[petsc-users] R: PETSc and Windows 10
Paolo Lampitella
paololampitella at hotmail.com
Mon Jun 29 09:27:04 CDT 2020
As a follow up on the OpenMPI matter in Cygwin, I wasn’t actually able to use the cygwin version at all, not even compiling a simple mpi test.
And PETSc fails in using it as well, as it seems unable to find MPI_Init.
I might try with having PETSc install it as it did with MPICH, but just for future reference if anyone is interested
Paolo
Inviato da Posta<https://go.microsoft.com/fwlink/?LinkId=550986> per Windows 10
Da: Satish Balay<mailto:balay at mcs.anl.gov>
Inviato: domenica 28 giugno 2020 18:17
A: Satish Balay via petsc-users<mailto:petsc-users at mcs.anl.gov>
Cc: Paolo Lampitella<mailto:paololampitella at hotmail.com>; Pierre Jolivet<mailto:pierre.jolivet at enseeiht.fr>
Oggetto: Re: [petsc-users] PETSc and Windows 10
On Sun, 28 Jun 2020, Satish Balay via petsc-users wrote:
> On Sun, 28 Jun 2020, Paolo Lampitella wrote:
> > * For my Cygwin-GNU route (basically what is mentioned in PFLOTRAN documentation), am I expected to then run from the cygwin terminal or should the windows prompt work as well? Is the fact that I require a second Enter hit and the mismanagement of serial executables the sign of something wrong with the Windows prompt?
> I would think Cygwin-GNU route should work. I'll have to see if I can reproduce the issues you have.
I attempted a couple of builds - one with mpich and the other with cygwin-openmpi
mpich compiled petsc example works sequentially - however mpiexec appears to require cygwin env.
C:\petsc-install\bin>ex5f
Number of SNES iterations = 4
C:\petsc-install\bin>mpiexec -n 1 ex5f
[cli_0]: write_line error; fd=448 buf=:cmd=init pmi_version=1 pmi_subversion=1
system msg for write_line failure : Bad file descriptor
[cli_0]: Unable to write to PMI_fd
[cli_0]: write_line error; fd=448 buf=:cmd=get_appnum
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(467):
MPID_Init(140).......: channel initialization failed
MPID_Init(421).......: PMI_Get_appnum returned -1
[cli_0]: aborting job:
cygwin-openmpi compiled petsc example binary gives errors even for sequential run
C:\Users\balay\test>ex5f
Warning: '/dev/shm' does not exists or is not a directory.
POSIX shared memory objects require the existance of this directory.
Create the directory '/dev/shm' and set the permissions to 01777.
For instance on the command line: mkdir -m 01777 /dev/shm
[ps5:00560] [[INVALID],INVALID] ORTE_ERROR_LOG: A system-required executable either could not be found or was not executable by this user in file /cygdrive/d/cyg_pub/devel/openmpi/v3.1/prova/openmpi-3.1.6-1.x86_64/src/openmpi-3.1.6/orte/mca/ess/singleton/ess_singleton_module.c at line 388
[ps5:00560] [[INVALID],INVALID] ORTE_ERROR_LOG: A system-required executable either could not be found or was not executable by this user in file /cygdrive/d/cyg_pub/devel/openmpi/v3.1/prova/openmpi-3.1.6-1.x86_64/src/openmpi-3.1.6/orte/mca/ess/singleton/ess_singleton_module.c at line 166
Sorry! You were supposed to get help about:
orte_init:startup:internal-failure
But I couldn't open the help file:
/usr/share/openmpi/help-orte-runtime: No such file or directory. Sorry!
So looks like you would need cygwin installed to run Cygwin-MPI binaries.. Also I don't know how cygwin/windows interaction overhead will affect parallel performance.
Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200629/6acb755f/attachment.html>
