install the latest MS-MPI (both sdk and setup) from https://www.microsoft.com/en-us/download/details.aspx?id=100593 <https://www.microsoft.com/en-us/download/details.aspx?id=100593>
> At this point I’ve been able to compile (using the MINGW64 terminal) different mpi test programs and they run as expected in the classical Windows prompt. I added this function to my .bashrc in MSYS2 in order to easily copy the required dependencies out of MSYS:
> function copydep() { ldd $1 | grep "=> /$2" | awk '{print $3}' | xargs -I '{}' cp -v '{}' .; }
> which can be used, with the MINGW64 terminal, by navigating to the folder where the final executable, say, my.exe, resides (even if under a Windows path) and executing:
> copydep my.exe mingw64
> This, of course, must be done before actually trying to execute the .exe in the windows cmd prompt.
> Hopefully, I should now be able to follow Pierre’s instructions for PETSc (but first I wanna give a try to the system python before removing it)
> Looks like the hard part is over. It’s usually easier to deal with ./configure issues.
> If you have weird errors like “incomplete Cygwin install” or whatever, this is the kind of issues I was referring to earlier.
> In that case, what I’d suggest is just, as before:
> pacman -S python
> Thanks,
> Pierre
> Thanks
> Paolo
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200630/778abc1e/attachment-0001.html>
